brake pulsation
Old Mar 31, 2009 | 08:12 PM
paldogy's Avatar
paldogy
Default brake pulsation
brakes are pulsating when slowing at lower speeds . 04 Convert has 40,000 miles, no hard braking. The dealer said about a month ago the pads were going to need replacing in a few months. I have had bad luck with turning rotors on other cars as they pulsate in a few weeks due to being thin, I think. Could it be just the pads? The rotors look smooth with no burnt spots or oil. Should I replace the rotors if needed rather than turning them?
Old Mar 31, 2009 | 08:17 PM
vette dan's Avatar
vette dan
Vette Dan
Just get rotors turned. While they have rotors off see if you can rough up pads.
Old Mar 31, 2009 | 08:18 PM
Chevy-SS's Avatar
Chevy-SS
I've had this problem on MANY vehicles. It was solved every single time with new rotors. Sometimes I tried turning the rotors, and that worked for a little while. But the problem seemed to quickly re-appear. So, I would recommend you buy new rotors.
Just my $.02, of course...................
Old Mar 31, 2009 | 08:19 PM
Black04Z06's Avatar
Black04Z06
I had a similar issue a few years ago. I changed out the rotors and pads which solved my issue. Napa wouldn't turn my rotors due to the tolerances being exceeded.
Old Mar 31, 2009 | 10:01 PM
Dave68's Avatar
Dave68
Here's my story and permanent solution to this very issue......
http://forums.corvetteforum.com/c5-g...ulsations.html
Old Apr 1, 2009 | 01:36 AM
DeeGee's Avatar
DeeGee
Not had the problem on the Vette but new rotors fixed the same issue on my son's Camaro. I had tham skimmed for a start but it took new rotors to finally fix it.
Old Apr 1, 2009 | 05:09 AM
paldogy's Avatar
paldogy
Thanks for all the information guys, especially Dave for that great post.
Old Apr 1, 2009 | 08:12 AM
J S Machine's Avatar
J S Machine
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17
St. Jude Knife Maker
Turning rotors does nothing but buy time, and it is only a cheaper solution to doing the correct thing which is buying new rotors.
When you turn a rotor, you remove metal and thickness. Less metal thickness to absorb and disapate heat = quicker warping.
I had this problem on my '95 full size chevy truck. I went from driving an S10 which doesn't weigh nearly as much, to driving the full size truck. When I would try to stop, it took alot longer and alot more pedal pressure to get it to stop like my little truck. After going through brakes and rotors about every 5 months while daily driving it I see that the issue was the weight of the truck. All the hard braking and the brakes trying to stop what was basicly a train ruined my rotors. I had them turned once or twice, but I don't even bother now. Just buy new ones. That is your best bet. While you are there you might as well stick on new pads.
Old Apr 1, 2009 | 10:05 AM
Black04Z06's Avatar
Black04Z06
Here's a pretty good article on brake pulsing.
http://www.stoptech.com/tech_info/wp...rakedisk.shtml
Old Apr 1, 2009 | 10:44 AM
Vega$Vette's Avatar
Vega$Vette
Pulsating is most often caused by pad build up on the rotors. It is very rare that a rotor is actually warped.
Most often "warped rotors" are a statement brakes shops use to get you to buy new rotors.
If a shop tells you they are warped make him put a dial indicator on it and show you. Or just pull your caliper off and rig up a simple bracket to hold the indicator and turn the rotor on the spindle to see if it has any run out.
Drilled under everyday street use are perfectly OK if you are not hard on you brakes. Not recommended for track cars.
Myself and lots of other Forum Members have used have used DS rotors for years with no cracking or other problems.
Old Apr 1, 2009 | 02:59 PM
RonJ's Avatar
RonJ
I'd suggest trying to "clean" the rotors off by doing some real hard braking. Same procedure as seating in new pads. If the rotors do have material built up on them, the hard braking may get rid of it and give you a smoother stop. When you do get them good and hot, don't hold the brakes on when you've come to a stop. Let the rotors cool off by driving for a few miles without using your brakes.
Doesn't cost anything to try it!
RonJ ...
Old Apr 1, 2009 | 04:10 PM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
I have to strongly disagree. I owned and operated an auto repair and parts store for 15 years and personally turned 1000s of rotors and they do indeed warp.
Old Apr 1, 2009 | 04:17 PM
De_Vette's Avatar
De_Vette
St. Jude Donor '09-'10-'11-'12
I read this and other similar articles before and agree this is the often the case for "warped rotors"
Old Apr 1, 2009 | 07:02 PM
RonJ's Avatar
RonJ
An excellent article from StopTech!
RonJ ...
Old Apr 1, 2009 | 07:14 PM
dobewillie's Avatar
dobewillie
new rotors are probably in your future
Old Apr 1, 2009 | 07:23 PM
TEXHAWK0's Avatar
TEXHAWK0
If you never brake hard, it could be build up.
Our Impala brakes started pulsing, and on a weekend trip I had to apply the brakes hard at highway speed to avoid a merging car. Brakes smoothed out.
On another GM car though, I had the rotors turned and the problem came back. I bought new Wagner rotors and the problem never returned.
Old Apr 1, 2009 | 07:33 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Warped rotors. Now you have an excuse to buy those drilled and slotted ones (if you like those).
Old Apr 1, 2009 | 11:07 PM
Dave68's Avatar
Dave68
He was referring to C5 factory rotors and uneven pad deposits on them IS a common problem. I experienced this when my rotors had only 6000 miles on them and I can assure you that they were NOT warped in any way, shape, or form. The stock pads are exceptionally good but when combined with blank rotors, uneven pad deposits are very likely.
The "bedding in" procedure may work, but it is far easier to get a set of slotted rotors and be done with it - no painstaking bedding procedure, no periodic slamming of the brakes, and NO pulsations from uneven deposits - EVER. It's an easy fix.
To brake pulsation
