Cautionary note about Techron
Old May 26, 2013 | 08:00 AM
FLZapped's Avatar
FLZapped
Default Cautionary note about Techron
While doing something else, I knocked over one of my bottles of Techron. At the time, I didn't think anything of it. After a few moments I smelled something. The bottle was leaking, so I picked it up and tightened the cap, which was loose.
I then checked the rest of my 4 bottles and not a single one of them had a tight cap. The next time you pick some up, check the cap for being on tight. The stuff is too expensive to waste, or allow to evaporate because of the cap not being properly seated at the factory.
Old May 26, 2013 | 08:22 AM
slvr bulit's Avatar
slvr bulit
My bottles have a foil seal under the cap
Old May 26, 2013 | 08:23 AM
Phanni's Avatar
Phanni
Every bottle I've ever opened has had a seal under the screw on cap.
Old May 26, 2013 | 08:26 AM
James2002z06's Avatar
James2002z06
Default That's spooky
Old May 26, 2013 | 08:27 AM
andrec10's Avatar
andrec10
Foil Seal. Whats really in your bottles?
Old May 26, 2013 | 09:15 AM
Oldvetter's Avatar
Oldvetter
Yep, they come from the factory with a foil seal. Due to the flammability of this stuff, I doubt that they could ship it if it didn't have a foil seal!
Old May 26, 2013 | 09:32 AM
Corvette_Ed's Avatar
Corvette_Ed
It's kind of hard to spill something that has a seal placed on it from the factory. If the bottle the OP had problems with did not have this seal it would indicate that someone had purchased it and returned it. I'd wonder what was really in it to begin with and would definitely NOT put it in my gas tank.
Old May 26, 2013 | 10:37 AM
Sonny71's Avatar
Sonny71
Oldtimer
Originally Posted by 8VETTE7
I've used dozens of bottles of Techron over the rears and they ALL had foil seals. Unless you removed the seal yourself, I would NOT pour the contents into my tank............
Old May 26, 2013 | 11:02 AM
bj1k's Avatar
bj1k
If it doesn't have a foil seal , take it back. Someone has tampered with it.
Old May 26, 2013 | 11:03 AM
CQRT's Avatar
CQRT
Was the seal messed with on your bottles?
Old May 26, 2013 | 11:19 AM
env00's Avatar
env00
Thanks OP, I had a similar issue...bought a pack of the from costco...the seal on one of the bottles was not glued on (not broken either)...didn't notice until I got in the car (smell of gas)...no prob replacing...could be deliberate but now thinking this a quality control issue...this was about a year ago. Thanks!
Old May 26, 2013 | 11:36 AM
jrose7004's Avatar
jrose7004
I'd take it back.
To Cautionary note about Techron
