Miata vs. Corvette
Made a world of difference on my friends 2000 C5 roadster.
2001 and newer c5s have the metal endlinks.
I also had a RX7, Honda S2000 and a Viper along with three Corvettes. The Miata is still my favorite.
That being said, I must also remind the corvette folks that the lighter the sportscar, the faster it can conquer tight curves. There is a very curvy road, not too far from my house. One afternoon as I was traversing those curves at a good clip, a Miata blew by me like I was a slug. Of course, if I were on a track, I'd have reeled him in and rendered his headlights as tiny blips in my rearview mirror but as I said, lighter cars love those tight curves.
Comparing a Miata and a Corvette is sort of apples and oranges. The Miata is actually going to be faster in certain situations than the Vette but so what? The Vette is more comfortable and all that low end torque is very seductive.
Here's a question: is the Vette closer to the Camaro/Mustang/Callenger or the Miata/Boxster/Lotus?
This Article compares the Lotus Esprit, Ferrari F355, Porsche 911 Carrera 4, Viper GT-S , Acura NSX, and a Corvette C5 FRC.. All pull comparable skipad numbers and offer the same sort or power and comfort. Mario Andretti was the driver behind the tests..
http://www.nsxprime.com/FAQ/Media/magazines/rt9906.htm
I think a lot of it come down to a few things. How important is steering feel? The Vette has very little, its pretty numb and its one of the hardest things to get right. I've driven 2011 and they still don't have it right. I'm putting C6 Z51 sways on mine next week and I expect the steering response to be better but no steering "feel".
I also pulled the console and bezel as I'm putting in a new radio. Cheap plastic saves weight but its still just cheap plastic. You really don't see that on the Ferrari or the Porsche. But then they cost a lot more. In that respect (quality of interior parts) the Vette is like the Miata. I wouldn't even say its as good or better than a 370Z.
Vettes always seem to be a little behind in car tech as relates to things like blue tooth, iphone/android adapters, etc.
So in terms of quality of materials in the interior, the Vette is more muscle car. But underneath, the Vette is quite well built and capable of taking a lot of abuse. Suspension is very solid, engine is very good. Electricals are reliable, AC is powerful. All traditional American car virtues.
All in all its the Corvette is a heck of a car, let down in just a few areas. Unfortunately, those areas jump right out at you. The virtues take a little time to appreciate.
Apart from the fact that the 380mm OEM wheel results in a very large effective steering ratio, the overall weight of the wheel adds to the numbness.
A smaller diameter wheel will still require the same amount of rotation for a given tire angle, but the actual distance traveled by your arms will be significantly lower resulting in a perceived decreased steering ratio. Additionally, while the torque required to turn the wheel will be the same, the force required to generate that torque will now be greater due to the fact that it will be acting over a smaller radius. This makes the steering heavier(which IMO is good).
The other benefit of replacing the OEM wheel is that the weight and moment of inertia of the new steering wheel will be much lower. This effect is analogous to putting lighter wheels and tires on a car. Less mass results in less inertia which results in faster acceleration. Without getting too technical, if you consider that the rotational analog of Force = mass x acceleration is torque = rotational mass(inertia) x rotational acceleration, then by decreasing the inertia, you effectively reduce the torque required to accelerate the steering wheel.
What's interesting to note here is that the driver is not the only source of force/torque acting on the steering wheel. The front wheels of the car transfer the forces generated by the car changing direction into the steering wheel. When you remove mass from the steering wheel, you are effectively removing a damper which absorbs the energy generated by the forces acting on the front wheels. By removing this damper, more energy is then transferred into your arms resulting in a more direct connection to the front wheels.
Lesson learned Lighter has advantages but when I got out of the Mudd I was in A big Fire breathing V-8 and he was, well, still a little brat! HA....
No hating on Miata's at all, everything has its place!!
