short term storage tips?
Old Jun 2, 2011 | 12:49 AM
Downtimela's Avatar
Downtimela
Default short term storage tips?
Hi all,
I'm leaving my vette sit in my garage for 5-8 weeks, just tanked up with 93 non-ethanol fuel. Is there anything else that it needs, I want to be sure she'll crank up when I return.
Old Jun 2, 2011 | 02:22 AM
DeeGee's Avatar
DeeGee
For 8 weeks I'd disconnect the battery or it'll be dead when you get back. Make sure you turn off the security feature on the radio if you have a stock radio. If you don't it will lock up when you reconnect.
Mine was on the boat in transit to UK for that length of time. Apart from a dead battery it was fine.
Old Jun 2, 2011 | 06:49 AM
baxsom's Avatar
baxsom
it is not a dainty little thing, 5-8 weeks is nothing. just take off the battery cable.
Old Jun 2, 2011 | 07:55 AM
AU N EGL's Avatar
AU N EGL
Battery tender is all you need to do.
Old Jun 2, 2011 | 08:03 AM
rwilkins's Avatar
rwilkins
Mine set from Oct., 2010 till May, 2011 with Battery Tender.....cranked right up
Old Jun 2, 2011 | 08:08 AM
IMXCITD's Avatar
IMXCITD
Old Jun 2, 2011 | 12:06 PM
99 VET's Avatar
99 VET
Oldtimer
St. Jude Donor '13
CTEK-3300 Battery Tender (sold by serveral forum vendors) gets my vote. If no electricy is available disconnect the battery.
Old Jun 2, 2011 | 12:11 PM
Downtimela's Avatar
Downtimela
thanks all, will do one or the other tonight
i don't think my radio theftlok is activated in case i can't find a tender, battery is a new optima also
Old Jun 2, 2011 | 01:25 PM
DeeGee's Avatar
DeeGee
Dont leave an Optima Red Top for 8 weeks. With the dormant drain on the C5 it won't survive. The one fitted to my Vette on its way home to UK was DOA. Its not the battery its the car.
Old Jun 2, 2011 | 01:26 PM
A battery tender should be used to keep the battery fresh. Maybe put a cover over the car to keep dust buildup down. And be sure the tires have plenty of air in them.
Old Jun 2, 2011 | 10:41 PM
chriskaw7r's Avatar
chriskaw7r
For good measure throw some moth ***** underneath to keep the rodents out of the wiring
To short term storage tips?
