Brake Bleeding
Old May 19, 2009 | 12:10 AM
c5blkvetteguy's Avatar
c5blkvetteguy
Default Brake Bleeding
I am going to be doing some brake work and want to flush the old brake fluid out. I know there is a thing you put on top of the master cylinder and pressurize the system. Then the bleeders get cracked and the new fluid goes into the system. What is the name of this pump thing and where can I buy one? Does it come with the hose to put on the bleeder (to run fluid into a jar)? I know the bleeding order. Is there any tips, tricks, or things to look out for? Thx in advance!
Old May 19, 2009 | 12:19 AM
Ed_78Vette's Avatar
Ed_78Vette
I purchased my brake bleeder kit from Mid America and it is called Power Bleeder. It's a two piece kit: first the master cylinder attachment with the pump, second the catch bottles that attach to the caliper bleeders. My kit is for my 78 C3, and nearly identical to the C5. It's a good investment.
Old May 19, 2009 | 12:38 AM
DeeGee's Avatar
DeeGee
I went with the alternative
Speedbleeders:
http://www.speedbleeder.com/
Old May 19, 2009 | 01:26 AM
Last C5's Avatar
Last C5
It's called a Motive and they have a web site. Make sure you get the late model GM cap and a yes they have a bleed bottle available too. Don't follow the Motive directions, keep the Motive tank empty and just monitor your fluid levels in the master reservoir.
Old May 19, 2009 | 03:39 PM
robsc501's Avatar
robsc501
Hi There:
I did my buddies c5 he was the pedal operator.I used the manual system.I used the GM p/n 12377967 brake fluid. The vinyl tubing size is 5/16" od x3/8"id.x 20 ft. long for about $3.50 bought at h/depot.By the way all the wheels were removed so access was easy. Speed bleeders are a nice upgrade.
robsc501
Old May 19, 2009 | 09:14 PM
Patches's Avatar
Patches
I use a Motive bleeder because I generally never have help when doing mods and maintenance so I look for tools that can make a two-man job a solo experience. This one fits the bill.
Old May 19, 2009 | 09:44 PM
Bill Dearborn's Avatar
Bill Dearborn
Here is a link to the late model GM Motive unit.
http://www.racerpartswholesale.com/p...Brake_Bleeders
Bill
Old May 19, 2009 | 10:47 PM
happa's Avatar
happa
Very Cool, looks like I'll be getting one soon
Old May 20, 2009 | 06:33 AM
Wheelyneat's Avatar
Wheelyneat
+1 on the Motive bleeder - works like a charm and is worth every penny. I've never been a fan of using the car's master cylinder as a "high volume pump" to move lots of fluid through the system and out of the bleeders... too many bad experiences with subsequent piston seal failure within a few days of bleeding the brakes. Maybe the fact that these failures were in British cars had something to do with it
Old May 20, 2009 | 07:23 AM
Armedruby's Avatar
Armedruby
Originally Posted by robsc501
Hi There:
robsc501
This is what I did.....for no more often than I bleed brakes, this worked fine for me.
Old May 20, 2009 | 08:03 AM
AU N EGL's Avatar
AU N EGL
Old May 20, 2009 | 09:31 AM
Red3644's Avatar
Red3644
How much pressure does the Motive tool use to push fluid through the lines?...I notice a gauge on front.
Old May 20, 2009 | 10:51 AM
Wheelyneat's Avatar
Wheelyneat
I rountinely pump mine to 15-17 psi with no issues whatsoever. Just to be safe I usually de-pressurize the tank and refill the master cylinder reservoir after each corner is bled.
Old Aug 11, 2009 | 11:37 AM
RDnomorecobra's Avatar
RDnomorecobra
you guys should read this ... http://www.z06vette.com/forums/f8/mo...12/index1.html. scroll down to posts #7 and #10.
I'm no expert but this argument against pressure bleeders makes sense to me. I am just trying to figure out best way to do this myself.
Old Aug 11, 2009 | 11:45 AM
Black04Z06's Avatar
Black04Z06
Originally Posted by AU N EGL
Ok, I see that you added a very cool mod .
Old Aug 11, 2009 | 12:12 PM
DPG's Avatar
DPG
St. Jude Donor '06
i just use this. it pulls the fluid out
http://www.harborfreight.com/cpi/cta...emnumber=92474
Old Aug 11, 2009 | 08:42 PM
HollywoodFRC's Avatar
HollywoodFRC
Default Bleed them yourself
One word: Speedbleeders. Allows you to bleed brakes with no help required. Great product, relatively cheap. Google 'speedbleeders' for source.
To Brake Bleeding
