LED "halo" modification?
Old Apr 23, 2009 | 11:27 PM
  #301
Coolface08's Avatar
Coolface08
I guess I'll be the one to say that I'd refrain from doing this. I mean, tinted tail lights is one thing, but blocking most of the tail light entirely seems to be like asking for a reason to be put in the wrong if someone rear-ends you.
Old Apr 23, 2009 | 11:36 PM
  #302
backnblack2003z06's Avatar
backnblack2003z06
Your not blocking any light when applying the brakes, all the leds will still function and light difference from static to brakes applied will be greater, I think you would have more of an issue with tinted tail lights espcially if they were still stock.
Old Apr 23, 2009 | 11:40 PM
  #303
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Solution: (this is on a blackout tail light)
Compare the standard halo mod to the LED strip (far right)
Old Apr 23, 2009 | 11:45 PM
  #304
jdmvette's Avatar
jdmvette
Night Owl for life
i think it's actually more benificial.
braking intention becomes much more obvious when going from just the halo to full brakes than a normal half lit tail to full brakes.
Old Apr 24, 2009 | 02:42 AM
  #305
JMc's Avatar
JMc
From: "This is not a psychotic episode, but a cleansing moment of clarity."
Originally Posted by backnblack2003z06
If anyone has added the diode to allow the halos to light up with the brake lights during the day (no parking lights on). I would love to have more info, a picture or diagram would be great, I plan on modifying mine this weekend and am fine with the regular modifying process but am having a little bit of a hard time wrapping my head around placement and orientation of the diode. Thanks in advance
Old Apr 26, 2009 | 04:12 PM
  #306
backnblack2003z06
Well I tried to add the diode and I am doing something wrong, but can't figure it out, the voltage is back feeding and lighting up the parking lights when I hit the brakes. This is the diode I used.
http://www.radioshack.com/product/in...ductId=2036268
I hooked up the anode end to the 12v+ feed from the stop/turnsignal wire and the cathode end is hooked to the orange and red wires going to the halos, I used a heatsink when soldering. Any ideas.
Old Apr 26, 2009 | 05:03 PM
  #307
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Isn't that what you were trying to do?
Old Apr 26, 2009 | 05:09 PM
  #308
backnblack2003z06
I should have been more specific, it's allowing the Halo to light up when I hit the brakes, what I wanted, but its back feeding to the front and side marker lights making them light up when I hit the brakes. The diode should stop that.
I'm trying to get the halo ring to light up with the brake and turn signals instead of just being on when the headlamps are on.
Old Apr 26, 2009 | 05:16 PM
  #309
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
you will need a second diode for the 12v input for the halo wire. This will stop back feeding.
Old Apr 26, 2009 | 05:28 PM
  #310
JMc's Avatar
JMc
Please post up some pics and/or a diagram when done. I'd very much like to spend an evening this week modding my halos on the kitchen table while the wife is out of town. I'm looking for harmless projects to keep me busy and out of trouble while she is away.
Old Apr 26, 2009 | 05:31 PM
  #311
backnblack2003z06
Yes, I see now, I think I got it.
Old Apr 26, 2009 | 06:33 PM
  #312
backnblack2003z06
I just added the second diode and it now works perfect, i just didn't see the extra path for current to backfeed, I will need to get some more diodes tomorrow, 8 will be needed in total, and post up some pictures of the diodes location for those that are interested. Thanks for all your help RadioFlyer.
Old Apr 26, 2009 | 06:40 PM
  #313
donsimpson12's Avatar
donsimpson12
Looks like the next mod to be added.. lol
Old Apr 26, 2009 | 09:20 PM
  #314
JMc's Avatar
JMc
Thank you both! I am interested!!
Old Apr 26, 2009 | 09:53 PM
  #315
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
well done....now post a vid of the results.
Old Apr 28, 2009 | 10:35 PM
  #316
backnblack2003z06
Just finished all four, I screwed up the first one I did and forgot to put in a resistor on one wire and for some reason put them on the grounds instead, the Halos was a little dimmer that the rest, hope I didn't damage anything. I am going to fix it right now. As for the diode placement I am going to reference the video made by xboxexpert earlier in the thread. Also I think this may make them likely to hyperflass so I would just get the bypass, If anyone has a link please post one up.
Diodes to use
There is a diagram on the back of the package to denote anode and cathode end so don't worry if your not sure about the terms.
Add one diode inline to white wire he has you mark with the black marker. The anode end should face the connector that plugs into the socket, the cathode end should face the tail lamp. The second diode will be used on the red wire directly next to the previously mentioned white wire (mark that red wire with a black marker, that is now the positive feed for the stop and turnsignals), you want to splice from that red wire to the LED positives ( the red and orange wires with the resistors) add a diode in line with the splice and have the anode end face the connector and the cathode end face the tail lamps.
Hope that helps, I'm not very good a explaining, but will answer any questions if you have them.
Old Apr 28, 2009 | 11:11 PM
  #317
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
well done.
To LED "halo" modification?
Old Apr 29, 2009 | 01:07 AM
  #318
JMc's Avatar
JMc
Ahhhh. Thank you. I see a visit to Radio Shack in my very near future... I may try this complete mod tomorrow evening.
Old Apr 29, 2009 | 12:59 PM
  #319
JMc's Avatar
JMc
I'm going to take the plunge and try modding my halos tonight with the new diode trick. The lack of complete lighting during daytime was the only thing holding me back from this mod. On my way to pick up the parts right now...
(later)
Got the parts and the halos apart. Any pics or drawings on the diode placement would be great, if possible. Thanks!
Old Apr 29, 2009 | 05:04 PM
  #320
JMc's Avatar
JMc
Are you talking about the short red wire in the middle of the same circuit board that the white wires were formerly attached? A clear photo or a modified diagram of the original drawings that Radioflyer posted would be greatly appreciated... I'm having just a wee bit of trouble visualizing exactly where those diodes fit in. Particularly the second one.
