C-5 Battery Replacement Questions
Old Feb 23, 2008 | 03:50 PM
Jailsey's Avatar
Jailsey
4th Gear
Default C-5 Battery Replacement Questions
My 02 convertible recently started having battery issues. Everytime I went to drive it the battery would be dead. So I finally replaced the battery. But when I went to start it the DIC said to "Pull Key Wait 10 Sec." I did that and then started it. After about 20 seconds the DIC started giving me messages such as "Reduce speed, Traction control problems, Check Tire Pressures, etc." Then the windows and door locks would not work. I removed the positive lead on the battery and waited 20 seconds to reset everything. I still can't get the windows, door locks, and driver memory to work. Does anyone have any suggestions?
Old Feb 23, 2008 | 03:52 PM
ov666's Avatar
ov666
clean leads again might still be dirty
Old Feb 23, 2008 | 08:39 PM
Dave68's Avatar
Dave68
That sounds like a short in the driver's door wire loom. See
http://forums.corvetteforum.com/showthread.php?t=896875
for tons of electrical info.
Old Feb 24, 2008 | 02:20 AM
DeeGee's Avatar
DeeGee
Good advice
Recheck that the leads are tight and clean. I'd also check the voltage on the battery to make sure you didn't get a bad one. Use a multi meter across the terminals with ignition off
If thats all good check the codes and then clear them down and see which ones come back. Post them up and it may give a clue as to where the problem is.
Old Feb 24, 2008 | 08:14 AM
rws.1's Avatar
rws.1
likely a poor negative lead connection.
A poor ground causes all sorts of DIC messages.
To C-5 Battery Replacement Questions
