tail lights out
Old Apr 6, 2008 | 01:43 PM
nuggins's Avatar
nuggins
Default tail lights out
the tail lights (parking lights), and fog lights and dash lights are out on my 99 vert ...i checked the fuses...anyone know what to do now...?
Old Apr 6, 2008 | 02:13 PM
leo97's Avatar
leo97
Default lights out
Did you check the fuses under the passenger foot well ? When mine went out it was a fuse, not sure if it was #7-8-5
Old Apr 6, 2008 | 02:21 PM
ctvette2003's Avatar
ctvette2003
PM Bill Curlee, he will know for sure, he is the forum electrical guru
Old Apr 6, 2008 | 03:47 PM
DeeGee's Avatar
DeeGee
Not certain but you may have more than one fault
The parking lamps and tails ground to G410 in the rear. The fogs ground to G102 in the front.
All have different fuses: Fog-Relay 39, back up-engine fuse 21 and relay 38
Here are the grounds locations
I'd start by cleaning the grounds and checking the connector in the passenger wheel well.
Old Apr 6, 2008 | 04:46 PM
nuggins's Avatar
nuggins
i see the braided ground strap is not connected...the power antenna is not hooked up...is that why...?
Old Apr 7, 2008 | 01:46 AM
DeeGee's Avatar
DeeGee
I would say so. Hook it up and you will probably be good to go
To tail lights out
