"Jake" backup lights
Old May 11, 2008 | 10:46 AM
KCvetteowner's Avatar
KCvetteowner
Default "Jake" backup lights
I guess I had a little tooo much time on my hands
http://www.pbase.com/callaway/jake
Old May 11, 2008 | 10:47 AM
EPMM 03 C5's Avatar
EPMM 03 C5
very nice!!
eric
Old May 11, 2008 | 10:48 AM
MagRedConv's Avatar
MagRedConv
Quite a few people here are going to be all over this!
Old May 11, 2008 | 10:50 AM
DRKMATTER's Avatar
DRKMATTER
St. Jude Donor '09-'10
I'm not into the whole "Jake" thing but brother those lights look wicked cool!
Great Job!
Old May 11, 2008 | 10:52 AM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
great work!!
Old May 11, 2008 | 10:59 AM
NemesisC5's Avatar
NemesisC5
Great Job!
Old May 11, 2008 | 11:03 AM
bucwheat's Avatar
bucwheat
OK ,I give up ,how did you do it?
Old May 11, 2008 | 11:06 AM
dobewillie's Avatar
dobewillie
looks good
Old May 11, 2008 | 11:44 AM
jdmvette's Avatar
jdmvette
Night Owl for life
that's a very cool idea!
Old May 11, 2008 | 11:53 AM
Vetteguy2008's Avatar
Vetteguy2008
That looks nice but it would be nicer if it was C5 jake
Old May 11, 2008 | 12:02 PM
flaagan's Avatar
flaagan
CF "Young" Senior Member
St. Jude Donor '12
Looking at it, I'd fathom a guess that he either used a pair of jake skull stickers to mask off the lights and painted them with some Krylon, or that was a very clever use of leftover sticker material.
Old May 11, 2008 | 12:07 PM
KCvetteowner
Your right, and I don't know why I didn't think about it. Shouldn't take me but a few minutes to extend the black lines down on both sides to make it a C5 Jake.
Guys,
I simply downloaded the logo into photoshop and sized it properly, printed a few tests on paper and then printed it out on sticker paper. I then cut the sticker out and placed it on the backup lights. I lightly sanded with 1200 grit around the logo to help with the bonding and sprayed with semi-flat black paint.
UPDATE: I wouldn't recommend using paint in cans as it's difficult if not nearly impossible to clear. Talk with an Auto Paint store and at least get them to make you some cans with high quality paint.
About 6 coats and a few checks with a mini-mag light in the socket to check on the coverage. I haven't put a clear over it yet but plan to. I won't have the engine and rear end up into the car for a couple more weeks. Can't wait to see how they will look at night.
Last edited by KCvetteowner; May 14, 2008 at 02:31 PM. Reason: added comment about using paint in cans
Old May 11, 2008 | 12:09 PM
STL94LT1's Avatar
STL94LT1
OK, I'm in the dark here. What does "Jake" symbolize?
Old May 11, 2008 | 12:30 PM
KCvetteowner
I didn't know myself until about two weeks ago! This should help:
http://www.corvetteblog.com/archives...guna-seca.html
Old May 11, 2008 | 12:33 PM
STL94LT1's Avatar
STL94LT1
Thanks.
Old May 11, 2008 | 12:38 PM
02MillenniumVette's Avatar
02MillenniumVette
http://www.badboyvette.com/
Old May 11, 2008 | 01:30 PM
RJ1AZ's Avatar
RJ1AZ
From: PHOENIX, AZ Yes, it's true. You are a good woman. Then again, you may be the Antichrist.
Great Job!
Originally Posted by KCvetteowner
Guys,
I simply downloaded the logo into photoshop and sized it properly, printed a few tests on paper and then printed it out on sticker paper. I then cut the sticker out and placed it on the backup lights. I lightly sanded with 1200 grit around the logo to help with the bonding and sprayed with semi-flat black paint. About 6 coats and a few checks with a mini-mag light in the socket to check on the coverage. I haven't put a clear over it yet but plan to. I won't have the engine and rear end up into the car for a couple more weeks. Can't wait to see how they will look at night.
I'm wondering how it would look if the lens were painted on the inside instead of the outside? No worries about scratching the paint that way...but the inside surface would have to be smooth for the stencil to stick to it.
To "Jake" backup lights
Old May 11, 2008 | 02:00 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Old May 11, 2008 | 02:04 PM
C5R USA's Avatar
C5R USA
From: Ideals are peaceful...History is violent...St.Charles, MO.
C5 of Year Winner (appearance mods) 2019
St. Jude Donor '08-'09-'12 thru'22
nice work
Old May 11, 2008 | 02:08 PM
Hams's Avatar
Hams
Cruise-In VII Veteran
I like.Hams
