cd changer how to????
Old Jan 19, 2009 | 01:29 AM
soada101's Avatar
soada101
Default cd changer how to????
03 vette 50th ed. i JUST got this bad boy and i have the 12 disk changer in it and i was wondering how i work it....... there is no remote..... supposed to have one? just wondering how to work it thanks!!!!!!!!
Old Jan 19, 2009 | 01:37 AM
DeeGee's Avatar
DeeGee
Trunk-Mounted CD Changer (Option)
If your vehicle has the optional trunk-mounted
CD changer it is located in the rear center storage
compartment. See “Rear Storage Compartments” in
the Index for more information.
With the trunk-mounted CD changer you can play up to
12 discs continuously. Normal size discs may be played
using the trays supplied in the magazine. The small discs
(8 cm) can be played only with specially designed trays.
NOTICE:
Heavy objects in the center storage area which
may shift or slide while driving could damage
your CD changer. Protect your CD changer by
not placing heavy, moveable objects in the center
storage area.
You must first load the magazine with discs before you
can play a compact disc. Each of the 12 trays holds one
disc. Press the button on the back of the magazine and
pull gently on one of the trays. Load the trays from
bottom to top, placing a disc on the tray label side down.
If you load a disc label side up, the disc will not play
and an error will occur. Gently push the tray back into
the magazine slot. Repeat this procedure for loading up
to 12 discs in the magazine.
3-25
Once you have loaded the discs in the magazine,
slide open the door of the compact disc (CD) changer.
Push the magazine into the changer in the direction
of the arrow marked on top of the magazine.
Close the door by sliding it all the way to the left. If the
door is left partially open, the changer will not operate
and an error will occur. When the door is closed, the
changer will begin checking for discs in the magazine.
This will continue for up to two minutes depending on
the number of discs loaded.
3-26
To eject the magazine from the player, slide the CD
changer door all the way open. The magazine will
automatically eject. Remember to keep the door closed
whenever possible to keep dirt and dust from getting
inside the changer.
Whenever a CD magazine with discs is loaded in the
changer, the compact disc symbol will appear on the
radio display. If the CD changer is checking the magazine
for CDs, the compact disc symbol will flash on the
display until the changer is ready to play. When a CD
begins playing, CD will appear in the bottom left corner
and a disc and track number will be displayed. The disc
numbers are listed on the front of the magazine.
All of the CD functions are controlled by the radio
pushbuttons except for ejecting the magazine.
Operating the Trunk-Mounted CD Changer with
the AM-FM Stereo with Cassette Tape Player and
Automatic Tone Control
If an error appears on the display, see “Compact Disc
Messages” later in this section.
The following pushbuttons are used for the
trunk-mounted CD changer.
1 PREV (Previous): Press this pushbutton to go to
the previous track if the current track has been playing
for less than eight seconds. If this pushbutton is pressed
and the current track has been playing for more than
eight seconds, it will go to the beginning of the current
track. If you hold or press this pushbutton more than
once, the player will continue moving back through the
disc. The sound will mute while seeking.
2 PROG (Program): Press this pushbutton to select
the next disc in the magazine. If a CD cannot be played,
its number will be skipped when selecting discs while
using this pushbutton.
3-27
3 NEXT: Press this pushbutton to advance to the next
track. If you press and hold this pushbutton or press it
more than once, the player will continue moving forward
through the disc. The sound will mute while seeking.
REV 4 (Reverse): Press and hold this pushbutton to
quickly reverse within a track. Release this pushbutton
to resume play.
 5 (Dolby): This pushbutton has no function when
playing a CD.
FWD 6 (Forward): Press and hold this pushbutton to
quickly advance within a track. Release this pushbutton
to resume play.
RECALL: Press this button to see what track is
currently playing. Press it again within five seconds to
see how long the track has been playing. When a new
track starts to play, the track number will also appear.
Press it a third time and the time of day will be displayed.
SEEK : The left arrow works the same as the
PREV pushbutton and the right arrow works the same
as the NEXT pushbutton.
P.SCAN (Preset Scan): Press this button to play the
compact discs in random, rather than sequential order.
RDM will appear on the display. Press this button again
to turn off random play.
AM/FM: Press this button to listen to the radio when
playing a cassette tape or a compact disc.
Tape AUX (Auxiliary): Press this button to play a
CD when listening to the radio. You can also press this
button to switch between playing a tape in the cassette
tape player and playing a CD in the trunk-mounted
CD changer, if both are loaded.
3-28
the AM-FM Stereo with Compact Disc Player and
2 RDM (Random): Press this pushbutton to play the
RDM will appear on the display. Press this pushbutton
again to turn off random play.
to resume play.
5: Press this pushbutton to select the next disc in the
magazine. If a CD cannot be played, its number will be
skipped when selecting discs while using this pushbutton.
to resume play.
playing a compact disc.
CD AUX (Auxiliary): Press this button to play a CD
button to switch between playing a CD in the compact
disc player and playing a CD in the trunk-mounted CD
3-29
Compact Disc Messages
If an error occurs while trying to play a CD in the
compact disc player or changer, the following conditions
may have caused the error:
 The road is too rough. The disc should play when
the road is smoother.
 The disc is dirty, scratched, wet or loaded label
side up.
 The air is very humid. If so, wait about an hour
and try again.
 The CD changer door is open. Completely close
the changer door to restore normal operation.
 An empty magazine is in the CD changer.
Try the magazine again with a disc loaded on
one of the trays.
 If the CD is not playing correctly, for any other
reason, try a known good CD.
If any error occurs repeatedly or if an error can’t be
corrected, contact your dealer. If your radio displays
an error message, write it down and provide it to your
dealer when reporting the problem.
Old Jan 19, 2009 | 01:41 AM
bencini231's Avatar
bencini231
Old Jan 19, 2009 | 01:42 AM
paullywalnuts's Avatar
paullywalnuts
Couldn't have said it better if I tried!
Old Jan 19, 2009 | 02:00 AM
soada101's Avatar
soada101
Default awsome!
alright!!! thats a awesome reply!!! thanks again have to try it tom! thanks a million!
Old Jan 20, 2009 | 03:58 AM
soada101's Avatar
soada101
ok cd player doesnt play burned cds in dash or disk changer. is this just normal?? guess im gonna have to buy a new deck!
Old Jan 20, 2009 | 11:26 AM
hotwheels57's Avatar
hotwheels57
It might depend on the CDs you're using...I can use reburned in my Z16 w/o any problem (TDK). It has the x12 changer.
I sometimes can use them in our Silverado, but one may cause an issue periodically. It has the x6 in the dash.
Our Trailblazer uses them w/o any problems. It has the x6 in the dash.
Old Jan 20, 2009 | 11:44 AM
4 KRUSIN's Avatar
4 KRUSIN
Save your money and buy an I-Pod. There are lots of threads on how to connect one.
Old Jan 20, 2009 | 12:09 PM
soada101's Avatar
soada101
yeah i have one but i wanted to add the connector but i dont want to deal with the battery drain!
Old Jan 20, 2009 | 12:18 PM
08 ATOMIC-Z's Avatar
08 ATOMIC-Z
Hook it up correctly and you don't have that problem.
Old Jan 20, 2009 | 12:55 PM
soada101's Avatar
soada101
can some one post a forum that that know of on here of how to install it "correctly" and what it is called to hook it it up to them oem radio! thanks all
To cd changer how to????
