Vararam vs. Honker
Old Oct 26, 2009 | 01:54 PM
03 Z-oh-6's Avatar
03 Z-oh-6
Default Vararam vs. Honker
Vararam seems to have the best design for a true CAI. On the flip side, the quality isn't top notch and it's a bitch to install.
Honker may not be a true CAI as it breathes hot air from the radiator? On the flip side, the build quality is top notch and easy install.
I'd really like to buy the Honker, but the fact it takes in hot air from the radiator sways me away. Should I go Vararam??
Old Oct 26, 2009 | 01:55 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Vararam all the way! On sale for $255 shipped right here at JWM.
Old Oct 26, 2009 | 02:15 PM
AU N EGL's Avatar
AU N EGL
Have taken off several v-rams to put on a honker or vortex style air intake. Greater throttle response.
Plus needed to put duct tape over screens for better aerodynamics and greater speeds.
Old Oct 26, 2009 | 02:19 PM
SaberD's Avatar
SaberD
im going to have to agree with Jhonathan on this one. go with the VR. if the fitment is bad, it can be fabricated to fit better. one other thing, i would want as much air going to the radiator as possible. the honker takes air flow away from the radiator, not to mention its sucking in hot air at lower speeds.
Old Oct 26, 2009 | 03:02 PM
AU N EGL's Avatar
AU N EGL
No and No
Old Oct 26, 2009 | 03:07 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
Where did you get your information that the Honker takes in hot air and takes air flow away from the radiator?
Old Oct 26, 2009 | 03:10 PM
yostie05's Avatar
yostie05
Originally Posted by AU N EGL
No and No
Please elaborate. I'm currently deciding on a CAI. Thanks
Old Oct 26, 2009 | 03:11 PM
HRDTOPC54FUN's Avatar
HRDTOPC54FUN
There are a lot of good things on this forum but that sataement is just wrong.
Old Oct 26, 2009 | 03:17 PM
c5vetteguy's Avatar
c5vetteguy
2018 C5 of Year Finalist
There's a zillion posts about the Vararam. Most agree that the quality isn't the best. Some have difficulties installing them, some don't (I didn't). Most agree that the performance makes up for the lack of quality. I like mine and have the VR Power Duct to compliment it. I have no intention of changing it to any other system. I'd also recommend the screens for the front inlets. Those have kept many an autumn leaf from being ingested.
There may be a comparison of the two (or more) on the forum somewhere. Be prepared to read a lot.
Old Oct 26, 2009 | 03:44 PM
03 Z-oh-6's Avatar
03 Z-oh-6
I was set on the Honker until I read that it's getting hot air from the radiator. I have no idea if this is true or not, that's why I posted the question. I think there will be bias from both sides, so how will I know the truth?
Old Oct 26, 2009 | 04:42 PM
Moota's Avatar
Moota
I just put in an order for a Honker. I live in So Florida though so the puddles here kind of spook me out with a Veraram. I figured you cant go wrong with a company like Callaway.
Old Oct 26, 2009 | 04:45 PM
jaygood's Avatar
jaygood
I'm a vararam fan
Old Oct 26, 2009 | 04:53 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Uhmmmm VARARAM all the way! If you think that is hard to install then you are wrong
Well actually I don't know you wrenching skilss but if you have a small amount of skills you can do it with ease.
I had mine for a long time before i went FI, I would not hesitate to recommend it to others and the quality is just fine, don't listen to all that you hear
Thanks,Matt
Old Oct 26, 2009 | 05:07 PM
madmatt9471
Thanks,Matt
Old Oct 26, 2009 | 05:26 PM
PCK1221's Avatar
PCK1221
+1 vote for a vararam.
I had trouble installing it, worth it though. Theres a noticable difference in acceleration
Old Oct 26, 2009 | 05:40 PM
SaberD's Avatar
SaberD
there is a reason why they didnt design the radiator shroud with a hole in it. it is supposed to capture air and force the air through the radiator. if you put a hole in it, its not going to be forcing as much air through the radiator because the pressure in the area is released through the hole in the shroud. At low speeds, where there isnt as much pressure, heat will rise off the radiator because there is not sufficient pressure in the shroud area to force air through the radiator. therfore, you will be sucking in hot air from the radiator. its common sense really.
Old Oct 26, 2009 | 05:50 PM
legman's Avatar
legman
Search out those who have tried both. Both are great products but one seems to have more than a few complaints about fitment and overall quality.
I went with the Honker and couldn't be happier.....
To Vararam vs. Honker
Old Oct 26, 2009 | 07:37 PM
arkus's Avatar
arkus
I have the Vararam and dont like the quality . Im going with the honker.
Old Oct 26, 2009 | 07:40 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
Sorry but I dont want to spend $225 on an intake and then it fit like crap and have to fabricate it?!?!?! Just my thought. Still sticking by aFe Stage II pictures in profile
Old Oct 26, 2009 | 07:43 PM
zeevette's Avatar
zeevette
I have the Vararam, and I'm very happy with the fit, and the results. OTOH, the Honker is a very nice piece, and at any speed above walking, the hot air sucking argument is no longer valid. IIRC, at today's prices, the Honker is substantially more expensive, and slightly less effective, so make your choice.
