JWM Projector Lights- Lower Opening Version- Thread 3
We spoke about it here, I wasnt one in favor of the "turtle neck" look and wanted more of the side of the projectors showing.
It was revised (partly due to necessity) and the reult didnt show as much of the side as I would like but it does show more than version one....its a compromise . . .
Most things in life are a compromise.
Disappointingly the shroud molds arrived a bit broken-up and deformed. Im looking at that as an opportunity to refine the shaping a bit.
I am currently (re)shaping around the projector openings and should get the repairs finished this weekend.
Pictures to follow.
Pictures to follow.
There must be an easy way to make a proto type? I remember one guy thinking outside the box and actually thinking the shroud could be made of a rubber type material which I think maybe could then be carbon fiber overlayed.
As far as what I have seen the model on the yellow vert is near perfect, maybe it could work with modification to the headlight area and attach differently then what existed with the original setup.
Anyway just thinking about how to get some done; it is apparent that the reason this is taking long is that a real good design has not been achieved and it is not easy matching up to existing hardware. I am like most others here, I am not too worried about what some deer thinks about my shroudless lights, I love these lights! I am very happy getting them and not worried a bit about when the shrouds get done, just want a good shroud for an excelant product finished some day!
Here's the fit and problems I've been working thru the last couple weeks. (between snowstorms and family business.)
The shroud mold/plugs arrived warped and a bit broken up from the fabricator. Here's the pics right out of the box...
The original goal of this fitting was to ensure the fit around all the OEM body panels especially the headlight lid and around the connection points. We feel this is more important than around the projector bezels for initial fitting. Unfortunately, even considering that the broken pieces can puzzled back together the fit of these are not where I'd like and would need a lot of work to be at the level I would be comfortable supplying.
I have done what I can to reassemble them and fit them to my lids but don't think I can re-work them without cutting them up. So, I've put thses aside for now and we'll attack bezel opening design(s) after we get the OEM fit right.
I think I have worked out the solution. See if you guys like this direction...
Many of you remember my efforts to mold these shrouds a year ago and I still have the plugs laying around. Here's a couple of pics of one of those plugs...
These ended up being scooped much too deeply the be useable molds. Here's pics illustrating the limitations of the "scoop"...
However, back then I spent hours ensuring the fit to the lid was as close as possible to the OEM black shroud. So I've begun removing the "plugs" from the blue aviation foam reinforcing I molded them to for vacuum forming the carbon fiber and re-fitting them to the lids. Here's pics of that effort so far...
I'll be cutting the backside of the mold out and adding the headlight assembly to this and reforming the bondo/epoxy mix around the bezels this weekend.
Removing all the bondo material carefully and incrementally is a slow and very dusty process. I've also begun a "back-engineering" process with the OEM shoud while during bondo/epoxy cure time(s). Here's pics of the initial trimming and fitting of the headlight assembly/OEM shroud. It might seem a bit redundant but I'll use this approach to ensure the bondo mold closely matches the OEM black plastic fit...
With headlight assembly...
I'll have more to show you guys after this weekend when I get an assembly installed into the prototype lid/shroud...
Here is the driverside and although the fit to the OEM lid was not that good the overall fit was close enough I think they can make it right, given good feedback.
Same pre-fitting story only more so due to the warping in shipment...
After spending time grinding and sanding...
Side by Side...
Fitting and shaping...
Pretty good fit at this point...
Lots of bezel exposed. This has been a desire of some owners and looks like I should be able to accomdate that -BUT- how would it look if halos are added...??
Side by side with the other design...
I have HALOs and am thinking the only way they may look really good is to build a glass/plastic enclosure on the front end.
I just started looking into molding clear plastic used for other automotive headlight designs, course a real glass piece would be the best way to go but probably not feasable.
I have my old covers and may begin to follow your design and see where it leads.
It was really cold most of yesterday and didn't warm up until late in the day. When it did finally warm up I opened up the shop and went to work.
Prepared with several layers of saran wrap over tape.
First layer of bondo...
Second layer...
It was late last night when I finished and I thought I had taken pictures of the piece with everything removed. I'll get some this morning and post them up.
I have a lot of grinding this afternoon but should be able to rough out our design from this...
With the headlight assembly...
Going to need a lot of sanding discs!!
-Side view of bezels: check...
-Small amount of turtleneck at edges: check...
-Room for individual projector adjustment: check...
Comments??
This is the overall design we think we'll go with. A few small refinements from here out but the major work is complete.
Fit to the lid... (rightside-up to save Joe some work...
With assemblies...
Expecting rain, cold temps and occasional snow showers here this week could make it challenging but I think I should have this fitted in place for pictures by this weekend...
[/IMG]
