Brake rotor difference?
Old Nov 15, 2009 | 02:41 PM
dlivewyer's Avatar
dlivewyer
Default Brake rotor difference?
I've been looking at some brake rotors and some say that they are not for the Z51. What's the difference and how do I know if they WILL fit Z51? I have a '97. Thanks, Dale
Old Nov 15, 2009 | 05:12 PM
dlivewyer's Avatar
dlivewyer
Anyone? Is this a stupid question? :o
Old Nov 15, 2009 | 05:46 PM
AU N EGL's Avatar
AU N EGL
C5 rotors are all the same size
all the fronts are the same across the models and years
same with rear
Old Nov 15, 2009 | 06:08 PM
korte's Avatar
korte
When you get brake rotors make sure that the middle of the rotors has the black covering (like the ones from the factory do) or the centerpiece will rust. Will turn yellow and look all nasty.
Old Nov 16, 2009 | 02:01 AM
Oldvetter's Avatar
Oldvetter
You can paint them. I suggest high temperature rustoleum.
If you get drilled and slotted, it is best if they are zinc plated.
Try:
http://brakeperformance.com/site/index.php?ad=direct
Old Nov 16, 2009 | 02:39 AM
Vette_Fan's Avatar
Vette_Fan
Try:
Not to steal the thread, but I was doing a search and I'm looking for some decent Brake pads & rotors, and have checked out their website. It looks great! Has anyone used the drilled & slotted rotors / pads from these guys?
Thanks...
Old Nov 16, 2009 | 09:25 AM
Carcass's Avatar
Carcass
I've got a full set of the Drilled/Slotted/Black coming this week,I'll let you know.(won't be installing them till the weekend)
Already have Hawk HPS pads,so I'm only getting the rotors.
Old Nov 16, 2009 | 09:39 AM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
I've been running Brakeperformance dimpled/slotted, zinc plated rotors for almost two years now, no problems, and they still look good.
Old Nov 16, 2009 | 09:50 AM
Dave68's Avatar
Dave68
Drilled rotors are like rear wings - look good to some but are for the most part, not functional. Slotted rotors, on the other hand will eliminate the dreaded pulsating brake pedal syndrome when running OEM pads. They also keep the pads parallel and fresh at all times.
PowerSlot rotors are cad-plated, not merely zinc-washed. The cad plating is much more durable and will most likely last as long as your car does. I went all-out and bought the cryo PowerSlots and I fully expect to never have to touch them again.
Old Nov 16, 2009 | 10:02 AM
AU N EGL's Avatar
AU N EGL
Brake rotors are consumable items.
the OEM ( style) rotors should last the life time of the car, if used under normal street minimum spirited driving.
Old Nov 16, 2009 | 01:31 PM
Vette_Fan's Avatar
Vette_Fan
Has anyone tried these? Seems like an inexpensive solution, for someone who simply wants brakes (not hi-perf/racing application). What do you guys think -
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
Old Nov 16, 2009 | 03:26 PM
Dave68's Avatar
Dave68
I wish that were the case with my car. After only 6000 miles, the dealership had to turn the rotors. After another 6000 miles, there was not enough "meat" left. I guess I could have bought different pads, but because I really liked the OEMs, I decided that blank rotors were the culprits. After having slotted-only rotors for many years now, I am glad I went that route. They are bulletproof!
Old Nov 16, 2009 | 11:56 PM
Vette_Fan's Avatar
Vette_Fan
What's your take on this?
Old Nov 17, 2009 | 09:02 PM
shermanr's Avatar
shermanr
The Baer Decelarotor is a cross drilled and slotted direct replacement for factory. No mod's needed. Would recommend changing to ceramic pads to eliminate the dust. Also please note that the wheel cleaners sold by the major car care guys will mess up any after market rotor.
Old Nov 18, 2009 | 02:00 AM
Vette_Fan's Avatar
Vette_Fan
I'm guessing nobody goes flebay....
Thanks. I'd just use soap & water...
Old Nov 18, 2009 | 07:27 AM
AU N EGL's Avatar
AU N EGL
Turn blank rotors ? Something else was wrong to wear down a blank rotor.
Slotted rotors scrap the brake pads to keep them clean, which is ok.
Blank sided rotors have the most braking surface to stop your car.
Old Nov 18, 2009 | 10:07 AM
Dave68's Avatar
Dave68
It wasn't wear, really. It was the dang uneven pad deposits that caused the pulsations. Yes, you can slam on the brakes to try to get rid of the deposits, but they quickly return. With slotted rotors, this is never an issue. Remember, the Cadillac CTS-V and Dodge Viper ACR come from the factory with slotted-only rotors.
To Brake rotor difference?
Old Nov 18, 2009 | 11:17 AM
AU N EGL's Avatar
AU N EGL
That is a caliper and piston problem. time to rebuild the caliper
Uneven pad deposition many times are do the the wrong type of brake pad and improper brake pad / brake rotor bedding in or seasoning process.
Slotted rotors do clean off the brake pads, but also decrease brake pad life.
Brake pads and rotors again are consumable items and need to be replaced from time to time
Old Nov 18, 2009 | 11:32 AM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Huh?
Old Nov 18, 2009 | 11:41 AM
korte's Avatar
korte
how can a consumable item last the lifetime of the car?
