A/C light blinks?
Old Mar 16, 2009 | 06:33 PM
BHZ28's Avatar
BHZ28
Default A/C light blinks?
When I try to turn on the A/C in the vette all that happens is the line light blinks a few times, goes back off, and the A/C never comes on. Anyone know whats up?
Old Mar 16, 2009 | 06:49 PM
dougbfresh's Avatar
dougbfresh
What temp and mode do you have it set on?
Old Mar 17, 2009 | 05:24 PM
BHZ28's Avatar
BHZ28
I turned the temp all the way down and it never came on. Mode?....I the main vents I guess lol
Old Mar 17, 2009 | 05:45 PM
poolboy's Avatar
poolboy
I think there are a few reasons why it could do that. Check the owners manual first as I don't think all of the reasons mean problems. I think that it could do this if the system is not fully charged though - I am not sure if this condition would throw a code, but you may want to check for codes too...
Old Mar 17, 2009 | 06:23 PM
Jet-Jock's Avatar
Jet-Jock
Pull the codes, if your not familiar ask we can post procedures.
Was the AC very cold when operating before? My guess is it may not have been super cold and the system is probably low on 135A. I'm just guessing, we need the codes.
Old Mar 17, 2009 | 07:51 PM
Srt03's Avatar
Srt03
I may be waaaaay off here but mine has done that as well. How cold was it outside when you tried to turn the ac on? I remember trying to turn mine on when it was like 20 degrees outside and it would let me (I also have the dual zone climate control) But when it is warmer it lets me. Go figure.
Old Mar 17, 2009 | 08:20 PM
RonJ's Avatar
RonJ
Wthout looking in the manual, I think Srt03 has it right. If it's too cold for the A/C to be used, I think the light will flash.
RonJ ...
Old Mar 17, 2009 | 08:33 PM
jj_adams319's Avatar
jj_adams319
any codes?
i had a similar prob when i forgot to reinstall the vacuum hose on the back of the intake manifold causing a vacuum leak. Mine would blink then stay on, but not blow.
Old Mar 17, 2009 | 08:38 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Mine will do that if the temp outside is cold, If you read the owners manual it is in there.
A/C (Air Conditioning):
This button turns
the air conditioning compressor off or on under most
conditions. The light on the A/C button will come on
when the compressor is operating in either the automatic
or manual mode. The air conditioning does not operate
at temperatures below approximately 35F to 40F
(2C to 4C). The light on the A/C button will flash if
pressed when air conditioning is not available. The air
conditioning cools and dehumidifies the air coming into
the vehicle. The air conditioning cannot be turned off in
defrost and defog, as it helps to remove moisture from
the vehicle. It also helps to keep the windows clear.
Old Mar 17, 2009 | 09:47 PM
Kens86's Avatar
Kens86
Avatar says Eglin AFB. Don't think its that cold. Could be low on freon check for ac codes
Old Mar 18, 2009 | 01:32 AM
DeeGee's Avatar
DeeGee
What reading do you have on the outside air temperature display. Is the sensor giving a false reading making the AC think the temp is <35 degrees?
Old Mar 20, 2009 | 08:39 PM
BHZ28's Avatar
BHZ28
I don't remember but I think the temp was wrong. I will have to check and I will check to see if the system is charged or not.
No it isn't very cold here, lol
Old Mar 20, 2009 | 10:26 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
Here is your answer.
If you try to turn the AC on but the FAN SPEED is not on at least the 1st setting it blinks and then turns off.
It took me about 10 times in my Hummer to have this happen before I figured it out.
In other words, I was turning on the AC, but the fan speed was OFF, it would blink and then go off.
Old Mar 21, 2009 | 10:22 AM
BHZ28's Avatar
BHZ28
I'll try that thanks.
Old Mar 22, 2009 | 01:20 PM
Gene Culley
Let us know how you make out.
Old Mar 23, 2009 | 07:13 PM
BHZ28's Avatar
BHZ28
I think the system needs to be recharged
Old Mar 25, 2009 | 08:08 PM
Gene Culley
If the light is blinking and the fan speed is set to at least 1 then it sounds as if maybe the head unit is faulty.
To A/C light blinks?
