door reflector leds
I wired them into the footwell lights.Took the doorpanels off and fished the wires through the rubber door boot. Theres a square panel with awire harness coming through that you can just snap out by the kickpanel.They even left a little v at the top for the wires! Ran them most of the day and lost no more leds.
I have been looking at the reflectors to do this mod. When you drilled the holes for the LED's did you find that they are hollow or solid? To me it looks hollow without cutting into it.
Gary
THey are hollow as you suspect. The reflector has a slight dome to it and the back panel is flat. I learned to use a drill stop so you dont score the back of the reflector.I also discovered that they,or at least mine were easy to take apart. If you turn one on its side you can see a thin channel between the reflector and the backing it is glued to. I just carefully used a flat screwdriver and pried the reflector loose from its base.I had to replace a couple of leds that burnt out because of too high voltage.Then just superglued it back together.I took Sinisterc6 advice and increase the resistor size to a 560 ohm to protect the leds better. They worked fine is series untill I fired up the engine and got 14.2 volts then I started loosing leds. NO problems so far!!
Thanks for the info. I have some ideas for how to do this, just need to find the right LED's.
Gary
a different style of LED maybe?
i dunno, it just seems that they draw attention to themselves instead of being a "glow" of light.
maybe if there was some way to black out the underside of the lense, so the light could only shine out of the reflector from the top/bottom/sides or something.
i haven't looked at the reflector too much, does it have a clear lense and it's red behind it or is it red right at the surface?
I would love to try something like this on my wifes 99 coupe.
Can you please tell me where to buy the led's?
What wire did you tap into for power, and how did you tap into it?
I also need some advice on soldering - maybe my old soldering iron is just crapping out, but I have a rough time getting nice clean solder connections.
I use a wand-type 30w iron, do I just need a larger iron?
Any tips would be greatly appreciated.
best regards -
mqqn
Just remember that with a camera, it needs to stay open longer in those dark shots, so the pinpoint of light, while it looks very much like small spots, in real life it is probably much closer to a uniform glow - at least in my experience taking pictures at night....
best regards -
mqqn
http://www.oznium.com/led.
If your going to do the bare leds dont forget to buy the appropriate resistors. I route them along the doorpanel wiring,through the doorjamb boot and wire them into the footwell lighting under the dash.
The setup I use you can buy at radio shack.The dual temp iron 15/30 watt works best for me.I only use the 30 watt setting for larger wires.
I keep a tin of tip cleaner/tinner on the base as you can see.Also the sponge when wet cleans the tip also. There are EE techs on the forum who have tons more experience than me so maybe they can chip in also.I'll post some pics next.
Pull the doorpanel.Here is how I routed my wiring
look for this panel above the kickpanel and just snap it out.
This is where you tap into the footwell lights. If you have the access panel out to fish the wires through you cant miss it. I dont use my footwell lights because I have led floodlights to do the job.Jus tap the red wire into the orange and black to black. JOb finished!! HOpe this helps! Tom.
Cool mod
