flickering interior light
Old Jul 3, 2012 | 09:54 AM
wolf1281's Avatar
wolf1281
7th Gear
Default flickering interior light
New to the Forum. I have a 2004 convertible. The under dash light on the drivers side flickers when lit. I removed the bulb,it has small yellow photo light sensors built in. I think the bulb is bad since the passenger side is working fine. Problem is ,I called a couple of Chevy dealer's. The only bulb they have listed is an 1194. No sensors. Any idea where I can get one of these bulbs with the light sensors. Thanks Wolf
Old Jul 3, 2012 | 09:56 AM
65GGvert's Avatar
65GGvert
Why would you want light sensors in the drivers side floor lamp? I'd just put in the correct one.
Old Jul 3, 2012 | 09:58 AM
wolf1281's Avatar
wolf1281
7th Gear
Default flickering light
I didn't. I believe it's the stock bulb.
Old Jul 3, 2012 | 10:01 AM
65GGvert's Avatar
65GGvert
The stock bulb didn't have sensors. It's the same as the passenger bulb
The list I saw said use 194 or 37
Old Jul 3, 2012 | 10:06 AM
wolf1281's Avatar
wolf1281
7th Gear
THANKS. I'LL check.
Old Jul 3, 2012 | 10:12 AM
DeeGee's Avatar
DeeGee
The stock bulb is a 194 for the courtesy lights.
Here's a full list FYI
CHEVROLET Corvette
Low beam headlamp: 9006
High beam headlamp: 9005
Parking light: 4157NA
Front turn signal: 4157NA
3157 will work:
The 4157 is slightly brighter (28.5 vs 27 watts for the 3157).
Rear turn signal: 3057
Tail light: 3057
Stop light: 3057
High mount stop light: LED Unit. Replace whole unit
Part #: 10253893
Fog/Driving light: 899
License plate: 194
Back up light: 2057
Front sidemarker: 194
Rear sidemarker: 194
Glove box: 194
Map light: 212-2
Step/Courtesy light: 194
Under hood light: 561
Instrument-general: 194
Automatic transmission indicator: 194
Note: If the bulb has or includes the suffix LL it’s a Long Life Upgrade which gives up to twice the life of the standard lamp
Sylvania Lamp Replacement Guide
http://www.sylvania.com/ConsumerProd...RG-Results.htm
2002 CHEVROLET Corvette
Low beam headlamp
9006
9006SU SilverStar Ultra: The brightest and whitest light. Up to 50% brighter, up to 40% more downroad visibility and up to 50% more sideroad visibility.
9006ST SilverStar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
9006EB EcoBright - Your Environmental Choice. Save Energy - Save Money. Up to 25% brighter light. CO2 reduced 9 to 21%. Gas savings $2 to $19.
9006XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility.
9006CB Cool Blue: The whiter light for style. Up to 25% brighter light and up to 25% more downroad visibility.
High beam headlamp
9005
9005SU SilverStar Ultra: The brightest and whitest light. Up to 50% brighter, up to 40% more downroad visibility and up to 50% more sideroad visibility.
9005ST SilverStar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
9005EB EcoBright - Your Environmental Choice. Save Energy - Save Money. Up to 25% brighter light. CO2 reduced 9 to 21%. Gas savings $2 to $19.
9005XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility.
9005CB Cool Blue: The whiter light for style. Up to 25% brighter light and up to 25% more downroad visibility.
Parking light
4157NA
Front turn signal
4157NA
Rear turn signal
3057
3057ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
3057LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Tail light
3057
Stop light
3057
Assembly
Fog/Driving light
899
License plate
194
194ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
194LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Back up light
2057
2057ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
2057LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Front sidemarker
194
Rear sidemarker
194
Glove box
194
Map light
212-2
212-2LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Step/Courtesy light
194
37
37LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Trunk/Cargo area
168
168ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
168LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Under hood light
561
561LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Instrument-general
194
194
Old Jul 3, 2012 | 11:05 AM
Great post DeeGee - that list will come in handy when a bulb needs replacement.
Old Jul 3, 2012 | 03:58 PM
SilverC54me's Avatar
SilverC54me
The bulb you are describing is a replacement LED. This is the only reason flickering would occur on just one lamp a a time. The factory replacement is a type 194.
There are several forum vendors that sell replacement LED bulbs. I bet that most of the replaceable bulbs have been changed to LEDs by the previous owner.
Gary
Old Jul 3, 2012 | 04:09 PM
wolf1281's Avatar
wolf1281
7th Gear
Thanks Gary. I think your 100 percent right. I haven't been able to get down under the dash and check it out. Pulled my back a few days ago. Is it better to go with the original 194 or stick with a replacement LED?
Old Jul 3, 2012 | 05:14 PM
ALLEGRO's Avatar
ALLEGRO
Old Jul 3, 2012 | 07:55 PM
SilverC54me
This depends on how much of the lighting has been changed to LED. If it is just the foot wells the put the regular bulb back in. If the whole car has been changed to LEDs I would replace the bad one with an LED.
Gary
Old Jul 3, 2012 | 09:51 PM
CSM Z06's Avatar
CSM Z06
Gary
Old Jul 4, 2012 | 01:04 AM
o2bnkc's Avatar
o2bnkc
You can get the LED's off of fleabay for a couple of bucks . That's where I got all mine. A lot of auto parts stores have them, too. No sense in paying a corvette tax. Stay away from the corvette vendors on those.
Old Jul 4, 2012 | 07:38 AM
wolf1281's Avatar
wolf1281
7th Gear
Thanks for the info.
To flickering interior light
