Need advice on tires
Old Jan 17, 2010 | 06:11 AM
JerG's Avatar
JerG
I'm running BFG Super Sports, an all-season, non-run flat. I like them a lot, very reasonable price. If you want a little more performance and sexier side wall and tread, go with the BFG G Force KDWs, it's an older design tire but seems to be the standard to beat for UHP tires.
Jerry
Old Jan 17, 2010 | 07:27 AM
ameldorf's Avatar
ameldorf
6th Gear
I'm running Falken Azenis RT-615s and like them alot.
Old Jan 17, 2010 | 07:38 AM
bljones's Avatar
bljones
Guys,Thanks for all the input. I live in Atlanta and it looks as though there are several non run flat choices in the price range I am looking for.
Old Jan 17, 2010 | 08:03 AM
IMXCITD's Avatar
IMXCITD
all the tires are pretty good now adays....just a matter if you want runflats or not. I had some Firestone Wideovals on my last Z and they were a good tire for the money. Shop your purchase around....check sam's, BJ's, tire rack, firestone...etc.
Old Jan 17, 2010 | 09:07 AM
Baron138's Avatar
Baron138
I have the Mich Pilots n like them a lot. Much better than the Goodyears I replaced
Old Jan 17, 2010 | 10:40 AM
Mike Gallagher's Avatar
Mike Gallagher
I have Firestone non runflats and have 2 comments: 1) great traction in warmer weather - noticably different when it turns cold - but not unsafe, 2) within the first month I had the C5 (two years ago) I got 2 screws in the same rear tire (2 separate occurances). I plugged the two different holes with the gooey worm looking things using the reamer and t handle inserter and have no issues with the plugs. I did have the tires rebalanced and dont go over 90 or so ever. Still holding after 17000 miles.
Old Jan 17, 2010 | 02:51 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Originally Posted by Glennm27
I had Goodyear GS-D3 tires on my C5 and loved them. If you drive in the rain, I don't think you'll find a better tire. Also very good in dry weather.
Originally Posted by goober51
How about cold weather? It's not exactly like the Arctic here in NC, but I don't want to be sliding around when it gets below 32..
Originally Posted by Dave68
How often does that happen? You would be sacrificing handling/traction most of the time if running all-season tires just because it gets below 32 occasionally.
with Dave
The GS-D3's have a treadwear rating of 280. The BFG KDW's mentioned in this post are rated at 300. Not much difference at all.
As with any tire, you must use your head when it gets cold, understand the laws of physics, understand when it's below 32 it's not the optimal time to be driving your car in a spirited manner and maybe give a little in those few times when it's colder than normal. There are NO tires made for performance driving on cold pavement... When it's cold, you need to give it a rest and drive accordingly......
Old Jan 17, 2010 | 04:41 PM
Turbo5's Avatar
Turbo5
Go with the Michlens you won't be sorry. They made my car ride like a rocket ship on rails!!
Turbo5
Old Jan 17, 2010 | 07:19 PM
DebRedZR1's Avatar
DebRedZR1
Moderator
CF Banner Relay Captain
West MI & JAX/NE Florida
Events Coordinator
St. Jude Donor '11-'17, '21
Originally Posted by Gitusum
nitto invo tires and bfgoodrich g force ta kdw tires and they look sexy too
I'm in for the Nitto Invos, look cool and handle awesome
Old Jan 17, 2010 | 10:07 PM
Dave68's Avatar
Dave68
Jerry
...a word of caution: KDWs are horrible on wet surfaces, They should be considered dry surface tires, only. The KDW2s are much better on wet surfaces but are noisier than most ultra-high performance tires.
....not according to a recent tire test by Car & Driver:
If we rated tires on tread design, the Nitto Invos would score high. The slashes that crisscross intriguingly through the tread had us envisioning a vicious Star Wars light-saber showdown taking place right there on the edge of the tire.
Unfortunately, the Nittos’ performance was less inspiring. They were second from the bottom in both dry lap time and braking, with both drivers reporting a soft feeling at the limit and that they were difficult to drive precisely because the grip would taper off in a nonlinear fashion. This led to more oversteer than most of the other tires exhibited, and even though they had an average skidpad run (0.91 g), the Invos left both drivers wishing for more grip.
Things were better in the wet, where Geswein ranked the Invos tops for precise responses, tied with the Dunlops and the benchmark Michelins. The tires’ predictability inspired confidence, although their lap time was still exactly in the middle.
Fairly quiet on the street loop, the Invos were below average in the dry and average in the wet, which put them in eighth place. Nitto does offer a higher-performance tire, the NT05, which conceivably could have fared better but is not available in the size specified for our test.
Old Jan 17, 2010 | 10:14 PM
Jet-Jock's Avatar
Jet-Jock
I also am trying to decide which tires for my '01 for the 1st time.(32k)..I was thinking i might get the Michelin PS2's non-runflats. or how about the Michelin A/S Pilot Sport Plus? . .Should the tire pressure sensors be replaced also? And how much are they? thks..
I'm on my second set of Pilot Sport A/S ZPs the first set was the non-plus (they weren't out yet) the second set are the plus's. Although they claim 45K, I'm probably at 16K and the rears are wearing fast, and no I don't do burn outs they are always kept at the proper pressure. The fronts look great in comparison.
The next time, I'm going with PS2's I'm not worrying about the cold tire needs being in FL and I'm not going to take any winter trips in it. Now trying to decide between the non RF PS2 and the PS2 ZP is the current consideration. The PS2 ZP is the OEM tire for C6 Corvette ZR1. The stance of the A/S is not as wide appearing or as aggressive as the PS2. The PS2 ZP is on the same line tire as the OEM F1 EMT. Except it is newer generation. I cannot remember the wear rating on the PS2 vs PS2 ZP though. It can be found on tirerack though.
Old Jan 18, 2010 | 01:26 AM
Stavesacre21's Avatar
Stavesacre21
I can't wait to get my stock tires off already so I can throw some General Exclaim UHPs on it. I really don't care for the Goodyears.
Old Mar 30, 2010 | 09:13 PM
  #33
Tastee Twirl's Avatar
Tastee Twirl
LIFE IS SHORT HAVE FUN
St. Jude Donor '12-'13-'14-'15-'16-'17-'18
I also run Falken Azenis RT-615s 315 30 18-255 40 17 they are sweet and less than 1k shipped. What a suprise after runflats seems like defferent car.
Old Mar 30, 2010 | 09:33 PM
  #34
2003 electronblue's Avatar
2003 electronblue
No one asks about the amount of mileage a tire gets i would like to know which BRAND tire gets the most mileage? is there a 50,000 mile tire ? the michelin's on my buick are rated 80,000. i live in fl so an a/s is not needed...
Old Mar 30, 2010 | 10:18 PM
  #35
Rockin'M's Avatar
Rockin'M
I've had the Firestone Firehawk runflats. Awesome looking tread pattern and nice tire that got about 30K miles. I just replaced them w/ the Michelin PS A/S Plus ZP's. totally different tread pattern and maybe not as wide, but really ride nice. I think the sidewall is bigger than the firehawks as it really looks taller now...maybe it's just the extra deep tread on the michelins. Both are great runflats.
Old Mar 30, 2010 | 11:27 PM
  #36
Jet-Jock's Avatar
Jet-Jock
Michelin Pilot Sport A/S Plus ZPs have a 500 wear mile rating, which should go about 45K.
Most of the other UHP/MP tires range from 200 to 300 ratings.
Old Mar 30, 2010 | 11:47 PM
  #37
postwhore's Avatar
postwhore
most people who use cheap tires have no IDEA how good the premium tires are
Old Mar 31, 2010 | 09:57 AM
  #38
ramez75's Avatar
ramez75
Dont mean to hijack the thread but since we are discussing tires. I usually buy the runflat Kumho all season from tire rack, they are alright, affordable. My question what are cons/ pros between runflats vs non-runflats other than if you have a flat tire u can drive few miles before trashing the tire.
RB
Old Mar 31, 2010 | 11:03 AM
  #39
TraceZ's Avatar
TraceZ
+2 The Goodyear GSD3s not only handle as well as the PS2s, but outlast them according to an independant tire test company's results.
I've been running them for years and never cease to be amazed at how well they grip on both dry and wet roads - truly a phenominal tire.
BUT Goodyear has discontinued them in the 275 40ZR18 size that we need for the rear of our cars. I just had a set installed that I got from Tirerack. At the time I ordered the rep told me they were down to 6 tires left at the warehouse in NV and all the other warehouses were sold out.
