JWM Projector Lights- Lower Opening Version- Thread 3
Old Sep 5, 2012 | 09:50 AM
  #561
ZEE-OH-6's Avatar
ZEE-OH-6
Is there room for me, I would like to make the purchase also ???
Old Sep 5, 2012 | 10:36 AM
  #562
Patches's Avatar
Patches
Originally Posted by jornahow
My driver's side low beam light failed recently. I discovered that it was actually the resistor that had burned out (I disassembled the resistor; something on the circuit board inside the housing was fried). I removed the resistor and plugged the harness directly into the ballast; both lights now work and the headlights go up and down perfectly without a resistor - I won't bother replacing it.
Hmm . . . gonna have to give that a try.
I'm sure Michael is working diligently on the shrouds.
Old Sep 5, 2012 | 12:30 PM
  #563
mtndv8's Avatar
mtndv8
Originally Posted by Martin555
at least you're lucky to have them on your car!!
i'm still waiting to receive them from the last group buy
Martin, all the Group Buy parts are assembled and awaiting Hella to send me the balance of Hi beam projectors so I can complete them. Have for some time now. I honestly can't tell you why they've taken this long.
I wanted to follow up what JW posted, Hella said they would let us know time frames asap. Please feel free to pm me personally if you'd like to discuss more...
Originally Posted by C5LOU
Has there been any further work done to produce shrouds or is it completely dead?
Not dead Lou. Far from it.
The summer fire season has severly limited the free time I've had to work on them, but I will say...
....you're gonna like the results!
Hmm... me too.
What little time I could spare...
Thanks Ed.
Old Sep 5, 2012 | 08:32 PM
  #564
C7LOU's Avatar
C7LOU
Can't wait!
Old Sep 6, 2012 | 04:23 AM
  #565
flaagan's Avatar
flaagan
CF "Young" Senior Member
St. Jude Donor '12
Hey JW, I believe my driver's side low beam has gone out. I haven't had a chance to check yet, but I didn't see it reflecting in the cars ahead of me on the commute home. Kind of a bummer since I've only had the lights in for a month or so. Anyways, how much and how soon could I get a replacement for it if it is burned out?
Old Sep 6, 2012 | 06:55 AM
  #566
SCM_Crash's Avatar
SCM_Crash
Is it the same side that you installed the resistor on? If it is, try removing the resistor and see if the light turns on. A few others (including myself) had this same issue.
Old Sep 6, 2012 | 08:00 AM
  #567
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Contact me direct for troubleshooting/tech support.
Old Sep 6, 2012 | 04:02 PM
  #568
flaagan's Avatar
flaagan
St. Jude Donor '12
Turns out its the passenger side, not the driver side; resistor is on the driver side. Just wanted to clear that up before contacting JW.
Old Sep 7, 2012 | 01:32 AM
  #569
nvusgt's Avatar
nvusgt
Hey mtndv8
is there any way whatsoever I would possibly be able to buy all the hardware minus the Hella pro's you guys have been outfitting these kits with? I understand this setup was designed using the Hella's and parting with an "incomplete set," might not be possible.
I've been wanting to create my own setup and I can't get passed the quality and craftsmanship that's gone into the necessary hardware. Allowing someone to snag the equipment and DIY a set of dual bi xenons, or a single bi xenon with an LED inner bulb setup, I mean the possibilities are far from limited. I think you might be able to make some money for those who are willing to do it themselves you know?
Just a thought.
Old Sep 7, 2012 | 04:58 PM
  #570
mtndv8's Avatar
mtndv8
Originally Posted by nvusgt
Hey mtndv8
Just a thought.
nvusgt, thanks for the post.
I'm not a vendor on this forum so all sales are JWMotoring.
Interestingly, I have already patterned the FXR Bi-Xenon and one other USDOT Lo beam projector and am considering others too.
I've also been patiently waiting a forum member working out the power needs for a high powered LED system that would lend itself quite well to the lower opening headlight heights.... Possiblities are indeed far from limited.
What were you thinking?
We have sold parts of the kit separately in the past. How 'bout you pm JW what you're planning and we'll see where that goes???
Old Sep 8, 2012 | 12:20 PM
  #571
Patches's Avatar
Patches
Hmm, Michael . . .I may have to wait for the results of those LED's before mounting any shrouds.
Old Sep 8, 2012 | 12:59 PM
  #572
jrc27's Avatar
jrc27
Cruise-In IV Veteran
Cruise-In V Veteran
Old Sep 8, 2012 | 02:16 PM
  #573
nvusgt's Avatar
nvusgt
will do, thank you for your reply.
As for the leds, using a bi-xenon pro, I was thinking of keeping the inboard area projector free and use that space for a row of leds (with a light diffusor so you cant see the individual led bulbs and not completely horizontal, but at a slight angle). As that row meet up with the projector outfitted with a bigger shroud (cut at the top to fit so the bottom is still round) the led/light bar would follow the bottom contour of said shroud.
And for those not able to visualize this, I suppose it might look similar to this:
I understand some people don't like the Audi led headlight treatment, but there's a good number of folks that I think would be very interested in this setup. But one important thing to keep in mind, a light diffusor, be it acrylic, or other material has to be used to avoid seeing individual leds. That's a must to keep this setup looking different than 90% of the crap after market led headlights out there. To be honest, a solid strip of continuous light would look SO much better anyway.
Old Sep 10, 2012 | 09:17 PM
  #574
C7LOU's Avatar
C7LOU
Hmm... me too.
Thanks Ed.
So, is there any estimated completion date for the shrouds?
Old Sep 17, 2012 | 01:15 PM
  #575
jornahow's Avatar
jornahow
ttt
Waiting for a progress report.
Old Oct 17, 2012 | 10:02 PM
  #576
droptopC5vette's Avatar
droptopC5vette
MS Events Coordinator
I want a set!!!!!! Shrouds are NOT important to me!! The lights are!!!
I would also be interested in a DIY setup w just the hardware, if the lights aren't gonna be possible any time soon....
I would DEF be interested in a used set, if anybody knows of a set!!! Pls let me KNOW!!! thanks!!!
Old Oct 17, 2012 | 10:33 PM
  #577
JETninja's Avatar
JETninja
WA Events Coordinator
I could be interested in this setup, specially if it used LED's.
To JWM Projector Lights- Lower Opening Version- Thread 3
Old Dec 12, 2012 | 05:36 PM
  #578
grumblebear's Avatar
grumblebear
so when is the next group buy in? I didn't get any notice of the last...
Old Dec 13, 2012 | 12:37 PM
  #579
IRON MAIDEN's Avatar
IRON MAIDEN
Did the shrouds ever get done?
Old Dec 13, 2012 | 10:48 PM
  #580
grumblebear
not yet
