[Z06] Camshaft question...
Old Nov 26, 2011 | 11:48 AM
zedoughtsix's Avatar
zedoughtsix
Cruising
Default Camshaft question...
has anyone heard of a cam that would have the label, GSX 1114 n6645-08. I think this is a custom grind but im not sure. my friend google has let me down... has anyone heard of these identifications?
Old Nov 26, 2011 | 01:49 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Some cam grinders will "HIDE" their duration timing numbers and keep them secret---sort of a chciken Sh thing to do in my opinion---
They won't even give them to you over the phone---
However the #'s you show look like an "LG Motorsports" cam grind
But they are listed like "G5X" rather than GSX--- Are you positive about the #'s ??
Old Nov 26, 2011 | 01:56 PM
zedoughtsix
Cruising
the numbers i am sure of. G5x series would make a whole lot more sense. Im almost thinking that the "1114" has to do with the LSA meaning that its a 114lsa but that is an assumption. !
Old Nov 26, 2011 | 01:59 PM
AU N EGL's Avatar
AU N EGL
if you cant easily find what it is, DO YOU REALLY WANT IT ?
Old Nov 26, 2011 | 03:01 PM
zedoughtsix
Cruising
I already have it, lol I bought the car at a dealer auction and just got done tearing apart the motor. The vehicle was someones baby, and they spent some money on it. It came with some aftermarket parts.. I dont know the original owner so i cant ask.
Old Nov 27, 2011 | 01:20 PM
tblu92's Avatar
tblu92
You can find out EXACTLY what it is in every detail by taking it to an engine shop that has a "Cam Doctor"--- this device measures exactly what the opening/closing points are--the duration--the lift-- the LSA--the centerline--the overlap---
Most place charge like $50 to do it-
Old Nov 27, 2011 | 02:15 PM
zedoughtsix
Cruising
Awesome info! Thank you!
Old Dec 1, 2011 | 05:05 PM
Brandi05vette's Avatar
Brandi05vette
did the same with my cam
Old Dec 2, 2011 | 08:34 AM
CTD's Avatar
CTD
I never tried this but I often thought sitting up a couple of V Blocks, set the cam in their, 2 dial gauges, degree wheel on it. Other than calculating for crankshaft degree's one should be able to figure out the lobe profiles & LSA?
I respect the Top Super Secret cam spec's & there reason's behind it, for me I would never install a camshaft with unknown spec's.
Old Dec 2, 2011 | 08:47 AM
NoVa03Z06's Avatar
NoVa03Z06
Navigator
Great idea! I just bought an 03 Z06 with a mild cam, but don't have access to the prior owner to ask the specs. Thanks!
To Camshaft question...
