[Z06] engine id question
Old Jan 9, 2013 | 08:27 PM
LT1driver's Avatar
LT1driver
Default engine id question
where on a new c5 LS1 crate engine is the code that tells what it is, i.e. ls1, zo6 etc. also what type is it, paper, stamped etc. that tells what engine you have. thanks.
Old Jan 10, 2013 | 09:51 PM
LT1driver's Avatar
LT1driver
nobody knows the answer to my question????
Old Jan 10, 2013 | 10:35 PM
JETninja's Avatar
JETninja
WA Events Coordinator
Can't speak for all LS6's...but mine has a bright red sticker on the Throttle Body that says LS6...and most seem to have that.
'04 Z..
Old Jan 11, 2013 | 12:02 AM
skyavonee's Avatar
skyavonee
I've heard from multiple sources that late-model LS1's (01+, or maybe 02+) use the LS6 block. If that's true, I'm guessing new LS1 crate engines also use the LS6 block. So basically it comes down to what heads/cam are installed. Look at the front corner of the cylinder heads. If '241' is stamped there, then they're LS1 heads; if '243' is stamped, then they're LS6 heads.
Old Jan 11, 2013 | 08:50 AM
AU N EGL's Avatar
AU N EGL
They seem to be called LS1s but are really LS6 blocks.
Check the heads and see what is stamped on the right front side of the head.
Old Jan 12, 2013 | 08:57 AM
MY03C5Z's Avatar
MY03C5Z
'04 Z..
They only came on 04z's. I added one to my 03
Old Jan 14, 2013 | 10:42 PM
LT1driver's Avatar
LT1driver
thanks, info was very helpful
To engine id question
