Plese emergency help!!
Old Apr 23, 2011 | 02:25 PM
  #41
tony123's Avatar
tony123
Originally Posted by Bill Curlee
Ive never heard or seen one and NO,, there NOT OEM stock what ever it is????!!!
GOOGLED!
http://www.etimago.com/yaris/repairm...mmobilizer.pdf
http://www.autothiefs.com/engine-immobilisers.html
good, I thing only TAC.I saw one on Ebay $250 used 98. HECK NO
I check with a dealer and answer was-sorry backorder-.
thanks for your post
Old Apr 23, 2011 | 06:49 PM
  #42
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Call or contact Gene Culley www.gmpartshouse.com for the TAC. He will het you the correct part.
Old Apr 24, 2011 | 12:15 AM
  #43
tony123's Avatar
tony123
I did, on friday and I got the same answer -backorder-
one day... one day my friend
Old Apr 26, 2011 | 01:23 AM
  #44
tony123's Avatar
tony123
Originally Posted by im-vettin-on-it
trust me on this: You arent getting spark and your fuel pump isnt working! I did all the same things, check the vats, checked the battery, checked the grounds, tried disconnecting the battery. As soon as I can get my hands on a TAC module Ill let you know if it fires up. My cars been down a few months now, I hate looking at it knowing its springtime and I cant drive it.
helo my friend, any news. Im still lol
Old Apr 26, 2011 | 08:08 PM
  #45
im-vettin-on-it's Avatar
im-vettin-on-it
no still in the same boat, trying to get a hold of a TAC. Everyone emails me with, "if your interested in new, contact me" then I do and........its on back order. On the forum they sell so fast, its crazy.
Old Apr 26, 2011 | 08:52 PM
  #46
tony123's Avatar
tony123
I know, I know same with me
Old Apr 26, 2011 | 11:25 PM
  #47
TwoSmoke's Avatar
TwoSmoke
Dang guys. I feel your pain. Something similar happened to me. Except my car would still run even with all the error messages.
Since your waiting on a TAC you could at least look at the driver door wiring harness for chaffing. It worked for me.
http://forums.corvetteforum.com/c5-g...xed-ty-cf.html
Old Apr 28, 2011 | 01:30 PM
  #48
tony123's Avatar
tony123
HOLY HELL What a mess. I almost don't know where to tell you to start but, here goes:
Remove BOTH battery cables! Clean and inspect! Look at the crimp connection under the rubber cover! If all is well reinstall. TORQUE the bolts to 11 ft/lbs.
Turn on the headlights. Motors should both go up and the lights should be bright. Turn lights off. You just checked the main 12 VDC battery buss.
Read this post. In the post, I discuss reading the voltages on specific fuses that are powered by the Ignition Switch "HOT IN RUN AND START" feed. Turn the ignition to ON and check each of those fuses to ground. On top of each fuse are TWO small slots. Those are TEST POINTS.
- C5 ignition Switch repair - http://forums.corvetteforum.com/c5-t...ch-repair.html
Each fuse should read full battery voltage. If you have a LOW reading, you need to clean or replace the ignition switch.
In the passengers foot well, you have a fuse box and the BCM. To the LEFT of the BCM are two thin Gray connectors. Those are STAR 1 and STAR 2 serial data buss connectors. One of the connectors has FOUR wires. The top of the connector comes off and theres a shorting strip in the top that connects all the wires together. Remove the top and see if that changes any symptoms. That removed the door modules and the seat module from the serial buss.
Give all that a look see and tell us what you discover...
Bill
hi Bill, please how I can recognize is it used TAC good for my car(they are all black and same) have one option with tac from Vette '04
please THANKS TONY
PS ; I know abouth thous numbers 1257...3, or newone1924....0
but thous # are not on the TAC-
Old Apr 28, 2011 | 06:15 PM
  #49
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I do not have a TAC to compare but if I remember correctly, they have numbers on the part that faces the PCM. Call Gene Culley www.gmpartshouse.com and he may be able to tell you compatibility between C5 years..
Bill
Old Apr 28, 2011 | 06:21 PM
  #50
tony123's Avatar
tony123
Bill
I found one today that has the exact number that we need (1257...3). I bought it for $200 and it was from C5 2004. We will see what happens when it comes Monday.
Thanks,
Tony
Old May 2, 2011 | 09:22 PM
  #51
im-vettin-on-it
well....did it work?
Old May 3, 2011 | 12:57 AM
  #52
tony123's Avatar
tony123
today I recived a TAC and nathing, looks like my TAC is OK
next step will be a DEALER grrrrrrrrrrrrr
Old May 3, 2011 | 04:02 PM
  #53
im-vettin-on-it
so your computer is ok, and your tac is ok??
Old May 3, 2011 | 04:41 PM
  #54
tony123's Avatar
tony123
Computer... hmmm not sure. It looked like it was in good condition and I didn't find any traces of water damage on it. Anyway, if there is something wrong with the computer, I will need those guys to synchronize is with the TAC and the rest of the car. I will try to get the car to the dealer one of these days and hook it up on Tech 2. We will see what will happen. You will be updated
Old May 3, 2011 | 05:05 PM
  #55
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Does this car have an aftermarket alarm or remote start?
Old May 3, 2011 | 06:01 PM
  #56
tony123's Avatar
tony123
N O, all factory
Old May 3, 2011 | 06:14 PM
  #57
doje's Avatar
doje
Did you ever try a new battery? These things are pretty sensitive to een a slightly dying battery.
To Plese emergency help!!
Old May 3, 2011 | 10:10 PM
  #58
tony123's Avatar
tony123
I've had a problem before with a dying battery and it's not even close to this. Anyway, anytime I do something around the car and the doors are open or I give contact with the key, my battery is connected to the charger and the power is never less than 12 volts. But thanks anyway. Is it possible for something to be wrong with some of the sensors? Any sensor? Maybe the engine, transmition...
THANKS MAN
Old May 3, 2011 | 11:04 PM
  #59
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Try this. OPEN BOTH DOORS! Pop out the accordion tubes. Fish the wiring harnesses out of the door pillar hole.. Disconnect the connectors and see if any of the female pins are bent, burnt deformed...
Old May 3, 2011 | 11:22 PM
  #60
tony123's Avatar
tony123
ok,... wright now
