OBX Headers have arrived and ........
Old Apr 14, 2009 | 09:53 PM
  #181
Sinister-one's Avatar
Sinister-one
Originally Posted by T_Vert
He is modifying the TI's so they are louder. They will bolt right up. Sinister, didn't you go w/ Dynatech cats? know of anyone who sells that cat w/ the flange already on it to bolt up to a 4 bolt collector like the OBX and dynatech?
Dave
You are correct on the Ti mod I'm looking to get done. They have a REALLY good sound to them right now, but I hear they sound even better with the bypass mod !
Yes I did find some Dynatech cats for cheap on fleabay a while back. If I hadn't found them I was going to buy some highflow cats and have the flanges from the resonators cut and welded to the new cats.
I've had mine on for a while. I guess I can provide some pics as well. That is if you guys don't mind looking at dirty headers...
Old Apr 14, 2009 | 10:15 PM
  #182
T_Vert's Avatar
T_Vert
Originally Posted by SoSlow1
I'll check question #1 when I work on it tomorrow afternoon.
No pics of the hole but took a 1" holesaw and was a little overkill but made plenty of room..
The wires on top the passenger header 02 may be rubbing the tunnel cover slightly..
Last question no problems at all..I'm running Taylors and are not any closer to the OBX's as they were to the stock manifolds...
do taylor wires have that metal cover on them like the stockers?do you have the wires passing through this hole or just up and back down and out of that hole you made? I have a nice thick aluminum one I'd hate to cut
Pics would be great sinister
Dave
Old Apr 14, 2009 | 10:22 PM
  #183
Chrisrokc's Avatar
Chrisrokc
Thanks for the info for the size of the hole needed. I saw a picture of a hole cut, it was HUGE. Maybe they just did it over kill style. Anyways 1" shouldn't be a problem.
I like that idea on getting those flanges welded onto the high flow cats.
Old Apr 14, 2009 | 10:23 PM
  #184
SoSlow1's Avatar
SoSlow1
Geaux Tigers!!!!
St. Jude 15 Year Donor
St. Jude Donor '08 thru '26
Dave
No the Taylors do not have the metal covers...The wires out of the 02's are just up and back down out of the hole...
Old Apr 14, 2009 | 10:43 PM
  #185
T_Vert's Avatar
T_Vert
Also another question that may be dumb but if the o2 wires in front are rubbing already, how did you get the o2 sensor in there? Did you put them in first?
Dave
  #186
jgump's Avatar
jgump
How high was the car (rocker panel) off the ground?
Thanks,
Old Apr 14, 2009 | 10:57 PM
  #187
Sinister-one
Dave
While the headers are hanging and not completely bolt onto the heads is when you screw in the O2's.
Old Apr 14, 2009 | 11:02 PM
  #188
T_Vert's Avatar
T_Vert
only problem w/ this is that to replace the o2 sensor you need to unbolt the entire header and part of the exhaust.
Old Apr 14, 2009 | 11:08 PM
  #189
Sinister-one
You are correct. And you'll have to drop the header as well if you need to replace the starter.
Old Apr 14, 2009 | 11:15 PM
  #190
T_Vert's Avatar
T_Vert
actually you can just unbolt it and swing it out of the way to replace the starter. Ive had to do that already.
Dave
Old Apr 15, 2009 | 12:05 AM
  #191
SoSlow1's Avatar
SoSlow1
Geaux Tigers!!!!
Thanks,
If you are asking how high I got the car to change out the exaust its 20 inches at the Y pipe...
Old Apr 15, 2009 | 12:11 AM
  #192
SoSlow1's Avatar
SoSlow1
Geaux Tigers!!!!
Dave
There is enough room to get it turned into (the bulb part of the 02) the bung ..Its a tight fit and I didn't even think to put them into the header before I bolted them up..
Old Apr 15, 2009 | 12:39 AM
  #193
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
These are now available for ordering on my website for $599.99
more to come for post. I just got info done and added to website inbetween the 38 double din bezels i have to make
www.doubledmods.com
http://www.doubledmods.com/product.s...0&productId=31
Old Apr 15, 2009 | 08:54 AM
  #194
Sinister-one
That's the same price as fleabay.......
Old Apr 15, 2009 | 10:50 AM
  #195
Quickshift_C5's Avatar
Quickshift_C5
So with you guys having such great luck fitment and quality, I guess I'm curious what kind of power you guys might gain from these OBX Longtubes before committing myself to a more expensive setup.
Would love to hear about your dyno results ASAP!
Old Apr 15, 2009 | 11:03 AM
  #196
Sinister-one
'03vettemaniac' had his dyno'd and here's his results...
Numbers Are In!!
Just got it dyno tuned by Charlie at RPM. Before the headers I had the Vararam, Borla Cat Backs, 3.42's and a dyno tune with RWHP 326. Now with the OBX headers and great tune by Charlie I got 356 rwhp and 365 ft-lb of torque! I asked Charlie how these headers compared with others and he said they were slightly above average in the hp gain and that the torque was the really impressive thing. I will look for my old dyno sheet and let you know the peak torque back then. If i remember right the peak torque was less than 320 ft-lb.
Looks like 30 HP more with the headers. Not bad for "cheap" headers !!
I'll be dyno tuning mine next month after I install my cam. I'll post up my results shortly thereafter.
Old Apr 15, 2009 | 11:09 AM
  #197
Espresso's Avatar
Espresso
Ha, that is wonderful to know.
To OBX Headers have arrived and ........
Old Apr 15, 2009 | 12:09 PM
  #198
dblack's Avatar
dblack
How bad is the fuel smell with these and no cats?
The vette is my DD and I don't want to be smelling like a gas station when I get out.
Old Apr 15, 2009 | 12:10 PM
  #199
Chrisrokc's Avatar
Chrisrokc
So let me get this right.... I am going to need all of this
OBX Header System
2 12" or 24" O2 Extensions?
Header Bolts
Old Apr 15, 2009 | 12:16 PM
  #200
Sinister-one
I run high flow cats, so I really couldn't say.
OBX Header System
Header Bolts
OBX Header System -------------- YES
2 12" or 24" O2 Extensions? ------- YES
Header Bolts---------------------- NO
You can reuse your existing exhaust manifold bolts. What you will need is:
4 - 1 1/2" long 3/8 bolts
8 - flat washers
4 - lock washers
4 - nuts.
Peferably in stainless. I picked all mine up at Lowes for about $3 bucks.
