Why so many fish-tail wipeouts?
when I did an autox event I spun out. while on a straight. my instructor (ex z06 owner) told me to gt on it. I did. Before we knew it I was spinning. traction control was on. I spun twice. had the brake hammered as soon as it started to spin. he count believe it happened so quick fast. in fact I'm still working on a remedy and have put a ton of money into it.
long story short, I did everything right and still came out wrong
It's straight racing theory, no mystery. I too have many, many years in very fast cars, but sometimes you find yourself in a no-win situation. If this were not the case, Nascar and Formula One drivers would never hit the wall or spin!!!!! Think about it.
DSTURBD
The "why' doesn't matter. Honestly - it doesn't.
All that matters is that you how to drive the car when things get out of shape. You do this by putting yourself into the position where the car gets out of shape and then getting the point of being able to deal with it. It doesn't matter whether you are doing a burnout, entering a turn, trying to dodge a refrigerator on the freeway exit or have just suffered a blow out.
All the theory in the world is no good if you have never actually experienced the events you are studying - or at least the aftermath. Spins, fishtails, slides etc.
This means you have to put yourself into the spots you hope to know how to avoid or drive your way out of in the future, in a controlled environment.
Get to that empty parking lot - put up some cones and get to know your car. Even an HPDE or AutoX is not the place to find out some of these maneuvers - as has been pointed out, if you get out of shape enough they may send you home.
Empty parking lot or advanced driving school are really your only 2 choices.
On track things can end up happening almost too fast to serve as learning experiences.
Skip to 7m20s in this video to see what happens when the clutch wont allow smooth shifts, the car gets stuck in neutral at 120mph and when it gets into gear it dies and you have to bump start on the entrance to a decreasing radius turn.
Had I not had the car out of shape on my terms before this event, I am not sure I would have been so calm dealing with the cascading events. The car wanted to snap around so fast while coasting it required a violent counter steer - no time to dilly dally - just react.
One thing I notice about a lot of people who do the see-saw spin outs, is they all seem to over counter-steer or snap from one side to the other too fast, and too far which throws the weight balance around too quickly and you basically lose any chance to bring it back to a medium.
Another thing is I think sometimes it is (if the environment will allow and your only goal is to save it) to just let the car understeer with minimal attempt at counter-steering the fish-tail. Often times you will be better off going off the road a bit or into another lane than finding yourself in an ice skate just going along for the ride and ending up who knows where!
When I had my Z06 with terrible tires, I had it kick out on me twice and it happened in a split second and on uneven road. All I did was let-off the gas and counter the slide by about 1/8 of wheel turn, and as soon as it was almost straight in the direction I needed to go, I lightly started to get back on the gas (a cruising speed amount) to transfer my weight back to try to gain traction again, and away I went. It probably helps that I have very quick reaction times and my heart does not "jump" until after the event, so I do not panic and make a bad move!
This is all just my personal opinion and I am no race car driver, so everything I just said could be all BS.
other is the tires they are on and day to day changes in the weather. a guy might do something on a 90deg, have traction and continue through
try it on a 50deg day and the tires break loose.
so many variables go into this
besides you should never be pushing more than 75% on the street anyway. you absolutely have to leave room for error cornering, could be gravel, oil, who knows. if you drive at the limit of traction on the street often you will wreck cars.
For example, a mountain road with a 3,000+ foot drop on one side is not the place to teach yourself how to push your limits. Neither is a street with a crowd lining the road, or on the road with other cars around.
VERY well put!I think a lot of what we are seeing is that for he first time, stock 400hp C5s and C6s are becoming affordable to kids that have only driven fast cars in Forza and GT5. You get your first decent job that allows you to afford a $350/month car payment and instead of buying a Civic Si as your first "fast car", you buy a supercharged C5 for $18,000 that makes 600rwhp. And that kid either figures it out and becomes a great driver.. or he ends up on YouTube.
Whether it be because he/she spun into a tree, up a hill, or just to show off their new-to-them high-hp monster!
