LED "halo" modification?
Old Apr 29, 2009 | 05:12 PM
  #321
jrc27's Avatar
jrc27
Cruise-In IV Veteran
Cruise-In V Veteran
take pics of progress please
Old Apr 29, 2009 | 09:19 PM
  #322
JMc's Avatar
JMc
From: "This is not a psychotic episode, but a cleansing moment of clarity."
Yo George! BackNBlack! Don't leave a brother hangin' here! I need to know which red wire to tap into with that second diode. Everything else has been done! Thank you in advance!
Old Apr 29, 2009 | 09:26 PM
  #323
backnblack2003z06's Avatar
backnblack2003z06
The red wire you want to use is the long red wire that goes from the connector to the circuit board. Im gonnna draw a picture for reference. I'll be home from work in a few minutes.
Old Apr 29, 2009 | 09:38 PM
  #324
JMc's Avatar
JMc
Thanks. My main problem is that I see no long red wire from any connector. I've got the red and orange wires on each side that are tied together via resistors and the only other red wires I see are jumpers connecting the three boards to each other. One, off to one side, appears longer than the rest of them, but I don't get the connector reference at all so I'm not sure if I'm tapping into the correct one or not.
Old Apr 29, 2009 | 09:43 PM
  #325
backnblack2003z06
What colors are the wires that come out of the connector that you plug into the tail light socket.
Old Apr 29, 2009 | 09:48 PM
  #326
JMc's Avatar
JMc
I've got two yellow and two white that are attached to the connector that the harness plugs into. The yellows go on the board near the word "stop".
  #327
backnblack2003z06
Old Apr 29, 2009 | 09:50 PM
  #328
backnblack2003z06
Well that explains that, mine are red like in the video, what I have marked as red in the picture you will consider yellow.
  #329
JMc's Avatar
JMc
Bingo. Got it now. Thank you.
Old Apr 29, 2009 | 09:57 PM
  #330
backnblack2003z06
Make sure of your diode orientation. The Cathode end should always be toward the wire with the resistors. Its not quite clear in my picture. An artist I am not.
Old Apr 29, 2009 | 10:23 PM
  #331
JMc's Avatar
JMc
Ugh. I got the diode orientation correct and just tried to power up my first completed lamp. No light at all. Not good. When I hit the brakes, the center cluster lights. But the halo is totally out...
Old Apr 29, 2009 | 10:25 PM
  #332
backnblack2003z06
What does it do when you turn on the head lamps.
Old Apr 29, 2009 | 10:28 PM
  #333
JMc's Avatar
JMc
Nothing. No Halo...
Old Apr 29, 2009 | 10:31 PM
  #334
backnblack2003z06
Try reversing the diode on the white wire and tell me what happens when you turn on the headlights.
Old Apr 29, 2009 | 10:33 PM
  #335
JMc's Avatar
JMc
You know, I took a different light out there and tried it again. Same result, but I tried reversing the plug and half the halo lit. ?!?!!?
Old Apr 29, 2009 | 10:36 PM
  #336
backnblack2003z06
Thats different, can you take a picture of the wiring and post it up so I can get a better idea whats going on.
Old Apr 29, 2009 | 10:50 PM
  #337
JMc's Avatar
JMc
What you CANNOT see in the pictures is the diode that is also connected to the white positive wire before it hits the resistored wires. Man, and I thought I was being very careful and tidy while I was doing all this stuff. I am totally bummed... While I await your reply, I'm going to try the other lights and see what they do. I'm assuming that I should be able to plug in one lamp at a time and test them that way...
Well, whatever I've done wrong, it seems fairly consistent, at least. Halos non functional - whether lights on or off. Brake center lights, functional. Could it be that I spliced into the wrong wire with that second diode? I went via your drawing, which was the lower of the two yellow wires I had. Maybe I should have spliced the other one. Maybe I'm sending ground to the red/orange wires that terminate to the resistors cluster.
I made the mistake of heat shrinking everything on the one that I finished, so for the sake of the photo, here is one that isn't finished yet, with the 2nd diode "resting" against where it would be soldered later.
To LED "halo" modification?
Old Apr 29, 2009 | 11:25 PM
  #338
backnblack2003z06
Do you have a volt meter? Plug the light in the harness. Take the black lead of the volt meter and connect it to ground, you can use the ground strap that is located in the rear bumper by the antenna. Use the red lead to probe the two yellow wires while someone hits the brake pedal, let me know what voltage is present at each yellow wire.
Old Apr 29, 2009 | 11:33 PM
  #339
JMc's Avatar
JMc
I've got a volt meter, but it's going to take me awhile to be able to do this. I'll see if I can con one of my kids into helping me.
Old Apr 29, 2009 | 11:46 PM
  #340
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
if you have a 12v power source, i reccomend grabbing a 3157 socket from your local auto parts store. This wil save you countless trips to the car and help you identify power adn ground wires in the comfort of your air-conditioned/heated home.
