I tried the one click parking brake trick, then 2 clicks then fully pulled. It dont turn my DRLs out. So I ll think about pulling the #2 fuse awhile. Thanks again everybody.
While I'm in the fuse block can I also disable the brake lights?
They have not been proved to be statistically significant. If owners think they look cool thats fine but NTHSA haven't proved any safety benefit:
The Studies:
Numerous studies done worldwide since the 1970s have tended to conclude that daytime running lights improve safety. A 2008 study by the U.S. NHTSA analysed the effect of DRLs on frontal and side-on crashes between two vehicles and on vehicle collisions with pedestrians, cyclists, and motorcyclists. The analysis determined that DRLs offer no statistically-significant reduction in the frequency or severity of the collisions studied, except for a reduction in light trucks' and vans' involvement in two-vehicle crashes by a statistically-significant 5.7%.
Theres a definite trend here on the Forum that the DRLs damage the turn signal housing because of the heat they generate. For me that would be a good enough reason to turn them off even if I had a choice.
The good thing is that it's the owners choice but it shouldn't be swayed by unproven opinion or by a GM commercial decision.
thanks for a response. the bulb deal is like 2nd grade for me but i'm still a little unclear on the fuses. what, if any, difference is there between pulling the footwell vs the underhood fuse. maybe i should ask if you lose more or less, or different functions other than the drl's, depending on which one you pull.
here's where i fall into the 'having a discussion' part of a forum. now that i know there are 2 #2 fuses that will render the drl's innoperative, i guess i could just look them up and see what they run.
It's the A2 fuse under the hood that disables the DRLs
The #2 fuse in the footwell controls lighting functions but does not disable the DRLs. It protects things such as the vanity lamps, the underhood lamp and the rearview mirror light.
ok. i was thinking that i pulled the footwell fuse, but it was the underhood one. i must have been in the footwell looking for a column lock harness or something.
DRL's have been a proven safety feature over the years. Please weigh your intentions very carefully considering that you increase your exposure to people who wouldn't "see" you as well running blacked out.
I driven in groups of Several Corvettes for years, and never have I mistaken a DRL being on as a turn signal. The DRL's are definitely a safety factor as they make our cars more visable. I can spot a Corvette from great distance because of them. Plus they look great!
Tell me I'm mistaken, isn't there a feature in the on board (dash) computer settings that allow you to disable them? I swear I saw that feature on my '98.
Nope. You can disable twilight sentinel on cars that are equipped with that option, but not the DRL.
I like the look of a c5 coming towards me with the DRL's on, just looks cool!
Even better when they come up behind you when you're in your DD. It looks very menacing. Of course if your DD is your Corvette cinch your seltbelt tighter and turn your competitive mode on.
When I first got my 2000, I noticed other Vettes, Z28's, and Trans Am's all seemed to have that very distinctive "look at me" look. I could spot them from a mile away. I figured it was some sort of conspiracy to make it easy for LEO's to spot muscle cars (not really), anyway I pulled my fuse for stealth purposes. Every time I see another C5 with the DRL's on I just shake my head, and wave.
Actually folks it' a fallacy that DRLs are a proven safety feature
I agree with that . Only car I leave them on on BMWs because they're dedicated, look nice, and would never be confused with a turn signal (white vs amber). I hate GM's half-*** approach of using the turn signals as DRLs too.
Originally Posted by DeeGee
If you pull the A2 fuse under the hood you'll lose the appraoch lights function
I don't care for any 'extra lighting' feature, but out of curiosity, what the heck is 'approach lighting'? The DRLs turning on while on reverse??? At any rate, the A2 fuse will be my solution. MUCH easier than modifying the relay, which will also throw the same codes, right? Finally, this works on a '12 GS, correct?
Originally Posted by rebelheart
If you dont care about the approach light option (I dont) pull the underhood #2 fuse. My car hasnt thrown any codes this way and is very simple.
Even if ECU throws codes, as long a they don't trigger a CEL or affect emissions readiness, I don't particularly care.
Originally Posted by Bills03Coupe
I driven in groups of Several Corvettes for years, and never have I mistaken a DRL being on as a turn signal. I can spot a Corvette from great distance because of them.
That's not a safety feature; that's a DISTINGUISHING feature .
I don't care for any 'extra lighting' feature, but out of curiosity, what the heck is 'approach lighting'? The DRLs turning on while on reverse??? The relay will also throw the same codes, right? Finally, this works on a '12 GS, correct?
Approach Lighting is the lights turning on when you hit the fob as you approach the car.
Yes. The code tells you the approach lighting (and DRL) is inhibited. Both the relay mod and the A2 fuse brings on a code.
BTW, no one mentioned the fact that the DRLs tend to melt the lamp housings and burn out T/S bulbs.
Find the relay in the passenger floorboard. Pull it out. Remove the gray plastic cover for it with a tiny screw driver. Next take a piece of a business card and cut a sliver. Slide it between the contacts. Plug it bavk in. Done. No problem. Easy! Also won't throw codes. Either that or pull the #2 fuse under the hood. However you will throw a code and disables completely. Ig you do it the other way....no codes and disables the daytime running only.
There are actually two relays to pull and defeat. I deleted mine within the first couple of months of 2003 without codes or any issue. You even keep your "approach" lights when you use the FOB to unlock at night. I honestly do NOT like DRL's on the C5 and am proud to have found this method here on CF.
I did this mod years ago as amber DRLs are illegal in UK. I have a B0502 and B0507 telling me the DRLs are not working. You don't get the DIC warning on start. The approach lights work normally.
If you pull the A2 fuse, the back up lights work normally but the approach light function is inhibited.
Incidentally, I'm still using my original turn signal bulbs after nearly 10 years.
I pulled the relays and put in a small piece of a cut business card to keep the relays from contacting years ago and don't have the codes. Wouldn't care if I did, when I swapped out to the black/amber Depo housings the old housings were burnt up bad and had cracks in them that allowed water in. My fathers '98 is on it's 9th or 10th set of front lights, I've never replaced the bulbs in mine since I disabled the DRLs. If you like the DRLs great leave them on and replace the bulbs regularly, it generates the type of discussion like BSMs
