German Projector Lights Status Update
Old Aug 21, 2009 | 03:38 PM
  #41
cdnguyred88's Avatar
cdnguyred88
Old Aug 21, 2009 | 04:01 PM
  #42
karateboi87's Avatar
karateboi87
Originally Posted by nvusgt
pretty sure those look like projectors and from what i read on the nsx boards, just need to throw in some good HID's
That's cool! I never knew that before. I thought the first projectors used in headlamps were by BMW, then by Honda (Their Acura Integra gen 2).
Originally Posted by black98c5
I think that looks bad a$$!!!
But those lights are halogen, right? They look like the stock halogen projectors that are on some cars now.
Old Aug 21, 2009 | 04:20 PM
  #43
zeevette's Avatar
zeevette
Originally Posted by CUlookin
The shroud they have over there is amazing looking...
Very cool!
Old Aug 21, 2009 | 04:55 PM
  #44
jrprich's Avatar
jrprich
I vote for shrouds like these. The problem with clear covers is condensation.......I would prefer the projectors as they are.....raw with shrouds.
Old Aug 21, 2009 | 06:40 PM
  #45
karateboi87
But all OEM projectors have clear covers. Only time condensation can occur is when it leaks, right?
Old Aug 21, 2009 | 07:26 PM
  #46
CUlookin's Avatar
CUlookin
They are but the other ones have HID's in the same setup... Not trying to Hijack your thread Jhonathan!
Old Aug 21, 2009 | 07:29 PM
  #47
karateboi87
No hijacking, the photo is a prototype of those sleepy eyes headlight that JW is bringing to the market, aren't they?
I think they look awesome
Old Aug 21, 2009 | 07:31 PM
  #48
SCM_Crash's Avatar
SCM_Crash
This looks FAR better than my idea.
Old Aug 21, 2009 | 07:33 PM
  #49
SCM_Crash's Avatar
SCM_Crash
Correct.
Old Aug 21, 2009 | 08:23 PM
  #50
jrprich's Avatar
jrprich
Yes, but I see tons of OEM lights that have leaked on many different models of cars......
Old Aug 21, 2009 | 08:39 PM
  #51
CUlookin's Avatar
CUlookin
No, this kit on the black car above (now that I found all the links I had saved) was from a German guy that wanted like 1500 for the kit. Jhonathan found a kit with the same hardware for like 500 or a little more, that came with a really crappy shroud... I know he's working on a new shroud that will be fit for the C5 world I believe, but correct me if I'm wrong. That way he can offer the kit at a reasonable price...
Old Aug 21, 2009 | 08:44 PM
  #52
karateboi87
Well headlights do get damaged
I've yet to see a BMW with their xenon headlights leak.
I see. Keep us updated!
Old Aug 21, 2009 | 09:00 PM
  #53
SCM_Crash's Avatar
SCM_Crash
Right. I've had 5 cars with covered projection lights (3 of which were Nissan/Infiniti) and we've NEVER seen leaks. My 19 year old 300zx has covered projection lights and there hasn't been any leaks in them yet.
Old Aug 21, 2009 | 09:04 PM
  #54
jrprich's Avatar
jrprich
These will not be made by BMW
Many OEM headlights develop fog and condensation over time without being hit or damaged. They also are prone to sun damage, but the C5 wouldn't have that issue since the lights retract.
Old Aug 21, 2009 | 09:08 PM
  #55
mtndv8's Avatar
mtndv8
Default condensation....
SCM_Crash, those are sweet! Is that your ride? Very Nice!
Originally Posted by SCM_Crash
Correct.
Condensation is directly related to humidity, air temp and atmospheric pressure.
When the air temperature rises the volume of air expands with the increase and the abillity of the (trapped) air to hold water vapor in suspension decreases.
This happens in nature and Meteorologists have very technical terms for it, like clouds and rain. jrprich/Jim you probably know this phenom well up there in Oregon. (Just teasing you bradda, Hillsboro's very nice... )
Sorry. Anyway, I see the key as venting the air, or allowing the heat/moisture laden air to escape to reduce pressure and keep the moisture in suspension. Problematic considering the heat generated by our 'proposed' mods.
I would think that as long as we aren't sealing the clear lens' completely and allowing air circulation, condensation wouldn't be a problem. (...unless I've missed something, which could be the case. )
How about a set of body colored shrouds covered by a clear lens??
Seems to me the C6's look pretty good like that. That would be my vote...
...if I get one?
Aloha
Old Aug 21, 2009 | 09:16 PM
  #56
SCM_Crash's Avatar
SCM_Crash
Nope. I wish. Those are fantastic looking shrouds.
My car is in the garage.
  #57
karateboi87
Well I was just using BMW as an example since they use projector bulbs too... you don't seriously think their clear cover is actually like a huge quality improvement over say, a Toyota's clear cover, right?
What I'm saying is, I have yet to see a huge problem regarding condensation. How many vehicles do you see or know someone have that have these issues often?
And as you said, C5's lights retract, so that makes it even less chance.
To German Projector Lights Status Update
Old Aug 21, 2009 | 10:08 PM
  #58
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Man tons of replies since I last checked
That's pretty much correct. The first guy Birger did want a lot more, but his kit is a better quality. After polling C5 owners and the way spending is that system is not going to work here.
We decided to try the cheaper kit to see what it's like. We found out it's not what we want so we're going to use the same concept with our own design. We will also be buying our own projectors and hardware to keep costs down.
Old Aug 22, 2009 | 03:13 AM
  #59
jrc27's Avatar
jrc27
Cruise-In IV Veteran
Cruise-In V Veteran
Originally Posted by Jhonathan_W
60mm Hellas.
Here is my original thread
http://forums.corvetteforum.com/c5-g...-their-c5.html
From the pictures you posted, they look like the 50mm hellas. I couldn't find anything on hellas site about 60mm modules
Old Aug 22, 2009 | 03:56 AM
  #60
karateboi87
I talked to radioflyer on another thread, and he mentioned 60mm Hella's. I have never heard of 50mm ones though. I know there are 60mm and 90mm. How would you tell 10mm from the photo?
