battery on/off switch
Old Sep 14, 2010 | 12:41 AM
General Lee's Avatar
General Lee
Default battery on/off switch
what is the switch called or the manufacturers brand name that shuts off the draw from the batt?
TIA
Old Sep 14, 2010 | 02:07 AM
DeeGee's Avatar
DeeGee
There isn't a battery master switch on the C5.
You'd need to disconnect the battery lead to isolate the battery .............. or fit a master switch.
Old Sep 14, 2010 | 02:50 AM
Jistari's Avatar
Jistari
http://www.google.com/search?q=batte...x=&startPage=1
About 342,000 results (0.34 seconds)
Tally Ho
Old Sep 14, 2010 | 12:30 PM
General Lee
yea disconnect switch thats it
how can i keep forgetting my best friends name Google
Old Sep 14, 2010 | 12:49 PM
It's a disconnect switch - have one on my car (came with the car when I bought it). Makes for an easy cutoff of the power should you need it.
Old Sep 14, 2010 | 01:02 PM
STALION's Avatar
STALION
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
Damn lazy a$$e$
Old Sep 14, 2010 | 01:32 PM
DeeGee's Avatar
DeeGee
Tally Ho
Thats the switch from my boat
Old Sep 14, 2010 | 01:36 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Old Sep 14, 2010 | 03:17 PM
montan46's Avatar
montan46
2nd Gear
Default Battery Drain
If it's worth anything, I purchased a unit that let's the battery drop to 11.7 volts and then automatically disconnects the battery. I don't remember the name but I got it from Mid America for $69.99 and it's working just like it should. It installs on either the top or side of the battery. The positive gets a screw in terminal post and the positive goes to the unit and the negative has a small wire connection from the unit. It's takes some work, because, like all vettes, there is never enough room.
Before I get hit by others, I've started pulling fuses and found one that showed 5.5 amps draw and when disconnected, dropped to 0.5 amps. I wish I had more time but this unit keeps me going until I find the parasitic pwoer drain. I was getting 8 volts drop overnight.
Down side, resets the clock to 1:00 each time.
Old Sep 14, 2010 | 03:31 PM
montan46's Avatar
montan46
2nd Gear
Forgot to say that it engage the battery, just turn on the headlights, you'll hear some gears moving, and then you have power.
Old Sep 14, 2010 | 04:38 PM
AU N EGL's Avatar
AU N EGL
Battery cut off switches for race cars.
http://www.discoveryparts.com/cgi-bi...roduct=battery
or
Old Sep 14, 2010 | 04:53 PM
hotwheels57's Avatar
hotwheels57
The street rod community has been using battery disconnect switches for years. This company sells models with a micro toggle, or a magnetic lock, or a key lock, or a touch pad. The solenoid resembles an old Ford solenoid. It's rated to 110amps continuous and 750amps surge. A jumper wire allows for all memory features to get power w/o allowing the car to be started. Should someone try to start the car, a small amp fuse will blow out...
http://www.watsons-streetworks.com/battery.html
To battery on/off switch
