Battery question
Old Jan 1, 2009 | 04:35 PM
HG's Avatar
HG
Default Battery question
New to C5's so I hope this won't be too stupid. Since it's too cold to play with the car, I was reading some of the tech tips and the very first one is about battery leakage. I states the bottom of the battery tray is open in the center. Just as a precaution, would it be dumb to just cover the hole with something. I'm going to replace the battery in the spring.. When I disconnect the battery , other than the radio stations, will I loose any other settings.
Old Jan 1, 2009 | 04:39 PM
DeeGee's Avatar
DeeGee
If your 99 has an OEM battery replace it as a precaution. the old AC Delcos were prone to leaks. If its a replacement dont worry as the later batteries were fine. An absorbent mat under the battery may be a good precaution for any battery though.
Here's all I know about batteries:
http://forums.corvetteforum.com/show...Battery+Thread
Old Jan 1, 2009 | 04:52 PM
HG's Avatar
HG
Thanks, great post about batteries. Love the shot of your car at the famous Las Vegas sign. Been there many times. It must have been a very long ride from England.
Old Jan 1, 2009 | 07:57 PM
Dave68's Avatar
Dave68
The last "leaker" battery sold was in 2000, so assuming that you don't have a 9 year old battery in your car, your electronic components are very safe. I would pass on the acid mat, as it won't allow the battery to slip in under the hold-down wedge. This is another reason why the replacement battery I bought is a 7 YR AC Delco Professional. It has the required features to fit under the wedge and the hold down clamp, perfectly. Besides, it has the best free-replacement warranty in the world at 50 months.
When I replaced my OEM battery, only the stations had to be reset. All other memories were retained.
Old Jan 1, 2009 | 08:30 PM
rws.1's Avatar
rws.1
The primary reason that side terminal batteries leak is that gorillas install them.
The torque spec for the side terminals is 12 ft-lbs....
When a Gorilla torques them to 30+ you break the bond between the metal insert and the plastic side wall and then they LEAK.
Old Jan 1, 2009 | 09:32 PM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
hince the 5/16 hex on the battery bolt. but that doesn't stop motorist from using a 18" pipe wrench. I've seen too many teeth marks on the bolts........ and the battery gets the blame
To Battery question
