Side Cove Improvement
Old Apr 3, 2009 | 07:30 PM
ALLEGRO's Avatar
ALLEGRO
Default Side Cove Improvement
After seeing tnarg's post I decided to give it a try. After a bit of modification, I think that it came out pretty nice. Also, here's a pic of some screw-head covers I did a while back but was too lazy to take and post a pic.
Opinions?
Old Apr 3, 2009 | 07:33 PM
Oh 2 Fun's Avatar
Oh 2 Fun
St. Jude Donor '09, '13, '15
That really does give it a more "finished" look.....nice....
Now....about those BSM's....
Old Apr 3, 2009 | 07:36 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Looks good
Old Apr 3, 2009 | 07:38 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
I thought the same things... in that same order
Old Apr 3, 2009 | 07:48 PM
csexton's Avatar
csexton
Nice mod
Chuck
Old Apr 3, 2009 | 09:00 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Nice touch
Old Apr 3, 2009 | 09:04 PM
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
What did you use for the trim? Interesting....
Old Apr 3, 2009 | 09:19 PM
bucwheat's Avatar
bucwheat
Me likey!
Old Apr 3, 2009 | 10:08 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
I think that side cove trim would look even better with some high quality, powder coated screens.
Old Apr 3, 2009 | 10:20 PM
ALLEGRO's Avatar
ALLEGRO
Door edging. Got it at AutoZone. I used the U-shaped variety. Very cheap, but does take some working to get it on. I had about an hour per side.
Old Apr 4, 2009 | 01:51 AM
DeeGee's Avatar
DeeGee
Thats a great look. Well done
Old Apr 4, 2009 | 02:33 AM
yaknow's Avatar
yaknow
nice job
Old Apr 4, 2009 | 09:18 AM
tnarg's Avatar
tnarg
St. Jude Donor '06-'08
Barry,
What a difference, huh?
Turned out nice... good job!
Old Apr 4, 2009 | 10:50 AM
rpm462's Avatar
rpm462
I think that looks great! If it was the "U" shaped edging how did you get it to stay attached inside the cover area? There's not any adhesive on the one side is there? ...or did you just slide it on the edge of the cove from the inside?
Old Apr 4, 2009 | 11:24 AM
tnarg's Avatar
tnarg
Default Hope this helps
I used plastic door edge guard for the trim. There are several types out there, but I choose the "U" shaped style. It has a bead of adhesive in it. See photo.
I have attempted to draw some basic instructions of a sort (see below). The trim comes two to a package (left and right door). I put the joint at the top as I felt that would be the least conspicuous.
Keep in mind the outside of the gill opening is on a different plane than the interior side of the opening, therefore, the edging has to make a 90º twist and turn as you go from outside to inside (through bottom and top).
A blow dryer (no heat gun) might be handy to make the corners. Your first attempt might be a training exercise as you get used to how the edging is going to act. I purchased two sets for this reason.
Hope this helps,
Grant
Old Apr 4, 2009 | 11:42 AM
Cirrus8's Avatar
Cirrus8
Very GOOD!!
Old Apr 4, 2009 | 12:50 PM
NorCalVette Kid's Avatar
NorCalVette Kid
St. Jude Donor '09
Hope this helps,
Grant
Thanks, what a great idea!!
To Side Cove Improvement
Old Apr 4, 2009 | 01:09 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
great work...this is what's been missing from all the cheap aftermarket screen kits for almost a decade now. If I were you I would copyright your idea cause some sleazy vendor is going to steal your thunder and charge $200 for a set to do the whole car. I think you should get all the credit for it and the work you put into the instructions.
Old Apr 4, 2009 | 01:52 PM
Both things look good. Nice idea and thanks for sharing it.
Old Apr 4, 2009 | 02:08 PM
rpm462's Avatar
rpm462
Hope this helps,
Grant
Thanks for breaking that down, its a great help!
