Found while replacing Window Regulator
Old Jul 26, 2012 | 02:03 PM
RV13's Avatar
RV13
Default Found while replacing Window Regulator
While replacing my driver's side window regulator, I noticed that this rubber seal has broken down into a bunch of tiny pieces...is it important? Should I replace it? Thanks!
Old Jul 26, 2012 | 04:25 PM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
I think that's what's left of the insulation gasket. It covers the whole opening. Important, no, nice to have, yes. Fairly inexpensive. The dealerships, major vette aftermarket suppliers, gene, all sell them still I think. I covered mine with frostking peel and stick foil covered foam insulation from lowes
Old Jul 26, 2012 | 04:56 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Oh I thought you was going to say you found a dope hole. IIRC there was a new owner of a C4 who said he found a dope compartment in his door.
Old Jul 26, 2012 | 05:07 PM
jrose7004's Avatar
jrose7004
I figured that you found a nut tied to a piece of string so that it would rattle.
Old Jul 26, 2012 | 05:13 PM
MawneeC5's Avatar
MawneeC5
http://forums.corvetteforum.com/c5-g...drug-mule.html
Old Jul 26, 2012 | 06:44 PM
RetiredSFC 97
Oh it was here. Thanks, I couldn't remember as I frequent the C4 section as well.
Old Jul 26, 2012 | 07:45 PM
bj1k's Avatar
bj1k
Thats your water splash curtain. It keeps water from splashing onto your inside door panel when water reaches the inside of the door. You should replace it .You can just cut a peice of heavy plastic and press it on to the sticky sealer. Will do the same thing.
Old Jul 27, 2012 | 08:57 AM
If it were me, I'd replace it and seal that area up.
Old Jul 27, 2012 | 09:15 AM
Evil Oil Apologist's Avatar
Evil Oil Apologist
water vapor barrier
Certainly helps, cheap, replace.
Old Jul 27, 2012 | 09:18 AM
Corvette_Ed's Avatar
Corvette_Ed
I have mine covered with Dynamat....
Old Jul 27, 2012 | 10:14 AM
RetiredSFC 97
Heavy gauge plastic will take car of that. Like the type they use for vapor barriers.
To Found while replacing Window Regulator
