Shifting
Old Sep 15, 2008 | 01:36 PM
Oldvetter's Avatar
Oldvetter
You should replace your MN6 transmission fluid every 50,000 miles.
1997-2000 C5s use paper blocker rings. Not all synthetic fluids are compatable. Mobil 1 is NOT, my 1998 C5 started grinding when going into 6th gear after 50,000 miles with Mobil 1 ATF in it. I changed to Amsoil ATD and it stopped immediately.
Old Sep 15, 2008 | 07:48 PM
lionelhutz's Avatar
lionelhutz
The reverse lockout might have stuck or been energized that one time for some reason.
Typically though, reverse is gated off unless the car energizes the solenoid and opens the gate. You can check it with the car off. It should not want to go to reverse but you can force it with some pressure. That's on purpose so you can still back up if the solenoid fails.
Peter
Old Sep 16, 2008 | 12:37 AM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Originally Posted by BigYellaJeep
Great info...and of COURSE I had to randomly get a 2000 instead of one year newer....but at least my millennium yellow is authentic,
FYI, the fluid Old Vetter mentioned above has been used by many forum members in their 97 to 00 Corvettes and I haven't heard of any problems with the paper blocker rings.
AMSOIL Torque-Drive Synthetic Transmission Fluid
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
