I need help finding AMBIENT TEMP SENSOR
Old Oct 21, 2012 | 06:49 PM
1ST-C5's Avatar
1ST-C5
How do i access the sensor?
Old Oct 22, 2012 | 02:04 AM
DeeGee's Avatar
DeeGee
Take a look at the picture I posted. Post #4 That's the sensor
Old Oct 22, 2012 | 08:51 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Not sure where you are located, But the ac light will flash if it is cold outside and will not turn on, It has to be above a certain temp for the ac to work.
Mr.Bill
Old Oct 22, 2012 | 10:02 AM
1ST-C5's Avatar
1ST-C5
Default removal?
Do i get to it from under the car or remove fan shroud etc on top?
Old Oct 22, 2012 | 11:09 AM
knewblewkorvette's Avatar
knewblewkorvette
I went underneath to get to mine. Good luck
Old Mar 17, 2013 | 12:24 AM
TexasVette64's Avatar
TexasVette64
My 97 A/C does the same thing when I push the A/C button. It flashes and than goes off. My outside temperature reading is correct with actual temp. I was going to bring it down and check and see if it just needed some freon. After reading this post that might not be the answer.
Old May 10, 2013 | 06:09 PM
R2R's Avatar
R2R
Mine flashed when freon was low. Put 1.5 lbs in and have no flashing and cold air coming out both sides.
Old Oct 2, 2017 | 05:04 PM
john_grabner's Avatar
john_grabner
4th Gear
Default temp sensor fastener
Originally Posted by DeeGee
How does one remove the fastener that hold the temp sensor?
