Decision Time..!
1999 - 2002: Service Bulletin: Higher Than Expected Oil Consumption
Subject: Higher Than Expected Oil Consumption (Replace Rings and Engine Valley Cover)
Source: Chevrolet Dealer Technical Service Bulletin
Number: 01-06-01-023A
Models: 1999-2001 Chevrolet Camaro, 1999-2002 Chevrolet Corvette, 1999-2001 Pontiac
Firebird, with 5.7L Engine (VINs G, S -- RPOs LS1, LS6)
This bulletin is being revised to add model years for the Corvette, information on the LS6 engine
and parts information. Please discard Corporate Bulletin Number 01-06-01-023 (Section 6 -
Engine).
Condition
Some owners may comment on higher than expected oil consumption. When checked, the oil
consumption could be in the range of 400-600 miles per quart (700-1000 km/L).
On the LS6 engine only, the technician may find oil behind the engine throttle plate and in the
intake manifold.
Cause
The cause for this condition may be an interaction between the piston rings and the cylinder
bore in vehicles that are operated at higher RPMs -- typically manual transmission vehicles
driven in a manner where the engine is frequently or consistently operating at greater than 3200
RPM.
On the LS6 engine only, the engine has a unique aluminum valley cover that has composite oil
separating baffles and PCV plumbing incorporated. In some cases, the PCV baffle may not be
properly sealed to the valley cover, causing oil to enter the PCV system.
Correction
On the LS6 engine only, replace the engine valley cover if oil is found behind the throttle body
or in the intake manifold before replacing the piston ring. Refer to Engine Valley Cover
Replacement in the Engine Mechanical - 5.7L subsection of the Corvette Service Manual.
A new set of piston rings is currently available through GMSPO. The new rings are part of a complete piston ring kit. Install only the number 2 compression ring and the oil expander ring from the piston ring kit. All other rings in the piston ring kit should be discarded. The original number 1 compression ring and the oil ring rails should be re-used in their original positions on the piston. All pistons should be used in the same cylinder bore.
I do appreciate all the comments
You can make them worst with spirited driving with shifts above 3200 rpm and lots of down shifting. Of course the fun meter starts getting active above 3200 rpm as well.
I have a 00 coupe and it doesn't use any oil in 3000 miles. Maybe an 1/4 oz in the catch can.
I would buy the car that's in the best condition. Hows the engine, brakes, interior etc. Sounds like your leaning to the red 01. If that's your choice go for it & don't look back. G/L
http://forums.corvetteforum.com/c5-g...call-done.html
Don't take a chance with the 01, I bought used 5 yrs ago(99) and wouldn't even consider an 01 for that reason alone..
I have an ’01 since June ’05, I never had to add any oil between changes.
