NEW Interior LED Mod Thread
Old Nov 17, 2008 | 08:24 AM
  #141
ljthe2nd's Avatar
ljthe2nd
Where did you measure the voltage? What is the voltage where the underhood light harness connects at the bottom of the hood?
Old Nov 17, 2008 | 08:54 AM
  #142
T_Vert's Avatar
T_Vert
the voltage is the same at the harness. I checked voltage at the two wires at the plug on the frame and also the two terminals where the light bulb attaches.
Old Nov 17, 2008 | 08:57 AM
  #143
ljthe2nd's Avatar
ljthe2nd
Did you try to see if the LED lights ok with a 12v source? Did you try the bulb with a 12v source?
Old Nov 17, 2008 | 09:02 AM
  #144
T_Vert's Avatar
T_Vert
LED and old light function fine w/ 12VDC from another source.
Old Nov 17, 2008 | 09:12 AM
  #145
ljthe2nd's Avatar
ljthe2nd
Use some jumper wires and go from the connector at the bottom of the hood where harness plugs in and see what happens when you go to the LED, then see what happens when you connect the bulb
(this is eliminating the switch in the light housing)?
Old Nov 17, 2008 | 10:05 AM
  #146
T_Vert's Avatar
T_Vert
I could certainly try this but, being as both the bulb socked and harness plug at the frame show the same voltage, I'd be surprised if there was any change.
Old Nov 17, 2008 | 10:14 AM
  #147
ljthe2nd's Avatar
ljthe2nd
I'm asking you to try the LED and the bulb with the voltage and current supplied at the connection near the bottom of the hood because since the beginning I suspected the switch in the underhood light housing. If you try this and it lights ok you will have proved that the switch is bad. If it still doesn't light properly this will mean you have a problem between the battery and this connection. If you don't want to try this, you're on your own because I'm out of idea's. good luck
Old Nov 17, 2008 | 10:25 AM
  #148
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Default Note on HVAC bulb swap
If you use pure (aka "cool white") LEDs for the HVAC controls, the blue tint in the buttons will give it an "aqua" color. (I call it a fruity blue) I'm working on a solution involving using "warm white" LEDs. the output from them is closer to a regular bulb and it should come out a pure white through the buttons.
Old Nov 17, 2008 | 03:00 PM
  #149
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
You're going to color you NEOs with a yellow highlighter aren't ya???????
Tim
Old Nov 17, 2008 | 03:02 PM
  #150
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Tim
nah....i found a place that sells 5mm white LEDs. But this isn't very high on the priority list.
Old Nov 17, 2008 | 03:05 PM
  #151
tstar's Avatar
tstar
I would imagine not, hey congrats on your sequential tail lights, they look amazing!!!!!!!!!!!!!
Tim
Old Nov 17, 2008 | 03:16 PM
  #152
Gonzo's Avatar
Gonzo
Well while reading the last 8 pages it has become apparent that I am the Forrest Gump of the Corvette Forum.
If I ever attempted this, my Zo6 would end up as a pile of parts on the garage floor. You guys are good and my hats off to you Very cool Mod
Forrest.......aka Gonzo
Old Nov 17, 2008 | 04:25 PM
  #153
nascar57's Avatar
nascar57
I have one of Larry's modded Electrochromatic mirrors with the Red Helper light and also a Red power on indicator as well as the maplights of course. The Red helper is brighter then the Orange but is not distracting while driving at night, I like it alot. The power on indicator is a little too bright, for me anyway someday I'll tone it down...
Larry obviously got the Auto Dim mirror apart without marking up the case at all. When I attempted taking a base mirror (NON Auto Dimming) apart I screwed the case up pretty badly. It was out of a Blazer and I had got it for the lenses so no biggy. It wasn't glued but I couldn't get the clips to release without applying destructive force!!!! So unless there's a secret trick or tool it isn't worth it IMO
By the way. have you tried my trick for using Blue or White LEDs in the LED Arrays?
Tim
PS When are you hooking up with Michael?
I havent tried the led trick with getting all 6 leds to light up in the mirror.I dont want to experiement with other peoples mirrors.Would do my own but it is red and as you know red is not a problem. Did my brothers in blue and 5 is plenty bright!
Michael will be here tonight so I'm looking forward to talking leds!!Got 2 more orders from jw today too!
Old Nov 18, 2008 | 12:14 AM
  #154
tstar's Avatar
tstar
If you want it done, we'll make sure it happens! PM me if you'd like.
Tim
Old Nov 18, 2008 | 01:12 AM
  #155
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
The Orange helper LED is 5mm I believe, you have to take apart the mirror to get at it. I attempted it once and pretty much cosmetically ruined my mirror!
FYI Orange is the weakest LED in terms of light output (mcd rating), Blue and White are two of the strongest. IMO replacing the stock one with White or Blue might be an anoyance when driving, kinda like having a dome light on.
My current mirror, an Electrochromatic, customized by my friend Larry has a Red LED for the helper light and it's substantially brighter then the stocker. Being Red it isn't glaring so not a problem driving at night with it...
Tim
I swapped my rear hatch, glove box, foot wells, and rear view all over to LED's today. The little orange helper LED was very easy to swap. I used a 5/32nds screw driver in the little slot of the holder button to turn the holder while using a little cheapy straight edged driver commonly used for advertising with the magnet on one end to pry up on the edges and it popped right out. Just pay attention to the way it was before you pull it out. The hole is D shaped and it took a bit to figure out how to pop it back in. The LED is crimped to a blue and a red wire. A simple snip and solder with some heat shrink and I now have a white LED shining down. It isn't annoying in the least. In fact it highlights the beer in the cup holder nicely. Not alot of the light comes out of the slot so it really is cool.
Old Nov 18, 2008 | 01:43 AM
  #156
tstar's Avatar
tstar
Hmmm I tried that and broke that slotted cover! Glad it worked out, good info for everyone else. I'd like to see a pic of your setup!!!!!
Tim
Old Nov 18, 2008 | 09:14 AM
  #157
mtndv8's Avatar
mtndv8
Default Thanks Tom!!
Originally Posted by nascar57
...Michael will be here tonight so I'm looking forward to talking leds!!...
New underhood LED spotlights!! WOO HOO!!!!!!! Can't wait to get home and install them.
Thanks for taking the time from your day/eve Tom!
VERY sahweet '01, Brother!!
Michael
To NEW Interior LED Mod Thread
Old Nov 18, 2008 | 11:31 AM
  #158
mcgilles's Avatar
mcgilles
doesn't sound bad at all. did you use a 3 or 5mm LED? what mcd? I think I would like white better than orange, but I certainly don't want it to be overpowering. can you adjust the aim of the LED with that slot? mine shines too far back, you an see the shifter fine if its in 2, 4, or 6, but 1, 3, 5, or R are still in the dark.
Old Nov 18, 2008 | 05:23 PM
  #159
nascar57's Avatar
nascar57
Default forum friends
Michael
No problem Michael,Had a great time meeting you and talking leds and vettes! I'll be waiting to see how the spots turn out!
Old Nov 18, 2008 | 06:11 PM
  #160
tstar's Avatar
tstar
Michael
Great to see you guys hooked up and hit off!!!!!
Tim
