Side Vent Lights w/Turn Signal Functionality
Old Apr 29, 2009 | 01:58 AM
  #61
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Wig Wag side vent lights... now that's a new one!!! Nice subtle glow too, what did you use neons?
Tim
Old Apr 29, 2009 | 07:24 AM
  #62
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
Tim
Nope I got the lights at autozone....they were called "LED fog lights" lol.
Old Apr 29, 2009 | 04:09 PM
  #63
nascar57's Avatar
nascar57
Originally Posted by Eric D
Hi Tim,
Mine has blue. They are 15 deg units that project a longer narrow amount of light so it doesn't show as much as the yellow and red that are 30 deg units. I guess I'll have to just give it a try and see if someone get upset over them. I have them on their own switdh so they can be turned on or off at will.
Thanks for your input!
Instead of wiring a switch and going through the firewall with the wiring you could wire them to a remote controll box. I do that on my kits and it works very well. Easy to wire and only a remote controll fob on your keychain. Oznium has raised their prices on them so I get mine from autolumination. You can also get the kits here!
http://www.shop.jwmotoring.com/produ...4&productId=28
Old Apr 29, 2009 | 04:34 PM
  #64
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
nascar57,
Thanks for the link, I'll check it out.
The foot well lights look pretty nice. I might have to work on that next!!
Old Apr 29, 2009 | 04:38 PM
  #65
nascar57's Avatar
nascar57
The pictures are a little over exposed but I have found nothing that works better!
Old May 14, 2010 | 06:14 PM
  #66
nascar57's Avatar
nascar57
jw now has the cove kits with a 4 function remote. Amazing results and easy to wire. Heres a link to the video.
http://www.youtube.com/watch?v=iJyUGyqHc2A
Old May 27, 2010 | 06:04 PM
  #67
rpm462's Avatar
rpm462
I've got the cove kit from JW Motoring and like that so much that I think I'll give Tim's mod a try and get the stuff from Oznuim and hook another set to the turn signals/DRL's via the DRL & fog light relays . We'll see what happens!
Old May 27, 2010 | 06:49 PM
  #68
tstar's Avatar
tstar
If you have any questions, just give me a shout!
Tim
Old May 27, 2010 | 07:52 PM
  #69
rpm462's Avatar
rpm462
Tim
Thanks Tim
Old Apr 24, 2011 | 03:06 PM
  #70
petedog2.0's Avatar
petedog2.0
I am definitely doing this, couple questions though, Which wires did you tap into to make them work as turn signals ONLY? (colors please) and if you use a DPDT relay and added a switch would that make them turn on and stay on? if not, how could you accomplish that? what I'm looking for is to use them as turn signals but have the option of flipping a switch and having them stay on for nighttime coolness, I already did the LED vanity plate mod and love it, was considering, tapping into rear signals and running a wire to the coves so I'm sure they only worked as signals and avoid the DRL issue. Thanks and love what you do, it gives me mod fever!
Old Apr 24, 2011 | 10:04 PM
  #71
VetteBoy1979's Avatar
VetteBoy1979
CI 3-4-8 Veteran
St. Jude Donor '07-'09-'12
Wow, that's lame. I think I would just pull the power wire...
Old Apr 24, 2011 | 10:27 PM
  #72
petedog2.0's Avatar
petedog2.0
was that "lame" comment really necessary? I was asking for advice, if you can't say something nice then at least say something clever, but thanks for taking the time to answer, I know your time is valuable.
Old Apr 25, 2011 | 01:44 AM
  #73
DeeGee's Avatar
DeeGee
Originally Posted by mtndv8
More orange than amber, I think but I like this LED strip location with the Race Mesh.
I'm thinking of leaving it off and flashing with the blinkers only, anybody else done it that way?
We have to fit amber turn signal repeaters in UK to pass the safety compliance yest on importaing the car.
I fitted mine on the front fenders
If I'd known that the inspectors would accept the gill solution I'd have gone this way. One UK owner modified his using a standard lamp unit:
Old Apr 25, 2011 | 01:53 AM
  #74
DeeGee's Avatar
DeeGee
I'm not sure thats possible and I spent a while looking at wiring diagrams before I modified mine.
Can't answer the relay question as I have never played around with that idea.
The problem is unless you inhibit the DRLs they always feed the turn signal circuit. You have a dual filament bulb on the T/S. There are 3 wires; a common ground, a brown hot for parking lights and a blue/white hot for turn signals.
At the back to get the turn signals to operate independently you have to snip a white wire under the dash. Unless you do that any light wired into the turn signal circuit would come on when you hit the brakes as well as the turn signal switch.
I think, but I could be wrong, to get what you want you'd have to inhibit the DRLs (easiest to pull A2 in the engine fuse box). If you did that then just splice a parallel circuit into the blue/white and the black close to each turn signal lampholder. That gets you them working as turn signals. To get a permanent light which comes on only when the lights are on you'd need to tap an additional wire with an inline switch into the parking light circuit. I used the hot wire to the small parking light in the front lamp cluster but my parking lights are mounted in my headlights.
Old Jul 7, 2011 | 01:18 PM
  #75
Silverado2011's Avatar
Silverado2011
6th Gear
Tim
removed non-supporting vendor link
Old Jul 7, 2011 | 04:00 PM
  #76
MUGILLA's Avatar
MUGILLA
I also purchased the cove light kit from Jonathan @ JW MOTORING and could'nt be happier with the finished results. Great products from a great vendor!!
Old Jul 7, 2011 | 04:01 PM
  #77
MUGILLA's Avatar
MUGILLA
To Side Vent Lights w/Turn Signal Functionality
Old Jul 7, 2011 | 05:22 PM
  #78
nascar57's Avatar
nascar57
JW and I both thank you for your business!! The 4 function remote is our best seller for use in the kits. Really gets you noticed after dark!
Old Apr 20, 2015 | 10:39 PM
  #79
raiderz's Avatar
raiderz
Here's the actual layout of the Gill light wiring;
Tim
I know this is an older thread but its something i would like to do.
Could someone explain the process for tapping into the factory relays 38,39,40.
Old Apr 20, 2015 | 10:53 PM
  #80
nascar57's Avatar
nascar57
Those relays are in the passenger side footwell fuse box. Remove the relays, flatten the end of the wires, tin the ends if you wish. Slide the end of the wires into the cavity as per the diagram and re-install the relay so it keeps the wires in place.
