Door Lock issue
Old May 2, 2011 | 10:49 PM
bucknutt76's Avatar
bucknutt76
Default Door Lock issue
Hey everyone, im sure this has been discused millions of times but with using the search I cant really find my exact problem. I have a problem with my driver door lock not locking with the fob or the electric switch either. I have to do flip the switch by hand if I want to lock it when I get out of the car. Im about to have it painted so I want to get it sorted out so when its done the door pannel doenst have to come off again. Please any help would be appreciated if you have had this problem please let me know what I need to do to have it fixed.
Chadd B.
Old May 2, 2011 | 10:52 PM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
The first thing I would check is the wiring at the hinges. Often get worn / damaged. Could also be a door module.
Old May 2, 2011 | 10:54 PM
bucknutt76's Avatar
bucknutt76
Ok guess I will have to wait until we take off the door pannel in that case.
Old May 2, 2011 | 11:02 PM
RedSoxFan's Avatar
RedSoxFan
Does the lock "click" but not lock? It could be a faulty relay in the door control module. If so here's how to fix it and save $$.
http://www.ronjpics.com/Corvettestuff.htm#DCM
Old May 3, 2011 | 02:21 AM
DeeGee's Avatar
DeeGee
A bad relay in the door lock control module is quite common. I had my right module replaced under waranty but it's starting to fail again.
As Red Sox Fan says, the lock just clicks when you hit the fob. With mine if I hit the fob a few times it eventually operates.
Bakersfield posted the definitive thread but unfortunately its showing as locked.
http://forums.corvetteforum.com/show...ht=door+module
I have a copy if you want one
Old May 3, 2011 | 08:14 AM
barblarry93's Avatar
barblarry93
See my post for needed relays. 3 relays for $20 shipped.
Old May 3, 2011 | 10:09 AM
Jake the Snake's Avatar
Jake the Snake
Most likely its the control module, both of my door locks have failed in the past and the window relay too. You can test by swapping the modules. Its an easy fix as posted above if you are good at very fine soldering. Mine cost $70 to fix w/ all new relays, problem fixed. PM me if you need more info.
Old May 3, 2011 | 08:18 PM
bucknutt76's Avatar
bucknutt76
Thanks for the help guys, there is a clicking noise for sure when ever I try to hit the lock button or on the fob.
To Door Lock issue
