What spark plug gap do you run?
Old Feb 9, 2010 | 09:00 PM
Patman's Avatar
Patman
Default What spark plug gap do you run?
There seems to be a big discrepancy as to the actual spark plug gap that the plugs for the LS1 should run, so I'm curious as to what everyone here is running?
I've been running NGK TR55ix plugs at the preset gap (.059) for the past couple of years with no problems, the engine runs very smooth with no misfires. Before that I ran NGK copper plugs with a .050 gap and that also worked well for me too. But I understand GM now has a TSB stating the LS1 should be running a .040 gap. (FWIW I tried a .040 gap for a while on my 98 LS1 Firebird Formula and it also seemed to work well for me, scan tool testing showed no misfires)
But I've always figured that for normally aspirated (and relatively stock) engines that you should run the highest gap that your ignition system will properly fire as that will allow for more horsepower (although I doubt there would be more than a 1 or 2 hp difference if even that)
Old Feb 9, 2010 | 09:54 PM
DIXZ's Avatar
DIXZ
NGK TR55 @ .050
Old Feb 9, 2010 | 10:59 PM
87SAM's Avatar
87SAM
Kind of depends on the plug. The TSB you mention is from 2003
A new spark plug has been released for use in the above vehicles. The new spark plug has an Iridium tip instead of the current Platinum tip. Due to the different tip design, the gap of the spark plug has also changed. The new spark plug, P/N 12571164 with AC Delco P/N 41-985, is gapped to 1.01mm (0.040 inches) when the spark plug is made. The spark plug gap is set during manufacturing and should not be changed or damage to the spark plug may result. Any new spark plug found to not be properly gapped should not be used.
Old Feb 10, 2010 | 05:33 AM
JDaniel's Avatar
JDaniel
St. Jude Donor '08-'09
I run BR7EFs at .35 all the time but that's also for nitrous. You won't get a misfire the closer you gap them. Your more than likely to get spark blowout the wider you gap them and I've even had that happen to me on me 2003 KB Cobra running TR6s. Gap your corvette plugs between .45 and .55 and you will be ok... Especially for a simple daily driver.
Old Feb 11, 2010 | 05:48 AM
Patman's Avatar
Patman
I'm disappointed that this topic hasn't gotten more responses Is anyone here running the NGK TR5ix plugs at their preset gap of .039? I might try those out next when it comes time to replace my TR55ix's (which have been in the car for almost 3 years and 32,000 miles now)
Old Feb 11, 2010 | 06:23 AM
Cybermind's Avatar
Cybermind
I'm using NGK TR55ix with the factory set gap and my car runs beautifully.
Old Feb 11, 2010 | 07:17 AM
dbaker's Avatar
dbaker
Originally Posted by DIXZ
NGK TR55 @ .050
Yep,same here on my 02Z.
\db2
Carolina
Old Feb 12, 2010 | 01:16 AM
itzza427's Avatar
itzza427
Delco Iridium's,,,.040,,,runs great!!
Old Feb 12, 2010 | 01:18 AM
The NNIAL8R's Avatar
The NNIAL8R
St. Jude Donor '11,'13
"I voluntarily took 60 days off from OT"
..Only AC Delco Iridiums....get that foreign NGK crap OUT of your GM vehicle ........................................ .......
Old Feb 12, 2010 | 02:17 AM
DeeGee's Avatar
DeeGee
I fitted NGK TR55s iridiums and the advice was to stick with the pre-gapped value which is less than the stock plugs.
There's loads of discussion. Some say stick with the traditional 0.060 but apparently that was prone to poor idle performance which is why the aftermarkets are gapped smaller. I thought the preset gap for TR55s was 0.040 but I could be wrong.
Old Feb 13, 2010 | 06:41 AM
Patman's Avatar
Patman
The preset gap for the TR55s is .059 while the TR5 and TR6 both have a preset gap of .039.
My idle is very smooth with the TR55ix plugs so I don't know why GM decided to drop the gap for the LS1 to the lower setting.
Old Feb 13, 2010 | 09:51 AM
Jet-Jock's Avatar
Jet-Jock
Many new plugs are pre-gapped and can be damaged by changing it.
Old Feb 13, 2010 | 10:11 AM
clayton1's Avatar
clayton1
Banned Scam/Spammer
TR55 iridiums, and I cant remember exactly but its in the .050-.060 range.
To What spark plug gap do you run?
