Custom body work question ?
Old Feb 23, 2008 | 10:36 PM
CheckeredFlag's Avatar
CheckeredFlag
Default Custom body work question ?
pardon my quick drawing here
but would it be possible to fill the area that attaches the rear section to the rest of the car with a type of filler ?
or does that section flex enough that filler may crack with stress ?
just thinking out loud here with some old hot rod / smooth over ideas
the thought is that it would be perfectly smooth (with no line) after it was painted
could be a nice subtle difference - if it works
ideas ?
Old Feb 23, 2008 | 10:41 PM
bmw2nv2000's Avatar
bmw2nv2000
Flex will def. cause cracking, but they do offer a poly filler that is suppose to flex. I guess you could try that but honestly would probably end up being a costly attempt. But if ya do it keep us posted
Old Feb 23, 2008 | 10:48 PM
Never heard of anyone doing that or wanting to do that for that matter. Not sure how a filler would hold up when attached to two different types of panels.
Old Feb 23, 2008 | 10:53 PM
_Will_'s Avatar
_Will_
From: Somewhere between mild insanity and complete psychosis
I would advise against pursuing this further.
Find another appearance mod to satisfy your urge.
Old Feb 24, 2008 | 12:53 AM
Lancer033's Avatar
Lancer033
what happens when you have to pull the rear for maintenance
Old Feb 24, 2008 | 12:56 AM
DeeGee's Avatar
DeeGee
That was easy
Old Feb 24, 2008 | 03:02 AM
jdmvette's Avatar
jdmvette
Night Owl for life
yeah man, don't do it.
if you get hit in one quarter you'll have to replace both of them along with the rear fascia...talk about expensive.
Old Feb 24, 2008 | 03:24 AM
Junkman2008's Avatar
Junkman2008
That's what I was thinking...
Old Feb 24, 2008 | 06:46 AM
RSchleder's Avatar
RSchleder
Default No!
Extremely difficult to fill the gap between two panels made of different materials. Coefficient of expansion, etc, will drive you nuts!
Old Feb 24, 2008 | 07:37 AM
AU N EGL's Avatar
AU N EGL
Just drive your car more and you wont see it.
Old Feb 24, 2008 | 07:39 AM
ZO6 Lee's Avatar
ZO6 Lee
St. Jude Donor '08-'09-'10
Stay inside the car.
Old Feb 24, 2008 | 07:58 AM
Tuxblacray's Avatar
Tuxblacray
The answer to your question is yes.... Sand it, glass it, use Dura Glass filler, sand it, primer it, sand it, base coat, clear coat. Done seemless one piece body.
If the rear is in need to be removed then it would have to be cut loose at the seem. (no big deal)
Over time it will probally flex enough that a repair or replacement will be necessary. It should last a minumium of 5 years using the above outlined process.
I know that because it has on my C3. I did this because I wanted the seemless look, and because I got the ureathane bumper with lights for $80.00.
I was going to do the same process with fiberglass so let's call the this 1st run practice. The outcome was worth it! When it finally breaks open or cracks I will replace it with glass and know it will be flawless.
Here is a pic of my Blackray with the molded ureathane to glass job. It turned out great, and black isn't very forgiving to work with...
Old Feb 24, 2008 | 08:25 AM
CheckeredFlag
nice job
thats the look
thanks for all the info from everyone - gives me something to think about
To Custom body work question ?
