temperature readout
Old Sep 7, 2011 | 02:47 PM
Dave 127's Avatar
Dave 127
Default temperature readout
Hi How do I remove the part of the dash to get to the readout? Thanks Dave
Old Sep 7, 2011 | 03:09 PM
DeeGee's Avatar
DeeGee
Which temperature?
Old Sep 7, 2011 | 03:13 PM
The digital readout is part of the Dual Zone HVAC component. If that is what you are trying to remove, the look on the Vette Essentials web site under the install instructions and you'll find what you need to get the radio bezel off which will provide you access to the HVAC unit.
It might help if you provide a brief description of what the problem is you are having.
Old Sep 8, 2011 | 08:58 AM
Dave 127's Avatar
Dave 127
The HV/AC read out was very dim for a while,if you tapped it ,it would glow brighter.Now you can hardly see it at all. I wanted to check for loose wires.
Old Sep 8, 2011 | 10:21 AM
Hey Dave, chances are you'll need to get into the unit and resolder some of the connections back together. I've got some Word files that describe the process - if you'd like a copy, PM me your e-mail address.
And to get the radio bezel off, go to the Vette Essentials web site like I mentioned above and look at their instructions.
Old Sep 12, 2011 | 04:45 AM
DeeGee's Avatar
DeeGee
For the dim HVAC fix try post #20 in this thread:
http://forums.corvetteforum.com/c5-t...iy-thread.html
As Jack says, vette essentials has the best instructions for removing the console
To temperature readout
