One "EYE" won't open ?
Old Jul 17, 2012 | 07:20 PM
gtbbaby's Avatar
gtbbaby
Default One "EYE" won't open ?
My '98 vert's driver's side headlight won't open on it's own but the lamp is on - I can open it manually with the **** though. I replaced battery and it was ok for a few weeks, now it's acting up again. Any help would be appreciated. Thanks in advance guys.
Old Jul 17, 2012 | 09:26 PM
Perhaps the headlight gear or the motor has gone bad?
Old Jul 17, 2012 | 09:50 PM
Dave68's Avatar
Dave68
Take a look at this:
http://forums.corvetteforum.com/c5-g...orialized.html
Old Jul 17, 2012 | 09:54 PM
calivette805's Avatar
calivette805
check if power is going to them . might be the gears witch commonly wear out or brake. if not the gears motor. if it is a power issue you might want to check fuses
Old Jul 18, 2012 | 02:22 AM
mike5511's Avatar
mike5511
Originally Posted by Dave68
I just used this write up and fixed my passenger side. Great writeup!
Old Jul 18, 2012 | 04:26 PM
cessna10's Avatar
cessna10
cesssna10
One benefit of getting older, dont like to
drive at night so avoid it like the plague,
therefore lights never get turned on.
Old Jul 18, 2012 | 04:38 PM
Corvette_Ed's Avatar
Corvette_Ed
Mine does the same thing, it works sometimes and others it doesn't. It's not the gear and I tried oiling it, but so far I haven't figured out the problem.
Old Jul 18, 2012 | 06:08 PM
2slicks1vette's Avatar
2slicks1vette
for all intensive purposes i think this is a grate idea. minus well check everything to be sure
Old Jul 18, 2012 | 07:32 PM
Chicago1's Avatar
Chicago1
If your gear is bad you will hear it. Do you here grinding? If it is then its the gear and being a 98 I'm surprised it hasn't happened. Another thing is pull the healight module out and clean the connectors they may be corroded or the module is going out. If not those two look into your healight switch/stalk those go out a lot I can guarantee it will be one of those three
Old Jul 19, 2012 | 09:16 AM
Corvette_Ed
Where is this module located?
Old Jul 19, 2012 | 10:01 AM
Lenrock's Avatar
Lenrock
Check to see if the 2" cam bolt is in place. I had same thing happen to me a week ago and got the gear rebuild kit and redid both when I discovered the the retaining gromet on the cambolt slid off. I guess it needed to be done sooner or later anyway
Old Jul 19, 2012 | 06:42 PM
gtbbaby's Avatar
gtbbaby
nope - no grinding - but I took it out today and it worked fine - WTF?
Old Jul 20, 2012 | 11:43 PM
fnseeker's Avatar
fnseeker
Default Drivers side headlight some times opens.
I have a 02 zo6 and the drivers side comes up almost every time during the day. And almost never comes up on the first 3-4 tries at night.
It has become a family joke that the car is afraid of the dark.
I have cleaned and checked the connections over and over. After I work on it. The motor works fine for a while. Evetually, it stops working. If I unplug and replug the connector. it usually works. Sometimes I have to jiggle or tap the motor and then it works.
Short of replacing the motor. I have become very fruastrated with this.
To One "EYE" won't open ?
