JWM Projector Lights- Lower Opening Version- Thread 3
Old Sep 13, 2011 | 09:08 AM
  #401
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
My little project
Old Sep 13, 2011 | 09:44 AM
  #402
mcgilles's Avatar
mcgilles
You guys have some some amazing work here. Are thee any picturs of the beam patten, cutoff, light dispersion?
Old Sep 13, 2011 | 02:43 PM
  #403
mtndv8's Avatar
mtndv8
Thanks Mike!! Good to hear from you! Thanks for the email, I'll shoot you some pictures...
Speaking of Pictures. SCM_Crash has graciously agreed to allow his Z to remain at the fabricators one more week for refining the shroud design. Input and photoshop examples are encouraged and welcome...
Huge "Thank You" to Matt/SCM_Crash!!! Mahalo Bradda...
Old Sep 13, 2011 | 04:07 PM
  #404
flaagan's Avatar
flaagan
CF "Young" Senior Member
St. Jude Donor '12
Dammit JW, now I want to paint mine! (Not really... I've got enough to do without adding another project!)
Mtndv8 - How exactly is the shroud going to be held in place? When I was first attempting to put my lights on, it didn't look like you have access to the rear screw that the stock shrowd is held in place with.
Old Sep 13, 2011 | 04:18 PM
  #405
mtndv8's Avatar
mtndv8
Not exactly sure yet James.
My feeling is a new hole will be needed.
So far the input I've received indicates folks would like;
-the turtlenecks evened up with the end of the projector bezels...
-the upper edge of the shroud evened up to a thinner mating line at the front edge of the lid...
-the sides of the shroud better radiused or curved more evenly...
Old Sep 13, 2011 | 04:19 PM
  #406
SCM_Crash's Avatar
SCM_Crash
No problem. I miss my car so much. I can't wait to drive her again. I was hoping that driving around my dad's Vette in the meantime would keep me from missing my Z so much, but I was wrong... My car is more fun.
I was expecting the shrouds to be rounder in the center like in the photoshop pics. Was that not possible?
Old Sep 13, 2011 | 04:29 PM
  #407
mtndv8's Avatar
mtndv8
One more week...
"Too Boxy" is kind of the concensus right now, however the fabricator says there just isn't the room to expose more of the bezels, so the photoshopped look we all like isn't truly possible.
That said we should be able to encourage him to even up the fronts of the turtlenecks as well as adding more radius to the sides. I think the results should at least have the styling cues of the photoshopped version...
Old Sep 14, 2011 | 12:00 AM
  #408
Jistari's Avatar
Jistari
This si about the clearance you have with a flat plane.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
I did that with : a binder, three pots of coffee and two packs of cigarettes Admitedly the oem mounting points are problematic, but I was fairly confident we could wind up with more of the side bezel on the lights showing.
Just love the way they look.
Just throwing it out there, but tis is what the sheet would look like flat prior to bending for this type of look
[IMG][/IMG]
Might it be possible to start with that and layer over it to build up ?
Old Sep 14, 2011 | 12:05 AM
  #409
Jistari's Avatar
Jistari
Originally Posted by mtndv8
One more week...
Or . . .dont turtleneck them.
Old Sep 14, 2011 | 09:52 AM
  #410
jornahow's Avatar
jornahow
Based on the pictures I think the turtle necks are going to create fitment nightmares - I think you will find there will be quite a bit of variation in position and alignment in the installed projectors. I would say lose the turtle necks. If you want to make it really simple use an oval cut out for both lights instead of individual holes for each light and if water intrusion is a problem put a rubber or neoprene sheet in the oval cut out with holes to slip over the barrels of the individual projectors. Just a thought.
Old Sep 14, 2011 | 09:54 PM
  #411
dquagliaroli's Avatar
dquagliaroli
Default turtle necks =
Have waited and waited. Bottom line is that actually being able to see at night is fantastic. howerver -
Have waited this long, lights are installed, would prefer to wait rather than put something that looks unnatural. Don't compromise the look at this point. Turtle neck my **** - go for what should have been the OEM look
Old Sep 15, 2011 | 01:43 PM
  #412
JW Motorsports
Banned Scam/Spammer
I've never been big on halos, but we've had a lot of requests for them so I thought I would experiment a bit. The hard part will be figuring out where to route the wires out of sight. The shroud will make this easier.
I can get them without the plastic piece. I figured this would be a better option since rocks love to hit the headlights.
Not pretty off
Old Sep 15, 2011 | 02:58 PM
  #413
jornahow's Avatar
jornahow
I think halos are neat for fixed light cars, but with retractible lights why would you drive around with the lights up and off and the halos on?
Old Sep 15, 2011 | 03:10 PM
  #414
c5vetteguy's Avatar
c5vetteguy
2018 C5 of Year Finalist
There would be no protection from the elements - the shrouds will be behind the halos in this case. Not necessary for the Sun Guns.
Old Sep 15, 2011 | 03:19 PM
  #415
JW Motorsports
Banned Scam/Spammer
The same thing could be said about the shroud. Nobody will ever see it.
I'm just experimenting since it's been requested. I'll probably tie mine in to a on/off remote switch for shows.
That's the purpose of the clear plastic case you see over the halos.
Old Sep 15, 2011 | 03:55 PM
  #416
jornahow's Avatar
jornahow
Yes but the shrouds are functional, not cosmetic - They're supposed to keep stuff (bugs, chickadees, weasels, marmots) out of the headlight innards.
Old Sep 15, 2011 | 04:05 PM
  #417
cdkcorvette7's Avatar
cdkcorvette7
If you could get them in a different color they might look pretty cool with the lights on...
Even in white they'd look pretty sick parked at a car show or event...
To JWM Projector Lights- Lower Opening Version- Thread 3
Old Sep 15, 2011 | 04:17 PM
  #418
JW Motorsports
Banned Scam/Spammer
Red, white, blue, green, purple, orange, and yellow are available.
The HIDs will probably be too bright to see with them on. I agree about the show part. That's why I will tie mine into an on/off switch
Old Sep 15, 2011 | 04:53 PM
  #419
mtndv8's Avatar
mtndv8
Doug, just so I'm clear on what you're saying. Are you agreeing with Joe's suggestion to consider eliminating the t-necks?
Old Sep 15, 2011 | 11:04 PM
  #420
TheFlyingDutchman's Avatar
TheFlyingDutchman
I agree with the consensus to smooth out the lines, and leaving a bit of bezel is a good thing. Also agree that now is not the time to rush. I'll wait. Take the time needed to get it right.
