Battery Disconnect???
Old Sep 14, 2008 | 11:09 PM
CO YGOSLOW's Avatar
CO YGOSLOW
Default Battery Disconnect???
I will be changing out my stock intake for a dual cone system. MAM and other instructions mention disconnecting the neg battery terminal (due to the MAF sensor). Is it necessary? If so, what memory settings do I lose?
Old Sep 14, 2008 | 11:22 PM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
clock will have to be reset and fobs will have to be resynchronized
Old Sep 15, 2008 | 01:24 AM
DeeGee's Avatar
DeeGee
If you have a stock radio with security activated you'll need the code to unlock it. In addition to the clock you may lose the memory settings. I've done it many times and never lost the fob synch
https://www.corvetteforum.com/techti...=164&TopicID=1
Old Sep 15, 2008 | 09:01 AM
CO YGOSLOW's Avatar
CO YGOSLOW
Is it really required when changing out your intake?
Old Sep 15, 2008 | 09:07 AM
10U 99's Avatar
10U 99
any time major components are being replaced under the hood it's a good idea to isolate the battery. you never know when an errant tool might make contact with a energized connection. an ounce of prevention........
Old Sep 15, 2008 | 10:47 AM
I never disconnected my battery when working on the air intake, but it certainly won't hurt anything. Just be prepared to reset things like the clock and maybe the radio if you do.
Old Sep 15, 2008 | 11:01 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Peace
Chip
__________________
..................Click for
Old Sep 15, 2008 | 12:50 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Originally Posted by Willfulone
Peace
Chip
Good idea always for any type work---especially when doing exhaust work that requires welding--The 02 sensors often take a spike--I can't tell you how many cars & trucks i've tuned that had exhaust work done and the Computer got stuck in "open loop fault" mode--
To Battery Disconnect???
