need intake recommendation!!!!!!
Old Dec 8, 2008 | 07:29 PM
  #41
ncevette's Avatar
ncevette
Originally Posted by Savior1974
Just save yourself the money and go with the ziptie mod. I made 385rwhp/368rwtq with that and a tune only.
are you serious?how did u do it?any pics?
Old Dec 8, 2008 | 07:49 PM
  #42
jtkeller's Avatar
jtkeller
St. Jude Donor '07
Originally Posted by 5W0P3
Here's a Callaway Honker for $350 shipped...http://forums.corvetteforum.com/c5-p...nd-shroud.html
Good seller too!
thanks Jeff - I like the Honker too - just couldn't get it to work with my new 103mm maf. I can't say enough about the stock like fit and quality components.
someone buy mine!
Old Dec 8, 2008 | 10:43 PM
  #43
dndrsn's Avatar
dndrsn
True Cold air, cheap, looks stock, works.
Click on the link.
"FLIP-TIE"
Old Dec 8, 2008 | 10:51 PM
  #44
C5XTASY's Avatar
C5XTASY
How is the Honker much different, other than changing the MAF location, from the Vortex. The concept seems exactly the same. The only issue I have, with either, is that one would think intake air, on both, would pick up radiator heat. Can anyone explain?
Ed
Old Dec 9, 2008 | 05:40 AM
  #45
dixonk's Avatar
dixonk
St. Jude Donor '09
Well I think the air blowing in would hit the air filter and cancel out the radiator heat.
Old Dec 9, 2008 | 07:54 AM
  #46
Chevy-SS's Avatar
Chevy-SS
Click on the link.
"FLIP-TIE"
I gotta admit, that looks factory stock and it's exact same principle as Callaway and all the others. Why isn't everyone just doing this? I mean, you still need to cut the shroud with most of the aftermarket CAI's.......
Old Dec 9, 2008 | 08:05 AM
  #47
Dominic Toretto's Avatar
Dominic Toretto
Originally Posted by ncevette
is it true you have to get a tune after vararam?
You don't HAVE to, but to realize the added power with them, it is a good idea.
Check his sig. He threw in an LS6 also.
-Alex
Old Dec 9, 2008 | 09:01 AM
  #48
C5XTASY's Avatar
C5XTASY
Sounds like a friendly dyno to me.
Ed
Old Dec 9, 2008 | 09:17 AM
  #49
C5XTASY's Avatar
C5XTASY
To my way of thinking, there are two advantages to a properly designed CAI. Number one would be keeping intake air at near ambient when stopped in order to keep timing from dialing back, while also allowing a very rapid cooldown to ambient once the car started to roll. Number two would be providing ambient air temperature at a pressure greater than a stock intake while moving. I know the Honkler, and Vortex, are good intakes, but I have a difficult time understanding how radiator heat wouldn't affect the intake air temperature while stopped.
Not bashing anything here, just questioning.
Ed
Old Dec 9, 2008 | 09:31 AM
  #50
Dominic Toretto
Ed
The thing is you will never completely eliminate engine bay/radiator temps just due to how the car is designed to function. The trick is to get the one that yields the best results as possible. As long as the intake manifold, hood, chassis design etc etc all limit space, heat flow etc then you will never have any intake that will completely be void of ambient engine temps.
-Alex
Old Dec 9, 2008 | 10:10 AM
  #51
Dave68's Avatar
Dave68
According to my CAR Chip data logger results, while it is true that temps rise while sitting in traffic, the ramp-down of (intake air) temps after you begin moving is very, very rapid. My CAI mod helps in this regard by funneling the air at the intake filter via a polycarbonate scoop. The Flip-Tie mod doesn't have a scoop and won't allow any of that cold air to cool down the engine bay, which tends to get very hot during slo-moving conditions. As I mentioned previously, rubber and plastic parts, as well as electronics tend to die an early death when exposed to very high temps.
Old Dec 9, 2008 | 10:14 AM
  #52
Chevy-SS's Avatar
Chevy-SS
Originally Posted by Dave68
...... The Flip-Tie mod doesn't have a scoop and won't allow any of that cold air to cool down the engine bay, which tends to get very hot during slo-moving conditions. .....
The Flip-Tie mod works almost exactly the same as the Callaway Honker. You gotta cut the shroud. There's no "scoop" on either one. So there's really no difference as far as cold air to cool down engine. The Flip-Tie mod is not hindering cooling air to engine in any way, as far as I can tell...............
Old Dec 9, 2008 | 10:20 AM
  #53
Chemdawg99's Avatar
Chemdawg99
St. Jude Donor '12 thru '21
IMHO, unless you are installing a new intake as a first-step bridge to bigger mods (LT headers,supercharger,H/C swap) you really won't see any larger gains between intakes that you would spend big $$$$ on and a Z06 air box lid.
Believe it or not, a stock engine pretty much gets all the air it needs with a stock airbox. If you modify the intake without modifying the exhaust, you are wasting time and money....
Old Dec 9, 2008 | 10:49 AM
  #54
Dominic Toretto
From plenty of dyno results I have seen on many different types of cars the between the exhaust and an intake the yields are far greater with an intake then an exhaust. However if you are talking about headers back, then that is completely different. But generally when people say "exhaust" it just means a catback so not really sure which you are referencing.
-Alex
Old Dec 9, 2008 | 11:12 AM
  #55
Remo's Avatar
Remo
Default Donaldson Blackwing
I really don't have a strong opinion on the subject. They're probably all pretty good. When I sent mine to Lingenfelter a few years ago the Blackwing was what they recommended. So I went with it.
Remo
Old Dec 9, 2008 | 11:34 AM
  #56
Milan's Avatar
Milan
Wow, did you really just say install and intake on a supercharger?
An intake is not a waste, people improve their ET and MPH at the 1/4 significantly with the Vararam. I personally improved .2 off my ET and +1 MPH over a Halltech Venom, everything else was the same (outside temp, 60', etc.)
Old Dec 9, 2008 | 12:02 PM
  #57
Chemdawg99's Avatar
Chemdawg99
-Alex
I'm referencing headers back. A catback does nothing for HP....
To need intake recommendation!!!!!!
  #58
Dave68's Avatar
Dave68
If the filter were facing the airstream, directly, there would most certainly be a benefit during slow-moving conditions, especially when the radiator is generating local heat that is in close proximity to the intake filter. By strategically adding an air "scoop", air is directed at the filter at close range. Take a look at rear-engine racers that have a "scoop" on top. There isn't just an opening facing the sky; the scoop directs air to the intake filter with a ramming effect. This is what my scoop does, only instead of just ramming air at the filter, it also blasts cold air into the engine bay, cooling components that tend to break down with excessive heat over time.
Old Dec 9, 2008 | 12:04 PM
  #59
Dave68's Avatar
Dave68
From what I've seen, changing from a coupe/vert airbox lid to a 2002-2004 Z06 lid will produce gains of 3-5 RWHP. However, an aftermarket intake system will easily get you 10+ RWHP.
Old Dec 9, 2008 | 12:05 PM
  #60
Chemdawg99's Avatar
Chemdawg99
No, I didn't say that.
