[Z06] cam
Old Oct 22, 2011 | 06:28 PM
homeless's Avatar
homeless
Default cam
How do these 2 cams compare. I ave a 2003 z06 with headers vararam cold air The cams are 228r and the torquer v2. thanks for input
Old Oct 22, 2011 | 06:45 PM
FourG63 97GST's Avatar
FourG63 97GST
for future reference, the question is pretty broad.
and put the torque specs in your post (I dont want to go look for it, sure im not alone)
Old Oct 22, 2011 | 07:42 PM
homeless's Avatar
homeless
Dont answer at all if you dont know. trying to find some body that is running them
Old Oct 22, 2011 | 08:59 PM
FourG63 97GST
lol, see you're limiting yourself from feedback, many cams share the same/similar specs just have different "name". i've been through 3 cams already, i'm sure I can give feedback on atleast 10
but i'll give you and answer, once better than the other
Old Oct 22, 2011 | 10:02 PM
FYRARMS's Avatar
FYRARMS
Wow. Attitude. FourG63 was hoping you would be more specific with your broad question so he could help you, Touchy Tommy.
Old Oct 23, 2011 | 12:13 PM
homeless's Avatar
homeless
Sorry if i jumped the gun,thought you was being a smart as. well any way the cams texas speed 228r is 228/228 588/588 112 lsa.the other is torquer v.2 232/234 598/598 112 lsa. Would like to know if any body has run them.Also what do you think about them
Old Oct 23, 2011 | 05:10 PM
tlove32's Avatar
tlove32
All things being equal - every degree in duration is worth about 2hp. So the torquer may be only worth 8 or so hp over the 228r, but the 228r might have better drivability due to less overlap
Old Oct 23, 2011 | 08:36 PM
Interspy24's Avatar
Interspy24
Hey hope the car is doing well!
Both are older cams and have been known to work quite well. The 228 cam will have a bit better drivability but give up maybe 8-10rwhp to the bigger 232/234 cam. If you can't decide, go halfway at a 228/232 on a 112+4. This is a great cam and especially with how light the zo6 is, it adds good power but drives well. Keep in mind if you will probably need a clutch soon, especially if you are launching at the track.
Btw I was going to run a custom 231/235 cam on a 112+4.
Old Oct 24, 2011 | 06:43 AM
homeless's Avatar
homeless
I have carried the car to the track.Wanted to see what it would run. Slipped the clutch a little it ran a 1.90 60 ft went a 7.99 at 93 mph.If i get the 60 ft down it should do ok.So far car has been good
Old Oct 24, 2011 | 10:08 AM
aztecracer's Avatar
aztecracer
Just finished getting my 2001 Z06 tuned with HPtuner, car made 413hp....390tq....I'm using the TSP 228r..112 lsa. Other mods are SLP under drive pulley, k&n intake, 1 3/4 longtubes, high flow cats, x-pipe, with SLP Load Mouth exhaust. Car is a blast to drive but need a new clutch
Old Oct 24, 2011 | 03:10 PM
FourG63 97GST
whats you main concern though, do you value drivibility or power? daily?
personally I think the torquer is the perfect medium with it comes to specs.
I went from a 234/238 114 to 239/242 111, and the thought the 234/238 was just on the edge of drivibilty, though that's all personal preference.
for the amount of work, I wouldn't go under 230s, 230-235 is the sweet spot imo. more if you're ok sacrificing for a bit more ruckus
Old Oct 24, 2011 | 09:44 PM
homeless's Avatar
homeless
I dont drive the car much at all.Just wanting little more power,but i would still like to be able to drive it on a 300 mile trip if i choose. Knowing this what would run if it was yours,Thanks
Old Oct 24, 2011 | 10:33 PM
zeevette's Avatar
zeevette
Big cam's are fine if you have a great tuner. I made lots of power NA with only a 228-232 @112+5, and it was very streetable. The lope got noticed, too. People are really surprised to hear a later model car with a rockin' cam. Now I have a blower cam, and I really miss the lope.
Old Oct 24, 2011 | 11:57 PM
FourG63 97GST
My car has similar purpose, but with a MS4, i'll take that on a road trip too
But i'll go with the Torquer in your case, with a descent tune, you probably won't notice it being there even cruising at 1100rpm on your road trip.
Old Oct 25, 2011 | 07:32 AM
AU N EGL's Avatar
AU N EGL
Nothing wrong with an older design cam. That just shows how well that cam works as it has been around a long time.
Old Oct 25, 2011 | 10:57 AM
04goatman's Avatar
04goatman
I had a 228r in my GTO it was a pretty good cam I got about 25-30 HP from it. It had a good sound everyone could tell I had a cam. I picked up the most SOP feel in the low end & mid-range. It was a tire spinner. ADVICE = GET GOOD SPRINGS don’t go cheap. I went .650 lift, I know that’s a little more but I wanted the durability and option just in case I decided to go up.
Old Oct 25, 2011 | 11:23 AM
DANZGLASS's Avatar
DANZGLASS
I think the sweet spot for the 346 is the 228-232 cams they seem to make close to the numbers of the bigger cams with better torque curves. For a street car who wants to have to rev to 4k plus to feel the power? I run a 228-232 .612/.612 113+1 and it makes power everywhere sounds great and doesn't buck in the least.
To cam
Old Oct 25, 2011 | 07:49 PM
PRE-Z06's Avatar
PRE-Z06
What are your goals with the cam?
Old Oct 25, 2011 | 08:19 PM
corvetteandsilverado's Avatar
I installed a cam in my car in May of this year it. So far I love it driveability went down but I knew that going into it with such a big cam I'm running the texas speed tsunami cam 235/240 .648/.609 on a 111 lsa. I was like you I dont drive this car much so when I do I wanted something more so I decided to run this cam I liked the dyno number that I had seen on the internet especially when you get a set of heads and I like the driveability over the magic stick line. I think you would be happier with the torquer IMO good luck and let us know what you decide to get
Old Oct 25, 2011 | 09:34 PM
hdff's Avatar
hdff
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17
england green installed and tuned a mayhem II cam in my z this summer , very streetable and i got 440 rwhp out of it... it is a blast to drive!!!
