NEW Interior LED Mod Thread
Old Jan 18, 2016 | 03:07 AM
  #1161
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
YLO Z06 Did you remove the power board and flip it around to check? The other side is usually what gets hit.
I've never seen anyone fry the display board! Pretty wild...
Anyway, get to a Radio Shack or similar and get some very small gauge wire. Remove (scrape it off) the green coating over the track at each end where it is still good and also adhered to the board and tin those areas. Then solder in the repair piece of wire and check for continuity... Basically splicing around and replacing the bad sections of the burnt track with some wire.
THEN find the short that caused this problem in the first place!!!!
Tim
Old Jan 19, 2016 | 12:16 PM
  #1162
YLO Z06's Avatar
YLO Z06
2023 C5 of the Year Finalist - Modified
Tim
Tim,
Yes, I flipped the power board over and just as you said, there was another burned trace on that side in the lower left. So last night I removed all 3 bad traces and replaced with new copper wire as seen below. I ran a continuity test on all 3 with my multimeter and all check out fine. I did not epoxy the new wires yet until I plug the unit back in and ensure everything works.
I did not find any reason for the burned traces other than I installed one replacement fan speed LED backwards. That is the only thing I changed the other night. Before that, the unit was working perfectly (other than the fan speed LEDs not lighting up). So I soldered in new LEDs, but since there are 2 LEDs going into the one slot on the PCB, I had one of the LEDs in backwards (+ and - were switched). When I plugged the unit back in, that is when it got fried. So the LEDs on the fan speed switch is the only thing that changed and must be the source of my previous failure. Fingers crossed. I will plug it back in today.
Old Jan 19, 2016 | 03:45 PM
  #1163
YLO Z06's Avatar
YLO Z06
Plugged the HVAC head unit back in and everything lit up and all functions work ! I covered the copper wire repairs with silicone sealant to protect them from getting damaged. Thanks for all of your help (again), Tim!
Old Jan 20, 2016 | 02:26 AM
  #1164
tstar's Avatar
tstar
Hey good job! And really nice pictures also!!!
I was worried about that one blob of solder on the power board next to that diode but if all is sealed, working and functioning, you did GOOD!
Tim
Old Jan 20, 2016 | 02:49 PM
  #1165
YLO Z06's Avatar
YLO Z06
Well, I thought I was done. Drove the car to work today and noted that the HVAC stays lit up even after I shut the car off. It did not do this yesterday. I wonder if the fix on the power board really is too close to that diode and is causing my issue? Any ideas as to where to look for the problem? Thanks, Tim.
Old Jan 20, 2016 | 04:36 PM
  #1166
tstar's Avatar
tstar
Damn... yeah double check all your repairs!
Tim
Old Jan 20, 2016 | 04:37 PM
  #1167
YLO Z06's Avatar
YLO Z06
Tim
Probably the power board, not the light board, right?
Old Jan 20, 2016 | 04:43 PM
  #1168
tstar's Avatar
tstar
I would put money there... yes.
Tim
Old Jan 22, 2016 | 03:06 PM
  #1169
ErikwithAK01's Avatar
ErikwithAK01
Hey all, been lurking here for a long time, so I figured I would finally ask a question. I had JW Motoring (who don't seem to be in business anymore) modify my hvac unit a year ago to red LED's, and it's acting up pretty bad now. There are 1 or 2 that are out all the time now, and almost ALL the rest are intermittent (seems to be heat related, as most of them are on when I first start the car up). It's really starting to bug me, and I don't have the stomach, or facilities to safely disassemble the unit, so I ask, do any of you do the light conversion for people? Or is there a place that does this work like JW used to do?
Old Jan 22, 2016 | 11:09 PM
  #1170
YLO Z06's Avatar
YLO Z06
Tim
Have any extra power boards laying around...?
Old Jan 23, 2016 | 03:36 AM
  #1171
tstar's Avatar
tstar
It sounds like the resistors, I've had more problems with crappy resistors then anything else! I'm out of doing that stuff now, check that EBay guy...
Tim
Old Jan 23, 2016 | 03:43 AM
  #1172
tstar's Avatar
tstar
No, sorry... I don't think the LEDs being on constantly will have much of an impact on your battery though...
Tim
Old Jan 23, 2016 | 03:16 PM
  #1173
Esser's Avatar
Esser
So I installed the door and mirror switch LED's, in bright white, and was expecting them to make the letter show up white. Unfortunately all it did was make them brighter but still have the yellowish hue to them. I tried cleaning them but no luck, what would be happening? Especially the power mirror buttons more than the others. The colors are all different shades of white and yellow.
Old Jan 24, 2016 | 03:21 AM
  #1174
tstar's Avatar
tstar
I've decided to "bow out" of the Forum, I don't have the time anymore... I want to thank everyone for a fun and educational time!!!
Tim
Old Jan 25, 2016 | 01:14 AM
  #1175
Mickeyrx70's Avatar
Mickeyrx70
Tim
______________
Oh no!
Thanks for all you've done to help so many of us! Will you still be repairing HVACs for your old customers?
Old Jan 25, 2016 | 08:06 AM
  #1176
huesmann's Avatar
huesmann
Mine show up pretty white.
Old Mar 15, 2016 | 08:49 PM
  #1177
thedudeman's Avatar
thedudeman
Hello, so I want to replace the burned out bulbs in my C5 with leds. I read the initial part of this thread were they refer you to the oznium leds. However, it appears in the comments that these leds do not work well for C5s at all. Is there a current best place to get leds to replace the factory interior lights with? Thanks guys!
To NEW Interior LED Mod Thread
Old Mar 15, 2016 | 11:13 PM
  #1178
YLO Z06's Avatar
YLO Z06
Tim
Wow, quite a blow to the Forum to have you gone, Tim! I want to say thank you for all of the help and advice you have provided to us over the years and for the blood, sweat and tears you put into the lighting mods on our beloved cars. And for the hands-on work and expertise you provided when you actually modified customer components for JW (my radio and HVAC among countless others). I wish you and your family great blessings and joy, and hope your life is lived to the fullest. Thank you again for all you have contributed to this forum and its members. You will be missed, but not forgotten.
Jason
Old Mar 15, 2016 | 11:19 PM
  #1179
nascar57's Avatar
nascar57
Tim
Tim has helped me from the very beginning of my led mods. Invaluable help on so many projects. What started out as a fun hobby grew into a successful led business and I dont think I would have gotten there without Tim's help in the beginning.
Cheers to you Tim and Thank YOu.
Old Mar 16, 2016 | 12:35 AM
  #1180
Randomhero8's Avatar
Randomhero8
I just ordered some from corvettemods.com
I will post pics when I get them put in. Hopefully they are not junk.
