Installed Vararam, now Check Engine light
Since you're the most knowledgeable about person who has posted in this thread about tuning the ECM could you clarify some issues for everyone here.
When changing the intake on the C5, the ECM adapts to the revised air flow. Could you explain to what extent it adapts?
When I installed a Vararam on my LS1
trims so long as they are within 0-5 POSITIVE.... I do not like the way the cars run with even as
little as -3%... They shake and run poorly..... Fuel trims above 5 I don't like. Read below....
Ok... While the ECM can adapt to upwards of 20% positive (lean) or so and not nearly
as far Negative (rich) what you don't want is to be running around with a car that's adding 20% to
the fuel calculations (in the form of Fuel Trims) or taking away 15% from the mix.
The car will never run well like that and your mileage will suffer. The second thing is that
one axis of your timing table is in GRAMS/SECOND of airflow and when the airflow or fuel
relative to airflow is manipulated weird things can happen.... This is why I STRONGLY
recommend using the VARARAM air intakes ESPECIALLY ON C6 CORVETTES with automatic transmissions.
In addition to having a reliable, clean, smooth airflow table your transmission will always
shift properly and last a long time. What people don't know (and most tuners too)
is that (on A6 cars especially) the transmissions line pressure values are calculated based
on the airflow values derived form the readings that the MAF takes.
In other words.... The more airflow that comes in, the greater the torque the
engine will produce....and the higher the TCM will elevate the line pressure to prepare
for the increased torque coming from the engine.....
Air intakes that grossly skew the airflow or make turbulence or that VORTEX in the pipe
are VERY BAD for tuners and worse for transmissions.
ONE IMPORTANT THING TO NOTE.... if you're installing a new air intake and you
are under the impression that the Computer will eventually LEARN the WOT fuel.....
You are WRONG. WOT fuel is "COMMANDED" however you only get what you
COMMAND if your MAF table is calibrated correctly... As airflow goes up, the MAF flow should go up....
from roughly 6 grams of airflow at idle for most cars to as much as 500 grams of air for the
C6ZO6 and even more when you add power adders.
Let's say for instance your MAF ERROR is 3%.... Ok, so your Trims are adjusting 3% of about 6
grams of air.... You're talking a VERY small change to your idle airflow and the pcm and
adjust for that.....
Now, at the higher rpms, your making 400-500 grams of air and you're off the same 3%....
That's a much bigger number and an even bigger problem.... Either you're WAAAAY rich or
WAAAAAY lean..... Bad news. Now, let's say you've got an A6 transmission....
and you're running lean cause your maf is wrong..... Just realize that your transmission is
producing WAAAYYYY LESS line pressure and the shifts won't feel good and the trans is
likely slipping.... Especially at WOT.... Bad news again.
Listen to your tuner....Take the cold air advice he gives you....and...
GET YOURSELF A VARARAM to avoid problems.
And don't forget the Chuck CoW TUNE!
Chuck CoW
We are subject to flash flooding down here on the beach [outerbanks] so You have to be carefull after a rain.
Sorry to doubt you, but it is always someones uncles, brothers, cousins neighbor who heard of a vararam causing a hydro lock.Not once have I seen or heard of any real proof of this.In New Orleans we have the worst streets and drainage with almost everyday thunderstorms that would wash most cities away,yet within all three local Corvette clubs and many ,many Vararams,not one single problem!
Sorry to doubt you, but it is always someones uncles, brothers, cousins neighbor who heard of a vararam causing a hydro lock.Not once have I seen or heard of any real prooof of this.In New Orleans we have the worst streets and drainage with almost everyday thunderstorms that would wash most cities away,yet within all three local Corvette clubs and many ,many Vararams,not one single problem!The reason your Vettes in New Orleans don't hydro lock is that they are probably stolen before their owners have them long enough to encounter any water!
I drove through a nightmare rainstorm from Norman, OK to FT Worth, TX last spring on our way to the Lone Star Corvette Club's Classic show based at Texas Motor Speedway. Vararam B2 has been on my car for several years. No PROBLEM!
Chuck CoW
Or even more likely,our corvette owners are bright enough to not drive through foot deep waters!
Chuck CoW
So even if im not getting a check engine light (im still not, after 80 miles of driving) Im still probably running lean? If im understanding you correctly, at idle the car is correcting for the lean condition by adding fuel (not an ideal solution) and at WOT it is not correcting at all, and im running lean as hell? I would hope the computer would look at the A/F ratio throughout the power band and correct for any problems accordingly, by adding up to ~20% more fuel as it as fit where it was needed. I would think the computer would trigger the check engine light if it detected that it was lean, no matter than the RPM, if more than the 20% fuel it can compensate for was required. Is this not the case?
Im not an A4 guy, since I have the Z, so the tranny isnt an issue..
Rebelheart, I'm just having fun with you so take no offense, I think Louisiana and especially New Orleans, New Iberia and the whole area is one of the most beautiful places on the planet!
You also have the best author in the world [James Lee Burke] who writes my favorite books that are based in new Iberia.
Have a great day friend!
Dave
To summarize:
Under part throttle, the ECM uses data from the o2 sensors as well as the MAF to determine the amount of fuel necessary to achieve a stoichiometric(14.7:1) air fuel ratio. The MAF measures airflow while the O2 sensors measure air fuel ratio. The ECM will use a table into which it plugs the MAF readings to determine the amount of fuel it has to supply. If the O2 sensors show that based on the MAF data the air fuel ratio is not stoichiometric, then the air fuel mixture is adjusted to match the desired AFR and recorded as a long term fuel trim. This is called closed loop mode because it repeatedly analyzes the O2 sensors to achieve a target AFR.
Under full throttle, the ECM only uses MAF data to determine fuel requirements. There are numerous reasons for this that aren't particularly relevant. The main point here is that there is no feedback from the o2 sensors to ensure you are getting the correct air fuel ratio. Generally, most mods do not require the MAF sensor calibration to be adjusted. Even long tube headers do not affect the MAF calibration. They require a new tune because the Volumetric Efficiency of the engine has changed, but the MAF calibration stays the same as the actual flow characteristics of the intake have not changed.
In the case of the Vararam, the MAF calibration has to be adjusted because it has significantly modified the intake flow characteristics. The 2 step solution to this problem is to purchase a MAF screen as well as get a tune. The screen is there to ensure the airflow remains laminar instead of turbulent while the tune is necessary to recalibrate the MAF.
IMO, both are necessary as it is very difficult to calibrate a sensor which has to operate both under laminar and turbulent flow. The tune is necessary because despite the screen, the intake still seems to skew the sensor readings down, meaning the airflow is greater than what the MAF is measuring.
Dave
At part throttle, the factory O2 sensors can "trim" the fuel plus or minus to make it run correctly,
but at WOT fuel is COMMANDED based on the MAF sensor reading and a lookup table.
If the MAF sensor reading has changed, then the WOT fuel will be plus or minus by the amount the
MAF sensor is out of calibration.
The problem is that part throttle uses very little airflow and 3 or 4 percent is not a big deal....
However when your breathing 400 grams or so of air at WOT, 3 or 4 percent
rich or lean is a VERY BIG problem. As the RPMs go up, you get progressively more
out of wack and it becomes more and more important to tune the more mods you have and the
more air the engine breathes.
NOW, you might not be moving much more air with your new air intake (any random intake)
but due to flow characteristics which are specific to each one, a cheap intake
might not flow much more air, but because of it's design and shape, it might make the pcm "THINK"
there is more or less air and even the wimpy-ist of air intakes that flows NO MORE AIR
than stock, can drastically hose up your car by throwing the MAF readings grossly out of range
in either the rich or lean direction.... Sadly, only a tuner would be able to tell you what's wrong.....
SO, when Chuck CoW says "USE A VARARAM" if I'm tuning your car....
You can now see why we make such recommendations.
It's something PROVEN, reliable, and plays nice with the MAF and ECM
and I've tuned them 1,000s of time with good results....
Good reason to use one.
Air intakes....ARE NOT JUST AIR INTAKES.... They are EXTREMELY IMPORTANT.
Stay TUNED!
Chuck CoW
Stay TUNED!
Chuck CoW
I got the check engine light after around 100 miles of driving
and after your detailed explanation it seems wise to remove the PD, which is what I just did. I hope that running the vararam with the stock air bridge does the trick. I do realize that its probably going to mess with the tables a bit, but hopefully runnable now with out triggering the engine light.
and after your detailed explanation it seems wise to remove the PD, which is what I just did. I hope that running the vararam with the stock air bridge does the trick. I do realize that its probably going to mess with the tables a bit, but hopefully runnable now with out triggering the engine light.Chuck CoW
Any suggestions? Never did this prior to the installation of the VR2.
