C5 headlight HELP
Old Jun 16, 2009 | 08:48 PM
DFB's Avatar
DFB
Default C5 headlight HELP
I turn on my lights both come up and on. I turn my
lights off, lights go off--both go down, then 1 comes
back up about 90%. the light is off ??
DFB
Old Jun 16, 2009 | 09:44 PM
2003 electronblue's Avatar
2003 electronblue
its probley a lose nut on the lamp arm they are always coming lose just tight it up and put on a lock for it.
Old Jun 16, 2009 | 09:51 PM
blk6spdvert's Avatar
blk6spdvert
Try turning on the high beams before you shut them off. I don't know why but it worked for me.
Old Jun 16, 2009 | 10:27 PM
DFB's Avatar
DFB
I tried high beams then turn off (did not work)
but thanks !!!
Old Jun 17, 2009 | 11:58 AM
DeeGee's Avatar
DeeGee
This may be worth a try. If not, it's probably an issue with the headlight stops or the gears. This one's a cheap fix if it works.
Number: 00-08-42-002
Subject: Left Headlamp Door Does Not Stay Closed (Shim Headlamp Door Motor/Actuator and Replace Insulators)
Model Year: 2000 Chevrolet Corvette
Condition
Some customers may comment that the left front headlamp door does not remain closed after the headlamps are turned off. Others may comment
that the left headlamp door closes when the headlamps are turned off, but then reopens. In either case, the right headlamp door operates properly.
Correction
Important
The following information applies to the left front headlamp door motor/actuator only. It does not apply to and should not be performed on the right front headlamp door motor/actuator.
Install one washer (2) between the left headlamp door motor/actuator (1) and the mounting bracket (3) at each of the three attaching bolt locations. Also replace the
insulator (4) on each of the two mounting bracket travel stop tabs (5) as shown. For information on headlamp motor/actuator removal, see the Headlamp Motor/Actuator
Replacement procedure in the Lighting sub-section of Body & Accessories in the appropriate Service Manual.
Parts Information
Part Number Description Qty Per Vehicle
11505463 Washer 3
16524060 Insulator 2
Old Jun 17, 2009 | 04:01 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
check your nuts.
To C5 headlight HELP
