Plese emergency help!!
Old Apr 13, 2011 | 10:08 PM
tony123's Avatar
tony123
Default Plese emergency help!!
hi guys today my c5 stopped and i needed to call AAA to tow me. everything was fine. i just went to the grocery store to buy some stuff and when i came back, my car wouldn't start. when i turned the key, my engine stalled and it was acting like it was about to start, but it wouldn't. im getting messages on my DIC computer: reduce engine power, service ABS, service traction system. please, can anyone help me with this problem?
thanks,
tony
Old Apr 13, 2011 | 10:10 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
First thing I would check is the battery, Make sure it has a full charge. Just a guess and starting point.
Mr.Bill
Old Apr 13, 2011 | 10:44 PM
Some really weird things happen when the battery gets low or goes bad.
Old Apr 13, 2011 | 10:46 PM
damilleniumboy's Avatar
damilleniumboy
Yeap, as they stated above your batery is dead.
Old Apr 13, 2011 | 11:03 PM
dennyb7's Avatar
dennyb7
Check the battery!
Old Apr 13, 2011 | 11:05 PM
dbbspider's Avatar
dbbspider
Update? Was it the batt?
Old Apr 13, 2011 | 11:29 PM
mcm95403's Avatar
mcm95403
I had the same problem last week, BUT:
I had just cleaned the filter in the Vararam. I THOUGHT I was careful, but I didn't snap the connector to the MAF on completely. After about 10 miles it poped off and I got all the same symptoms. Snapped it in place correctly and everything was fine.
Old Apr 13, 2011 | 11:30 PM
GBsC5Vert's Avatar
GBsC5Vert
From: LA/OC border, probably sittin' under the patio, by the pool...smokin' a cigar! SoCal
I concur with those above!
Old Apr 13, 2011 | 11:45 PM
damilleniumboy
Yeah, MAF might be a problem. If it starts vert rough it will be the connection to your MAF. The MAF cable is before your throtle body right in your air-bridge.
Old Apr 14, 2011 | 12:28 AM
tony123's Avatar
tony123
thanks guys I will try that tomorrow.
Old Apr 14, 2011 | 07:39 AM
tony123's Avatar
tony123
i checked my air hose and they are fine. I would like to know what is the MAF.... it seems to me like I can't hear my gas pump. It makes a short bzz, and then nothing, as if something had cut it off. I posted on the first post, the messages that I was getting on my DIC. Please guys, i really need help.
Old Apr 14, 2011 | 05:07 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Old Apr 14, 2011 | 05:10 PM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
How is the battery?
Old Apr 14, 2011 | 05:47 PM
tony123's Avatar
tony123
Originally Posted by jacks996
How is the battery?
batery is gooooooooood
Old Apr 14, 2011 | 05:53 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Pull the codes and post them.
Old Apr 14, 2011 | 06:34 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Exactly...pull those codes. Check the fuses....all of them in both fuse boxes.
Old Apr 14, 2011 | 06:59 PM
tony123's Avatar
tony123
OK CODES ARE
PCM
: 0601 H C-MEMORY
1518 H C-PCM to TAC module serial data circuit
TCS: 1241 H C-magna steer circuit malfunction
1276 H C-delivered torque sig. CKT malfunction
PLEASE HOW TO FIX THAT = THANKS GUYS
batry OK
all fuses OK
To Plese emergency help!!
Old Apr 15, 2011 | 07:18 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
I'd check battery with a meter and look at loose grounds?
Old Apr 15, 2011 | 08:17 AM
dgrant3830's Avatar
dgrant3830
I want you to ask to move this thread to the Tech section where Bill Curlee will see it or send him a PM with those codes. This is a much more serious issue with the PCM. Off the top of my head, I'm thinking you've got battery acid corrosion issues on the PCM so you might want to look under the battery. To access the PCM, you need to remove the right fender-well and of course the wheel to get to the fender-well....but please get a hold of Bill.
The P601 usually means a dead PCM. Its possible the TAC module could be causing this but unless you are skilled in these matters, time for a Tech2 and/or the dealer...along with some cash. Is this a '98? Never mind, I looked in your profile and saw that it is. '98's have this issue and it probably is toast...not positive mind you but be prepared.
Old Apr 15, 2011 | 08:35 AM
killain's Avatar
killain
Oldtimer
Default Strange Battery Behavior
Mr.Bill
Also make sure the grounds are clean and tight there's one in the engine bay of the drivers side right inboard of the wheel and bolts into the Chassis.
