finally found clear corners........
Old May 9, 2009 | 05:16 AM
  #41
hdff's Avatar
hdff
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17
how do you stop the hyper flash that is stated on the switchback ad? also what are depos?
Old May 9, 2009 | 05:22 AM
  #42
jdmvette's Avatar
jdmvette
Night Owl for life
you stop the hyperflash with the flasher bypass harness. do a search for it.
depo is a manufacturer who makes clear corners among other things.
Old May 9, 2009 | 05:31 AM
  #43
hdff's Avatar
hdff
how can i find depot's stuff?
Old May 9, 2009 | 06:06 AM
  #44
jdmvette's Avatar
jdmvette
Night Owl for life
http://www.depoautolights.com/
Old May 9, 2009 | 06:41 AM
  #45
ljthe2nd's Avatar
ljthe2nd
You can use resistors, but they are a real pain to install and they get real hot or the easiest way is to install this flasher.
http://www.corvette-enhancements.com/c5_flasher_fix.php
Old May 9, 2009 | 06:53 AM
  #46
hdff's Avatar
hdff
Originally Posted by jdmvette
i do not see chevrolet listed here
Old May 9, 2009 | 07:00 AM
  #47
ljthe2nd's Avatar
ljthe2nd
search ebay for: Corvette C5, depo
Old May 15, 2009 | 01:02 PM
  #48
biglite351's Avatar
biglite351
Originally Posted by Jhonathan_W
Are these the ones that do the hyper-flash thing? Would I have to buy a pair of these and the harness listed in this thread?
http://forums.corvetteforum.com/c5-g...-for-drls.html
http://www.adaptiveperformance.com/hyper.htm
Old May 15, 2009 | 01:25 PM
  #49
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
They will give you hyperflash.
You only need to buy the hyperflash harness.
  #50
ljthe2nd's Avatar
ljthe2nd
On the C5 if you remove any of the incandescent bulbs that are used for the DRL's or the tail lights and replace them with LED's you will get hyperflash (flashing of the turn signal, much faster than it should be). Other than being annoying it will also lead to the LED to burn out faster and possibly the flasher burning out faster than it should. This is caused because although they are both 12v lights, the LED's current draw is much less than that of the incandescent bulb, so much less that the system thinks the bulb is burned out and this hyperflash is a signal telling you that you have a burned out bulb. To correct this situation, you have a number of options, you can install a load resistor in series with each one of the LED's you have installed in place of the incandescent bulb, or you could install the incandescent bulb you are replacing in parallel with each one of the LED that you have installed, or the easiest fix is to install one flasher bypass harness that includes an electronic flasher.
Old May 15, 2009 | 02:15 PM
  #51
biglite351's Avatar
biglite351
I suppose one would need two of those harnesses as well, one for each side... right?
Old May 15, 2009 | 02:16 PM
  #52
ljthe2nd's Avatar
ljthe2nd
One harness will take care of the whole car.
Old May 15, 2009 | 02:24 PM
  #53
ljthe2nd's Avatar
ljthe2nd
The C5 has one turn signal flasher that works with the incandescent bulbs installed from the factory to make the turn signals work. The bypass harness, is just that, it bypasses the OEM harness and replaces it with an electronic flasher that is designed to work with either incandescent bulbs or LED's. They don't make a replacement electronic flasher for the C5 like they do on some other cars, so to get around this people have designed a bypass of the OEM flasher and the addition of an electronic one. That is what these bypass harness are made for.
Old May 15, 2009 | 02:34 PM
  #54
JMc's Avatar
JMc
From: "This is not a psychotic episode, but a cleansing moment of clarity."
FYI, even with the bypass harness installed, your emergency flashers will hyperflash, unless you put your left or right turn signal on at the same time, in which case all four corners will slow down.
Old May 15, 2009 | 02:44 PM
  #55
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
mine doesn't. hazzards flash at normal rate with the led flasher harness and switchbacks installed
Old May 15, 2009 | 02:47 PM
  #56
JW Motorsports
Banned Scam/Spammer
I don't see too many people using their hazards enough to not buy LEDS.
Old May 15, 2009 | 02:48 PM
  #57
JMc's Avatar
JMc
That's interesting... I wonder why my switchbacks and halo LED's hyperflash when the hazards are on, then?
Not that I mind the hyperflash on the hazards at all. In fact, I think I may prefer it. I only use the hazards when having to stop abruptly for traffic on the freeway and there is nobody behind me for a large distance. I want them to see that there is something up ahead that they need to pay attention to.
To finally found clear corners........
Old May 15, 2009 | 03:02 PM
  #58
biglite351's Avatar
biglite351
Sorry to be a pain... so buy two of the lights linked abouve and one of the harness that I linked, right? Are those the best versions of these items or are there other/better versions from other vendors?
Old May 15, 2009 | 03:11 PM
  #59
ljthe2nd's Avatar
ljthe2nd
Johnathan a vendor here sell the switchbacks,
http://shop.jwmotoring.com/product.s...&productId=139
And Richard with Corvette Enhancements (also a vendor here but I don't have a link, but you can do a search), sell the harness, but I have heard he is out of stock right now, you would have to check his site. If he is out the link you have for the harness would work also.
Old May 15, 2009 | 03:26 PM
  #60
JW Motorsports
Banned Scam/Spammer
I have one flasher harness. It's not on the site yet though.
