NEW Interior LED Mod Thread
Old Nov 24, 2008 | 01:12 AM
  #181
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
It's no trouble, I have one tore apart right now in the basement and have been meaning to do it anyway... Go unwind and we'll see how long it takes, it it's too long it'll be waiting for you in the AM.
Tim
Old Nov 24, 2008 | 01:27 AM
  #182
rpm462's Avatar
rpm462
Tim
Thanks...greatly appreciated.
Old Nov 24, 2008 | 01:46 AM
  #183
tstar's Avatar
tstar
Ok Got it, uploading pics now... There's really only two circuits, it's just running crazy on the board.
Tim
Old Nov 24, 2008 | 01:51 AM
  #184
rpm462's Avatar
rpm462
Tim
Old Nov 24, 2008 | 01:55 AM
  #185
tstar's Avatar
tstar
On the Red harness... We'll call the Blue wire #1, here's the two jumpers.
1 - 3 = Hot
2 - 5 = Ground
And it works too!
Tim
Old Nov 24, 2008 | 02:20 AM
  #186
rpm462's Avatar
rpm462
1 - 3 = Hot
2 - 5 = Ground
And it works too!
Tim
Thanks Tim...looks good...will give it a try it in the morning...calling it a night. Much appreciated.
Old Nov 24, 2008 | 04:56 PM
  #187
rpm462's Avatar
rpm462
Ok, finally got back to it a little while ago and those pin outs worked great! Thanks again Tim. Was relieved to know I did have them in the right sequence.
Was a bit dim at first, but once I pulled the blue plastic sheet out made a big difference. Does seem to have a few hot spots but not sure what I can do to get rid of those. Just need to put it back together now.
Old Nov 24, 2008 | 05:00 PM
  #188
tstar's Avatar
tstar
Don't put it together yet!!!! PMing ya....
Old Nov 24, 2008 | 06:23 PM
  #189
rpm462's Avatar
rpm462
Ok here's what the foam layer looks like with the chrome tape on it.
Now the before & after shots, looks like it evened it up a bit.
Before
After
The "eject" button looks a lot better.
Old Nov 24, 2008 | 06:27 PM
  #190
tstar's Avatar
tstar
ok good!
Old Nov 24, 2008 | 06:31 PM
  #191
rpm462's Avatar
rpm462
One thing I just thought of...I imagine it will be quite a bit brighter when it's hooked back up to the actual 12-volt power in the the car. Have you noticed any huge differences in the ones you've done? Might make those hot spots a lot more noticeable, or bring out some others?
Old Nov 24, 2008 | 06:32 PM
  #192
tstar's Avatar
tstar
Not really, they look the same with a 9 volt battery or the car's voltage...
Tim
Old Nov 24, 2008 | 06:35 PM
  #193
rpm462's Avatar
rpm462
Tim
Good to hear...once again thanks for all the help. Going to go put it back together.
Old Nov 24, 2008 | 06:37 PM
  #194
tstar's Avatar
tstar
Anytime Bruce... take care.
Tim
Old Nov 29, 2008 | 03:16 PM
  #195
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Default All things Superflux!
My original interior LED lights started giving my problems recently with various bulbs burning out...causing others to quickly follow as the voltage per bulb changed. I ordered a pack of 20 superflux LEDs from ebay and couldn't be more pleased with the results.
Cargo lights using painted OEM lenses drilled for LEDs:
Footwell lights using painted 1/8" plexiglass.
Mounted:
Output shots:
The good news: I have light where i need it.
The bad news: I can now see my dirty carpet
Price list:
LEDs: $14 (pack of 20pcs)
Plexiglass FREE!!! (leftover from previous project)
Tech notes:
Each light uses (4) Superflux 5-chip LEDs. The draw is 100mA and 3.1v which means in series no resistor is needed. (12.3v total voltage drop)
Each LED produces 35,000MCD at 140 degree viewing angle. This converts to:
roughly 578 lumens per housing.
45.98 candle power per housing.
At a total of 2312 lm, My interior lights in OEM locations now produce roughly the same output as a 135w incandescent light bulb (2350 lm).
Old Nov 29, 2008 | 05:17 PM
  #196
tstar's Avatar
tstar
Very nice work!!!!! As always!
Tim
Old Nov 29, 2008 | 10:39 PM
  #197
nascar57's Avatar
nascar57
Hey RF nice work for sure!I was looking at the connectors you used. I have something very simular from autolumination but they dont have the center yellow wire as your does. Where did you get those and what purpose does the center wire serve?Power for another circuit?
To NEW Interior LED Mod Thread
Old Nov 29, 2008 | 11:30 PM
  #198
CircledWagons's Avatar
CircledWagons
From: Guess it & Win a Rock, s&h only $4.95 New Mexico
The members of this forum are AMAZING at coming with the most cool mods for their vette. Extra cool project for the winter.
Old Nov 29, 2008 | 11:51 PM
  #199
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
I got them from a 36LED array from autolumination.com about 6 months ago. The array crapped out so i cut off the 194 wiring harness and used it with my new ones. Their new models don't have the yellow wire either. strange....
Old Nov 30, 2008 | 02:00 AM
  #200
nascar57's Avatar
nascar57
I also wish they would quit changing the colors of the wires on the connectors! I keep having to change my instructions.NOt too many scources for these as far as I know.
